MSPNWA
Re: 787 vs A350 range
Tue Nov 06, 2018 4:24 pm
zeke wrote:
Several times on this thread it has been stated that UA has published 789 furn burn data, I have asked for the reference time and again.
Why are people so afraid of making the source known and open to scrutiny ?
BTW I did not see significant fuel burn differences between numbers I have put on here for the A350 and flight plans, just like thepinkmachine did earlier. So there seems to be two schools of thought, those who fly imaginary planes on a flat earth, and those who do it in real life.
"QF9 FAST FACTS
229 passengers and crew
253.5 tonnes takeoff weight (half a tonne under MTOW)
100.6 tonnes of fuel
Approximate flight time of 17 hours 02 minutes
Departing Perth’s runway 21 at 1900 local time Saturday March 24
Landed London Heathrow at 0502 local time Sunday March 25"
from http://australianaviation.com.au/2018/0 ... in-london/
5883 kg/hr average
SQ22 101.4 tonnes, 17 hrs 22 minutes = 5838 kg/hr
https://twitter.com/FATIIIAviation/stat ... 1213747200
Do you realize you just gave evidence that, on average, the 789 should have a noticeable fuel burn advantage? You just compared apples to oranges, and the 789 still matched the A359.
QF9 is on the very edge of the 787's range (fuel burn disadvantage)
SQ22 wasn't at MTW, a fuel burn advantage
SQ22 is going eastbound and had very favorable winds that day (fuel burn advantage)
SQ22 is the ULR, which has a very thin passenger configuration (fuel burn advantage). QF9's config isn't dense either, but it's much more in line with common configs.
What we have is two data points. That's it. Two data points that are not a valid comparison for a conclusion, unless you want a biased result of course. We need a consolidation of dozens and hundreds of data points to make an accurate conclusion. To conclude that the A359 and 789 have near identical fuel burn rates goes against physics and economics. It means that Boeing did poor a job engineering the 789, and it also means that dozens of airlines are buying this mistake even with its significantly inferior economics. So do I trust you and your data points? Or do I trust science, Boeing, and the airlines? I think you know where I'm putting my trust in.
Tue Nov 06, 2018 4:53 pm
thepinkmachine wrote:
Zeke, small correction regarding QF9. According to my calculations, the Trip Fuel for this flight should be around ~95 tonnes, So average fuel flow would be around 5588 kg/hr.
100.6 tonnes quoted earlier is most likely the Block Fuel and that’s approximately a tonne short of the maximum tank capacity (unless QF birds have bigger than standard tanks, which I doubt).
The article suggested they were departing with full tanks and half a tonne below MTOW, Qantas do not use destination alternates most of the time, they have all engine diversion points before the destination.
I had a look at the OLB for a 273 tonne takeoff and flight time of 17:22. On a ISA day they will be a burn of 97.9 and still air distance of 8235 nm. For ISA+14 with the same weight and time, the still air distance covered is 8500nm (warmer day down lower lower with a better TAS) and a burn of 102.1 tonnes. I think what we are seeing on the SQ flight in the effects of taking off in the tropics with high ISA deviations.
The 787 data we have been looking at I assume is ISA ?
Having said that, comparing average fuel flow quoted by some anonymous United Pilots (or whoever) against official FCOM flight planning data is pretty meaningless. Why did we even allow to get dragged into this? :banghead:
Yeah have to agree.
kengo wrote:
Zeke, is that a fair comparison? One is flying westerly and the other is flying easterly with different wind conditions. Also, QF9 and SQ22 has a seat difference of around 60 seats, so I am not so sure if it is a fair comparison between the two types flying in a opposing routes. Would be interesting to see the return flight fuel burns for the two.
It was over a fairly similar endurance, as I just mentioned above if anything the A350 is disadvantaged by taking off in the tropics where the atmosphere is warmer and the tropopause is much higher. That Twitter photo indicated that the A350 had ample fuel to go to New York and then divert to Boston and then even to hold a little more. They were very conservative to have that much additional fuel onboard which could have translated to 50 more passengers if they swapped 5 tonnes of fuel weight for passengers, with the same takeoff weight. The aircraft took off 7 tonnes below MTOW so it still had additional margin for around 5 tonnes more payload.
I will give myself a stern talking to for not taking into account the effect of relativity and time dilation between two aircraft travelling east vs west. Didn't you know the earth rotates at 15 degrees per hour, which is 900 nm per hour. There is an 8 hour time change between LHR and PER, that means the 787 didn't really need to fly all that far as in the 17 hours the earth rotated towards them ?
:spin: :spit:
I have actually presented lots of data points from the various FCOMs which people are dismissing.
