jelpee
Re: Screening help.
Sat Apr 20, 2019 7:27 pm
Not the best of lighting. #3 looks a bit over sharpened (titles and cockpit windows). Others are passable for me.
Jehan
Crosswindphoto
Re: Screening help.
Sat Apr 20, 2019 7:49 pm
Thanks Jehan!
airkas1
Re: Screening help.
Sat Apr 20, 2019 8:57 pm
I agree with Jehan, although for me only the cockpit of the last photo looks a bit OS. Titles are fine for me.
Crosswindphoto
Re: Screening help.
Sun Apr 21, 2019 10:20 am
In my experiences those lines will always look jaggy even with no sharpening. Granted it looks way more noticeable with sharpening but it will always look jaggy, at least with he equipment I have.
Crosswindphoto
Re: Screening help.
Tue Apr 23, 2019 4:14 pm
Would this shot be considered similar to a photo that I already have uploaded?
https://www.airliners.net/photo/-/-/540 ... X673L3w%3D *uploaded shot*
https://imgproc.airliners.net/photos/ai ... c68fbfcbee *shot in queue*
Also a pre-screen on it would be appreciated.
Tim
airkas1
Re: Screening help.
Tue Apr 23, 2019 4:22 pm
If it's not the same day, then you might get away with it, but it is awfully similar, yes.
Crosswindphoto
Re: Screening help.
Tue Apr 23, 2019 5:06 pm
I'll leave it in then,
Thanks Kas!
Crosswindphoto
Re: Screening help.
Fri Apr 26, 2019 4:19 pm
Can I get a pre-screen on this photo please?
https://imgproc.airliners.net/photos/ai ... 78171c2190
jelpee
Re: Screening help.
Sat Apr 27, 2019 11:20 pm
This will draw a "Motive" rejection for the blockage of the nose due to the air-stairs Too bad since it is otherwise a good image; I like the perspective.
Jehan.
Crosswindphoto
Re: Screening help.
Sun Apr 28, 2019 10:14 am
Thanks Jehan!
Crosswindphoto
Re: Screening help.
Tue Apr 30, 2019 6:51 pm
Can I get a pre-screen on this shot please?
https://imgproc.airliners.net/photos/ai ... 28b0429888
Tim
jelpee
Re: Screening help.
Wed May 01, 2019 12:01 am
Tim,
Needs some additional contrast (check the histogram). I would prefer that the King Air be centered. Centering will still show part of the A300(?) in the frame. Otherwise nice, IMO.
Jehan
Crosswindphoto
Re: Screening help.
Wed May 01, 2019 10:15 am
I centured it to leave in the RCAF titles on the Polaris, but I will center it more and add contrast, thanks Jehan!
airkas1
Re: Screening help.
Wed May 01, 2019 12:43 pm
I would crop the right side just left of the "ARC" of the Polaris.
Crosswindphoto
Re: Screening help.
Wed May 01, 2019 4:48 pm
jelpee
Re: Screening help.
Wed May 01, 2019 10:09 pm
Tim,
Citation: Mildly over sharpened: jaggies visible in tail section, but should be OK
Cargo Jet: I don't like the clipped horizontal stabilizer on the right side.Would likely draw a motive rejection. Can you give it a wider crop to include the entire stabilizer?
Jehan
airkas1
Re: Screening help.
Wed May 01, 2019 10:13 pm
#1: the jaggies on the building and cheatliens are too much for me.
#2: crop is passable for me, but heat haze and not great quality (especially towards the back).
Crosswindphoto
Re: Screening help.
Thu May 02, 2019 10:15 am
Thanks guys!
Crosswindphoto
Re: Screening help.
Thu May 02, 2019 4:05 pm
Are these 2 better?
I cant escape jaggies on the building itself in the Citation shot, but they are gone from the aircraft itself now.
https://imgproc.airliners.net/photos/ai ... 80b587e601
https://imgproc.airliners.net/photos/ai ... f6150a90ac
airkas1
Re: Screening help.
Thu May 02, 2019 4:18 pm
The Cargojet looks nice. For the Citation, there are still jaggies on the fuselage cheatlines in front of the engine. If you have sharpened the building as well, use the eraser on that as well as the jaggies. If you are unable, send me the RAW/original file and I'll try an edit (airkas1[at]airliners.net).
Crosswindphoto
Re: Screening help.
Fri May 03, 2019 5:53 pm
I tried this shot/angle, larger size and little sharpening this time.
https://imgproc.airliners.net/photos/ai ... 3fb3af2787
airkas1
Re: Screening help.
Fri May 03, 2019 6:27 pm
Looks good enough and better than the other photo.
Crosswindphoto
Re: Screening help.
