IFlyVeryLittle
Too far?
Fri Mar 15, 2019 7:38 pm
Have we gone so far off the track that we're designing airframe/engine combinations that simply don't fly right without complicated sensors and avionics designed to counteract what aerodynamics insists on doing? I recall the F-117 was built so unstable it required a sophisticated fly-by-wire interface to keep it from tumbling out of the sky. But that's a different kettle of fish. What do we really gain by building jets that cost billions to develop, save marginal percentages in fuel consumption and still require HAL to keep flying? Or did I miss the point entirely?
unimproved
Re: Too far?
Fri Mar 15, 2019 8:22 pm
Military aircraft are designed to be unstable since a plane that only wants to fly straight ahead would be at a huge disadvantage in aerial fights.
Nobody designs a passenger aircraft that way, but certification costs for a new design can drive them to keep on stretching. The basic 737 fuselage has grown more than 10m from the -100 to the -max8.
stratclub
Re: Too far?
Fri Mar 15, 2019 8:29 pm
Same reason modern cars have gone digital. Just engineers taking advantage of newer technologies. Is digital integration a good thing? Mostly yes and occasionally no.
With the 787 as one example, it gets aerodynamic efficiencies that were imposable with old analog control systems.
WIederling
Re: Too far?
Fri Mar 15, 2019 10:30 pm
The solution for military craft is an ejection seat.
Transport class aircraft don't have ejection seats.
Neither for crew nor for selfloading payload.
Murphy is an optimist
stratclub
Re: Too far?
Fri Mar 15, 2019 10:54 pm
An ejection seat has nothing to do with an aircrafts stability. Fighters are inherently unstable because it makes them more maneuverable. If a pilot were to always fly within the aircrafts flight envelope, never botched a take off or landing and was never shot down, a fighter would not need an ejection seat.
Civilian air craft except for possibly aerobatic aircraft are designed to be inherently stable because they don't need to be as maneuverable as a fighter. The design intent with civilian aircraft is that if it is trimmed correctly, when you let go off the controls it will return to straight and level flight.
747Whale
Re: Too far?
Sat Mar 16, 2019 3:51 am
No, because that's not remotely the case.
It is, which makes it irrelevant.
We could go back to hang gliders, but we can do better.
WIederling
Re: Too far?
Sat Mar 16, 2019 8:25 am
You are pointing to the wrong shell.
stratclub
Re: Too far?
Sat Mar 16, 2019 5:40 pm
I was commenting on your misunderstanding in this post of yours.
My unedited post that contains my complete thoughts.
I have no clue what that means.
WPvsMW
Re: Too far?
Sat Mar 16, 2019 7:07 pm
The shell game... under which of 3 shells is the marble?
WIederling
Re: Too far?
Sat Mar 16, 2019 9:31 pm
In the case of the astable FBW wrapper stability added military craft your safety fall back ( on loosing the stability augmentation or some other indispensable functionality ) is the ejection seat: Saves the ( assumed to be ) most valuable part of the vehicle.
On a transport class airplane you don't have that option fall back from losing stability augmentation must a basically stable craft.
engines out? the plane must provide for basic operability. you must be able to land ( if you find some place suitable.)
stratclub
Re: Too far?
Sun Mar 17, 2019 4:06 am
Oh O.K. I guess were not going to get you to post anything that makes any sense.
WIederling
Re: Too far?
Sun Mar 17, 2019 8:46 am
I try to fit in. :-)))))))))
Users browsing this forum: Bing [Bot] and 24 guests
