MilanNN
Post screening info.
Fri Dec 30, 2016 11:02 am
Good day!
I've got some rejected photos for bad info, could you help me.
http://www.airliners.net/user/photo-cor ... to/4133185
http://www.airliners.net/user/photo-cor ... to/4133181
With best regards.
Roman.
airkas1
Head Screener
Re: Post screening info.
Fri Dec 30, 2016 11:51 am
Hi Roman,
You've linked to the photo corner. Following those links leads us to our own photo corner.
I was able to get the links through the screening log:
ID4133185: http://cdn-www.airliners.net/photos/air ... bd3c612ab1
ID4133181: http://cdn-www.airliners.net/photos/air ... 65eb21b583
But what I can't see is the info you provided on the upload. Could you please advise?
MilanNN
Fri Dec 30, 2016 12:11 pm
Info for first Version: 06
Generic Type: Agat
Basic Type: Agat
For second Version: 01
Generic Type: Agat
Basic Type: Agat
airkas1
Head Screener
Fri Dec 30, 2016 12:44 pm
Ehhhh..
I'm not familiar with that type of aircraft, but the info should be something like below.
First photo:
- Airline: Untitled
- Basic Type: Agat
- Generic Type: Agat XXXXX
- Version: Agat XXXXX
- Correct Reg.: 06
- Correct MSN (if known, otherwise leave empty)
- Correct date
- Correct location
Second photo:
- Airline: Untitled
- Basic Type: Agat
- Correct Reg.: 01
- Correct date
- Correct location
- I assume the "01" and "06" are the registrations.
- I don't know the generic type & version, hence the "XXXXX".
If AGAT 01 and AGAT 06 are the actual version, then you need to:
- Select "No" at the 'aircraft manufacturer filter enabled'.
- Select "Agat" as generic type.
- Select "Agat 01" or "Agat 06".
Perhaps a screenshot of the info that you uploaded it with will make it more clear.
MilanNN
Fri Dec 30, 2016 1:10 pm
Thanks for your help!
I hope now all will be OK.
