Jay124
Fliters
Sun Apr 22, 2018 10:36 pm
Wondering what kind of lens filters are the best for reducing heat haze?
Jason
Kaphias
Re: Fliters
Sun Apr 22, 2018 11:15 pm
None - shoot in colder weather (or more accurately, less temperature differential between the surface of the tarmac and the air).
Jay124
Re: Fliters
Mon Apr 23, 2018 1:20 am
That's what I was afraid of. It was 68 today but real bright sun all day.
cpd
Re: Fliters
Mon Apr 23, 2018 8:12 pm
Jason
I've had some success using an ND filter (darkening) and using a slower shutter speed.
But if conditions are very hot/hazy then nothing will help.
vikkyvik
Re: Fliters
Mon Apr 23, 2018 10:23 pm
I imagine all that would do is "average out" the heat haze.
So on a heat-hazed straight edge, instead of lots of small sharp heat-haze wiggles, you'll get a straighter, but much softer, line.
Is that correct? Never really tried it myself.
cpd
Re: Fliters
Tue Apr 24, 2018 2:43 am
It sort of does. It's not perfect, and you do have to use a slower shutter speed, but you might get a photo that otherwise would be ruined by heat haze. If it is very hazy, then it's useless. But lighter heat haze can be offset by that trick.
The idea of the ND filter is to darken things, slow down the shutter speed and still maintain a reasonable aperture (ie, not F/16). If your shutter speed is too high, the heat haze looks very obvious.
Jay124
Re: Fliters
Wed Apr 25, 2018 12:38 am
Thanks, the other day is was clear but really sunny. I think it was coming off the runway.
But I am going to try shooting slower shutter to see
cpd
Re: Fliters
Wed Apr 25, 2018 2:28 am
Unless you are really close to the runway or the plane (or the plane is going really fast) then you don't need to use the shutter speeds I typically see being used, 1/1250sec or 1/1000sec, those are way too high for broad daylight. 1/320sec or even 1/125sec is enough using todays stabilised lenses and correct shooting technique.
Users browsing this forum: No registered users and 16 guests
