blacksoviet
How does LATAM fly the 787 between AKL and SCL?
Fri Jan 11, 2019 10:37 pm
Don't ETOPS regulations require a quad-jet on this route? Is there a island where they can land a 787 in an emergency?
Apprentice
Re: How does LATAM fly the 787 between AKL and SCL?
Sat Jan 12, 2019 1:45 am
B787 will be certified for 330 minutes. (5 1/2hours).
Not been a pilot, my calculation give me that plane will be always between 51/2 hours of Auckland or Santiago, been distance between them
Around 11:00 (direct flight)
As I understand, mayor concern is Jet lag. But, with higher humidity and cabin pressure, expectation are...
“An4; IL18; IL6; Tu5; D10; MD11; MD83; B32; B34: B37; B744; B748; B752; B763; B772; B773; B77W; A320; A332; A333; A342; A343.
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
“CUBANA” 90 years Flying”
Stitch
Sat Jan 12, 2019 1:59 am
The 787 has been certified for ETOPS-330 since 2014 and using Great Circle Mapper it looks like they can fly a direct routing. The FAA has reduced ETOPS for the Trent 1000 family in certain situations, but those might not reply to a Chilean-registered airframe or if they do, LATAM might be using frames powered by RR engines not under the FAA restrictions.
blacksoviet
Sat Jan 12, 2019 2:14 am
Did the Lan Chile 767-200ERs have enough range to fly from SCL to AKL?
Stitch
Sat Jan 12, 2019 4:20 am
Perhaps if they were empty. :)
I think the 767-200ER is limited to ETOPS-180/207 and that means it would need to take a far more northerly track to stay within range of alternates and that would significantly increase the total flight time / distance to the point it would certainly impact available payload due to the need to load more fuel.
Apprentice
Sat Jan 12, 2019 11:49 am
Are We talking about a B767-200 or B787?
Stitch
Sat Jan 12, 2019 5:32 pm
Both.
The 767-200ER and 787-9 have the range to make the trip with their design payloads flying a direct path, however ETOPS routing considerations allow the 787 to fly direct under ETOPS-330 while requiring the 767 to fly farther north as there are no available alternates within ETOPS-180/207(/240) minutes to allow a direct path.
Flyingdevil737
Sat Jan 12, 2019 10:16 pm
They also fly the 789 between SCL and MEL, and that’s even longer.
The thunder from Down Under
Users browsing this forum: No registered users and 21 guests
