zachary165
Pre Screening: Cessna 172R cockpit
Mon May 22, 2017 1:25 am
Hi All, I just got back from my first solo Cross Country flight and took this photo of the cockpit on the ground. The sun was straight on the nose, causing the overexposure of the outside. I wanted a second opinion on the photo.
"Keep true to the dreams of thy youth." - Schiller
airkas1
Head Screener
Re: Pre Screening: Cessna 172R cockpit
Mon May 22, 2017 10:45 am
Unfortunately I think it will get done for overexposed. Congrats on your first X-country though!
jelpee
Screener
Mon May 22, 2017 9:31 pm
Hey Zach, Try setting up your camera on manual exposure and expose for the outside. Ordinarily, this will render the inside dark. Use the pop-up flash or better yet a shoe mounted flash that has TTL metering and it should illuminate the inside nicely resulting in an image that looks well balanced.
Congratulations from me as well on the X-Country solo!
Jehan
zachary165
Tue May 23, 2017 5:05 pm
Thanks for the tips. I'll try again with my next flight and try with that photo
notaxonrotax
Thu May 25, 2017 12:28 pm
Congrats, Captain!
Here`s a simple trick, try covering the windshield with a cover or some kind of blanket. Alternatively, park the bird in the hangar. It will make a flight deck shot so much easier, without the bright light coming in.
Granted, my newspapers don´t look too fancy but you get the idea in the following example:
http://www.airliners.net/photo/Untitled ... Yudg%3D%3D
Perhaps another obvious one: flash up the instruments in the relative "dark" as described above; this makes a cockpit so much more interesting.
Good luck!
No Tax On Rotax
For anybody that happens to be wondering:"yes, owning your own aircraft is a 100% worth it!"
Users browsing this forum: No registered users and 9 guests
