Starfuryt
Screening Feeback
Mon Sep 10, 2018 6:59 pm
Hello everyone wanted to get some opinions on a couple of rejections as well as pictures still in screening.
https://i.imgur.com/kBTyhRv.jpg
Rejected for quality, Halos and Vignetting
I personally don't see halos and I've seen pictures with more vignetting accepted, I've tried to clean it up as much possible.
https://i.imgur.com/iQ6lrZE.jpg
rejected for overexposed, previously rejected for underexposed when it was slightly darker, and apparently blurry?
Possibly a resize issue, since at least full size image looks pretty crisp on my screen.
Still got these 3 waiting for screening that I'd love to get comments on
https://i.imgur.com/zfN6ljU.jpg
https://i.imgur.com/ktZmZ5o.jpg
https://i.imgur.com/RbyHqEP.jpg
Thanks in advance.
dutchspotter1
Re: Screening Feeback
Mon Sep 10, 2018 8:46 pm
N903AN: halo's visible near the back of the right engine. I don't see any obvious vignetting
PH-BHO: rather bright (especially the white parts) but still within limits on my screen. Does seem oversharped and halos visible near the main and nose gear
The other three: too much contrast, oversharped, halos. Some kind of HDR editing?
NO URLS in signature
Starfuryt
Mon Sep 10, 2018 9:10 pm
Thanks, seems i overdid a bit on the contrast, after getting a slew of low contrast rejections.
No HDR, just a lot of reducing highlights and increasing shadows.
Will rework them, thanks for the feedback
Starfuryt
Mon Sep 10, 2018 11:19 pm
reworked version of N903AN
https://i.imgur.com/vCDnJng.jpg
I don't see any noticable halos. I still do see some vignetting in the top corners, but I can't do much more about it w/o ruining the image I think.
Lowered sharpness a little as well, let me know if this is any better.
WN - Florida One
https://i.imgur.com/v2XYNzr.jpg
not entirely sure if I made this better or worse
fsx98
Mon Sep 10, 2018 11:53 pm
One way to fix vignetting issues for N903AN is to use the Lens Correction tool by going to Filter > Distort > Lens Correction (depends on which Photoshop version you use); under Vignetting, you can slide the "amount" value to the lighter setting (I personally set the value between 9 and 14, depending on which lens you use). I would apply the lens correction tool before starting my workflow of leveling the horizon, then cropping, and vice versa (for my preference).
Aviation junkie + computer expert!
Starfuryt
Tue Sep 11, 2018 12:00 am
it's already at max lens correction, i'm actually a bit surprised, though again the plane was quite a bit offcenter in the original, that's likely part of the issue
airkas1
Head Screener
Tue Sep 11, 2018 10:31 am
The reworked 903AN is overexposed. Try reducing highlights by -30/-40. If it gets dark, add a little bit of shadows/whites. Looks pretty nice otherwise.
FL1 looks a little cyan, but not too bad. Otherwise nice.
Starfuryt
Tue Sep 11, 2018 2:06 pm
Yea i didn't submit the 903AN yet since I wasn't happy with how it looked last night.
Starfuryt
Fri Sep 21, 2018 10:46 pm
I just had the following rejected for soft/blurry
https://i.imgur.com/VmMiuRO.jpg
I did use a bit less sharpening than usual, however for the life of me I can't figure out where there is any blurriness there.
Thanks in advance
dutchspotter1
Sat Sep 22, 2018 12:38 pm
Looks OK to me.
JakTrax
Mon Sep 24, 2018 8:09 pm
To me, it has a blurry feel in parts. Selective sharpening (particularly around the fuselage titles) may help but depends on the original. It's very difficult to determine if it's genuinely blurry from such a small file.
Karl
jelpee
Screener
Tue Sep 25, 2018 1:06 pm
Blurry for me--especially visible in the main titles.
Jehan
airkas1
Head Screener
Tue Sep 25, 2018 6:31 pm
Blurry for me as well.
Users browsing this forum: No registered users and 9 guests
