I'm not much of a screener, but from what I can tell, this photo has obvious signs of backlighting; perhaps a bit soft? I could be wrong with soft but I highly doubt that this photo would make it with the backlighting without a good motive in this angle.
Looks a lot better with the amount of light in this angle! Not sure if there are any other issues with this photo (again, I am not good of a screener), but it looks passable, in my opinion!
Hi, the photo is affected by heathaze, you can see it clearly looking at the blue/white line on the fuselage. I would never work further with a photo like this and try again in better circumstances.
Looks soft, heat hazed, and flat to me. Would probably be much better at 1024 or 1200.
As I said earlier, it may have a shot at a smaller size. It is very clearly heat hazed, I am not sure if 1024 will mask that well enough, but no way it will work at 1600
The underside and aft section is blurry and likely the image is indeed affected by haze. The titles also look iffy, (BA titles are always a pain). All in all I think the image is just too marginal.
