sherman2000
Fuel Flow Meter
Mon Oct 29, 2018 1:29 am
Hi, what is the most common type of fuel flow meter used in commercial aircrafts?
Tristarsteve
Re: Fuel Flow Meter
Mon Oct 29, 2018 11:59 am
Well usually just figures on an LCD screen on the engine display showing the fuel flow in kgs/hr (or lbs/hr in the USA)
There is no separate meter.
Re: Fuel Flow Meter
Mon Oct 29, 2018 12:13 pm
I think he means the hardware itself. As in the gadget that measures fuel flow.
fr8mech
Re: Fuel Flow Meter
Mon Oct 29, 2018 2:12 pm
Well, on a CF6, as installed on the B767, the transmitter uses the angular momentum of a rotor to measure mass flow rate. In other words, the flowing fuel spins a rotor. The rotor RPM is counted, the software in the EICAS computer converts the RPM to a flow rate and reports it to the crew, via EICAS.
I suspect most modern aircraft are similar.
DL_Mech
Re: Fuel Flow Meter
Mon Oct 29, 2018 9:01 pm
The Ametek 8TJ167 is a popular fuel flow transmitter used on commercial airliners.
http://www.ameteksfms.com/products/fuel-flow-transmitters
This plane is built to withstand anything... except a bad pilot.
sherman2000
Re: Fuel Flow Meter
Sun Nov 04, 2018 10:27 am
thanks for all the replies!
Apprentice
Re: Fuel Flow Meter
Sat Nov 10, 2018 10:41 pm
Just to add that flowméter are pared with densitometer, as fuel is measured in weights units (KG/ LBs) and rotor measure volume (Ltd/ Galons)..
Some have a density meter for all Rotors, others, one dens to one rotor.
“An4; IL18; IL6; Tu5; D10; MD11; MD83; B32; B34: B37; B744; B748; B752; B763; B772; B773; B77W; A320; A332; A333; A342; A343.
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
“CUBANA” 90 years Flying”
Users browsing this forum: No registered users and 27 guests
