ricox
13 Rej ... I Need Some Help... Thank's
Thu May 26, 2016 3:43 pm
Hi all,
today is not one of my best a.net day  , I've experieced 13 rej consecutively, I appealed one and it was added to db, good but now I have to ask other opinion on these:
1- https://www.airliners.net/addphotos/r...0160526_r1463470864.0941g-ezdj.jpg
quality blurry dark
2- https://www.airliners.net/addphotos/r...60526_s1463470470.5206ra-67218.jpg
quality blurry oversharpened , I signaled that there was heathaze on the back and it is easy to think that is on the plane fusoleage but not, it was already rej for ovs I reduced a lot ...
3- https://www.airliners.net/addphotos/r...0160526_j1463472125.6079hb-jya.jpg
grainy soft dark pheraphs little soft on the window but could you indicate where are dark and grainy noticeable? Thank's
4- https://www.airliners.net/addphotos/r...0160526_k1463470707.2506bh-clh.jpg
quality blurry dark
Thank's very much for any suggestion.
Bye
airkas1
RE: 13 Rej ... I Need Some Help... Thank's
Thu May 26, 2016 5:08 pm
1) I agree. It's blurry and the sun-behind-the-clouds makes it look dark. Not a lot you can do to fix that one.
2) It just looks too heathazed, sorry. Heathaze does bad things to a photo, making it soft and easily oversharpened at the same time. In this case, I see both. The nose looks soft and the back is oversharpened. Not sure if this is fixable.
3) Definitely dark and soft. But it looks out of focus (hence soft). This photo doesn't seem fixable in Photoshop.
4) It could probably be a little lighter, but it's a marginal photo. It seems a little oversharpened to compensate a blurryish original.
[Edited 2016-05-26 10:08:21]
len90
Fri May 27, 2016 1:18 am
1. Agree with Kas
2. Agree with Kas. Way too much heat haze in that picture thus giving the OS appearance. Look at the cheat line and see it just jagged all throughout
3. OOF and VERY dark
4. Looks more OS than anything else to me. It is dark but not too bad on that.
vikkyvik
Fri May 27, 2016 4:06 am
Quoting ricox (Thread starter):
quality blurry dark
Agree with quality and blurry, might throw in oversharpened, which often goes along with blurry.
Marginal, maybe OK at a smaller size, but probably not.
Agree with Kas, looks out of focus, and certainly dark. Take a look at the histogram - there's a lot of empty space on the right side.
quality blurry dark
Maybe not blurry, but definitely oversharpened. You could try at a smaller size, but the light will probably kill it.
ricox
Fri May 27, 2016 4:59 am
Thank's a lot, I understand.
In Nice I used 1.4x on 100-400L II, probably I lost a lot of sharpening...
