Catalin81
Reject photos
Sat May 20, 2017 4:58 pm
Why this picture no recive reject for double, is a same day, same angle, same side, all motive for rejected.
https://www.airliners.net/photo/Luxembou ... /4378745/L
https://www.airliners.net/photo/Luxembou ... /4378739/L
RolandRat
Re: Reject photos
Sat May 20, 2017 5:22 pm
One's taking off and one's landing, totally different photo's
Catalin81
Re: Reject photos
Sat May 20, 2017 5:32 pm
No, is not true, is same, same day, same date, same angle, same side. Is acceptable, two different picture in a same day, but need angle need to be more 90 gree, or ohther side, here is same. I want to admin remouve one picture, last added on the site. Thanks !!
bombayduck
Re: Reject photos
Sat May 20, 2017 5:46 pm
Demand all you like, I doubt very much if they will do this remove one of the photo's. As they are both different phases, one landing and the other is ready for departure.
bombayduck
Re: Reject photos
Sat May 20, 2017 5:52 pm
Should have put one on flypast the other is taking off, both are different phases.
RolandRat
Re: Reject photos
Sat May 20, 2017 6:43 pm
Agree BombayDuck, or even one is on the ground the other is in the air !!!
either way their different....
airkas1
Re: Reject photos
Sat May 20, 2017 11:30 pm
Quote from the Acceptance Guide:
For an accepted or submitted image that is nearly head or tail-on, we will generally also allow a side-on from either or both sides that is 90 degrees or more different viewing angle from the other image(s). This can apply to the same sequence (i.e. taxi, take off, landing or static display).
And if that's not good enough, then I refer you to this section:
We reserve the right to add more than one image of special or unique events, even if those images might otherwise be considered double. It is at our discretion what constitutes a special event
So no, neither photo will be removed.
Users browsing this forum: No registered users and 22 guests
