Balerit
B787 cockpit windscreen issues
Sun Jan 20, 2019 3:57 pm
While browsing AeroInside, I noticed that the B787 has quite a few cockpit windscreen issues, has anyone got any more info on this.
Balerit
Re: B787 cockpit windscreen issues
Mon Jan 21, 2019 4:29 pm
Is it a case of these new plastic fuselages flexing too much?
stratclub
Tue Jan 22, 2019 1:42 am
What "issues" are you referring to? Can you link an article or something?
airnorth
Tue Jan 22, 2019 9:28 pm
I haven't read about any windscreen issues?
Since when is the fuselage plastic? The fuselage is primarily carbon fiber
see link:
https://www.compositesworld.com/article ... ercial-jet
This is direct from the source linked:
Spirit was chosen to manufacture the 787’s entire forward fuselage — called Section 41 — which includes the cockpit, cockpit windscreens, two doors, nine passenger windows and all of the avionics, cockpit seating and wiring. Measuring 6.2m in diameter and 12.8m long, Section 41 is, arguably, the most complex of the plane’s fuselage sections.
Hard to imagine there could be any flex at all in a one piece unit.
Stitch
Tue Jan 22, 2019 10:53 pm
In the first few years of service, cracks in the uppermost layer (of five) were occurring at a rate higher than expected. I'm not sure what the final "fix" was between Boeing and PPG (the supplier), but I recall it was addressed.
Balerit
Wed Jan 23, 2019 2:24 pm
see link:
Plastic is a tongue in cheek term us old maintenance engineers call the latest aircraft since epoxy is the stuff used to hold it all together. Airbus use a different technique to build their fuselages and I don't think they've had any issues with cracking windshields, hence my query. Looks like it was a window issue.
Balerit
Wed Jan 23, 2019 2:31 pm
Refer to this page and scroll down to see many instances of cracked windshields:
https://www.aeroinside.com/incidents/type/b788/boeing-787-8-dreamliner
Kindanew
Wed Jan 23, 2019 11:09 pm
see link:
The A350 cockpit section is still metal for birdstrike reasons.
Users browsing this forum: No registered users and 28 guests