Tue May 07, 2019 6:18 pm
https://imgproc.airliners.net/photos/ai ... c9aead3234
airkas1
Re: Screening help.
Tue May 07, 2019 6:26 pm
Looks really nice!
Crosswindphoto
Re: Screening help.
Tue May 07, 2019 6:56 pm
Is the framing ok? I keep thinking it’s too high in frame.
airkas1
Re: Screening help.
Tue May 07, 2019 9:14 pm
It’s spot on.
jelpee
Re: Screening help.
Tue May 07, 2019 11:11 pm
Looks very nice at full size!
Jehan
Crosswindphoto
Re: Screening help.
Tue May 21, 2019 4:23 pm
Pre-screen?
I don't have high hopes for the WestJet, but i'll try anyway.
https://imgproc.airliners.net/photos/ai ... 04489a3bf1
https://imgproc.airliners.net/photos/ai ... dd6dc45691
jelpee
Re: Screening help.
Tue May 21, 2019 11:42 pm
The Surveillance Dash 7 could use some brightening up.
Westjet looks very flat and soft. The overcast sky doesn't help this one.
Jehan
Crosswindphoto
Re: Screening help.
Wed May 22, 2019 10:18 am
I’ll pull Westjet and brighten the 7.
Thanks Jehan!
Crosswindphoto
Re: Screening help.
Sat Jun 01, 2019 9:15 pm
Cna I get a pre-screen on this photo please?
Bearing in mind that it is an extremely rare visit and this was the only shot I could get.
https://imgproc.airliners.net/photos/ai ... 6f76363169
Crosswindphoto
Re: Screening help.
Sat Jun 01, 2019 9:24 pm
Actually scratch that one, here is a better sized one:
https://imgproc.airliners.net/photos/ai ... a4375da518
fsx98
Re: Screening help.
Sun Jun 02, 2019 12:37 am
Looks okay to me, unless if anyone else finds something that warrants a rejection.
jelpee
Re: Screening help.
Sun Jun 02, 2019 12:45 am
Looks good!
Jehan
Crosswindphoto
Re: Screening help.
Sun Jun 02, 2019 10:07 am
Wow, I thought it would be hit for soft, I was wrong! Thanks guys!
Crosswindphoto
Re: Screening help.
Tue Jun 04, 2019 4:19 pm
I'm having some secnd thoughts on this shot, can I get a pre-screen on it please?
Tim
https://imgproc.airliners.net/photos/ai ... 272896881f
jelpee
Re: Screening help.
Tue Jun 04, 2019 6:13 pm
Not on my screening monitor, but I don't see anything that would cause any concerns.
Jehan
fsx98
Re: Screening help.
Fri Jun 07, 2019 6:19 pm
The Pilatus looks okay to me.
The Gulfstream could use a little CW rotation.
The Piper could use a little CCW rotation.
King Air looks fine to me.
Cargojet looks okay, though I may be concerned about the light glare; could wait for a screener to make a final decision.
Crosswindphoto
Re: Screening help.
Fri Jun 07, 2019 6:32 pm
Crosswindphoto
Re: Screening help.
Mon Jun 10, 2019 5:01 pm
Can I get a pre-screen on this one? Submitted it a few days ago but am having some second thoughts about it.
https://imgproc.airliners.net/photos/ai ... 2b02c63cc1
jelpee
Re: Screening help.
Mon Jun 10, 2019 11:42 pm
A very slight cyan cast visible in the whites of the fuselage, but not fatal IMO. I would accept it.
Jehan
wiggy
Re: Screening help.
Tue Jun 11, 2019 6:24 am
the otter looks a little soft but otherwise fine
Crosswindphoto
Re: Screening help.
Wed Jun 12, 2019 4:48 pm
Will this be hit for underexposed?
https://imgproc.airliners.net/photos/ai ... abe62977bb
JakTrax
Re: Screening help.
Wed Jun 12, 2019 6:00 pm
It's a situation where the light is so harsh you're at risk of getting both an underexposed and overexposed rejection. I may be being pessimistic but I can't see it making the cut...
airkas1
Re: Screening help.
Wed Jun 12, 2019 7:15 pm
The angle of the light is quite harsh, but I would give you a pass on it.
Crosswindphoto
Re: Screening help.
Wed Jun 12, 2019 7:32 pm
Thanks Kas and Karl!
Runway28L
Re: Screening help.
Wed Jun 12, 2019 8:48 pm
Not sure if it's just my monitor but the entire windowline looks oversharpened.
Lighting is harsh but I don't see how it's severe enough to warrant a rejection.
jelpee
Re: Screening help.
Wed Jun 12, 2019 10:11 pm
I agree with Kas...the light is a bit harsh, but acceptable for me as well.
Jehan