MSPNWA
Tue Nov 06, 2018 5:30 pm
tommy1808 wrote:
The comparison is via flight time, not distance, so wind doesn't play. The SQ flight is still longer, despite the A359 being a touch faster.
Wind absolutely makes a difference. It might be the most significant difference that doesn't allow these two flights to be properly compared.
So that's what you're going to resort to when shown to be incorrect...
WIederling
Tue Nov 06, 2018 5:34 pm
Could you please expand on your position ?
Murphy is an optimist
MSPNWA
Tue Nov 06, 2018 5:54 pm
I'll explain it in a scenario. Let's say you have a long-haul flight that happens to have very favorable weather conditions on the day of departure (which the inaugural SQ22 did). Under an average air speed, you'll arrive early, significantly earlier than necessary (SQ22 landed a half-hour early). What do you do? Power through it? Or do you use the wind and milk it, maximizing efficiency?
gloom
Tue Nov 06, 2018 6:01 pm
Ever noticed they compared two flights by flight time, not the similarity of the ranges? Or the fuel flow is by hour, not the mile?
LOL. What a perfect way to make oneself fool.
To all the believers - I know you know it's 10% or more. It's just those stupid people who don't know how to read FCOM, or maybe even forget those 8T in case of one or the others. If you do, please, let the aviators do their job, and don't spoil anyone else with your beliefs.
Thanks.
Adam
WIederling
Tue Nov 06, 2018 6:11 pm
If you fly coffin corner you don't have all that much leeway, do you?
( independent of people here looking at flight time and not at geo distance traveled.)
LH707330
Tue Nov 06, 2018 9:25 pm
I don't think the modern planes are that close to the coffin corner, so I don't think that matters as much. Regarding the winds, that's often overstated, see the section "effects of wind" here: http://code7700.com/aero_range_performance.htm
Also, I'd be curious to see the 343 in the chart, was there ever a v2 with that in it?
RJMAZ
Tue Nov 06, 2018 9:43 pm
tommy1808 wrote:
on a ~2% shorter flight,
The fuel burn per hour takes into account flight duration. The comparison is valid.
tommy1808 wrote:
with ~5T less fuel remaining
The lighter aircraft with less fuel burn per hour will land with less fuel. The comparison is still valid.
tommy1808 wrote:
and probably 2 tons or so less furniture in the cabin
Less furniture weight but much more passenger weight. The 787-9 flights carried slightly more payload once you deduct fuel and empty weight. The payload plus remaining fuel upon landing are nearly identical between two flights.
The two flights are absolutely perfect examples to compare ultra long haul fuel burn of both types. They provide the real data points at the far right of a range vs fuel burn graph.
The advantage to the 787 only increases for the 787 as range becomes shorter. Once you start taking off well below maximum takeoff weight on a short sector the cruising altitudes are the same. The empty weight starts to play a big part on the climb fuel burn which is a bigger percentage of the flight duration as the flight length becomes shorter.
tommy1808 wrote:
which is a far cry from "10% more fuel burn for the same payload/range". It would appear you have proven yourself wrong once more...
If you check my original post. I have highlighted the important part.
RJMAZ wrote:
The 787-9 when flying the same payload the same distance burns nearly 10% less fuel on the trip. That is the 787-9's advantage.
So my original post is still correct. It nearly hits a 10% advantage on short sectors. If I was forced to put an exact number on it using my small data set of real flight data I wouod say the fuel burn advantage goes to about 8.5% on a short sector.
On the the majority of airports once you add fees the lighter frame makes the trip cost advantage exceed 10% on trips below about 2000nm. This excludes aircraft purchase prices and staff cost.
smaragdz
Tue Nov 06, 2018 9:58 pm
“I would say” versus an actual peer-reviewed technical analysis from FCOM data, I wonder which is credible!
RJMAZ
Wed Nov 07, 2018 2:55 am
Peer reviewed? Are you joking? The graph even showed the A330 flying WAY further than it could. It was clearly rushed. The large 787-8 and 787-9 difference also makes no sense.
I just did a search on your username. You have a large number of Airbus posts all positive. Just accept your favourite plane burns 4.5+% more fuel than the 787-9. I accept that the A350-900 can fly much further. In the "UA cancelled LAX-SIN" thread I was very positive towards Airbus. Unlike you I am not a fanboy.
Here is my quote from the UA thread recognising the A350-900 dominance on this route.
RJMAZ wrote:
This is nothing more than UA realising the 787 can not fly LAX-SIN. It was a good test for the aircraft but it was optimistic to assume it could make a profit.
People need to realise that payload range curves drop off a cliff at a certin point. As Jayunited pointed out the blocked seats in winter is significant. That extra 300nm makes a very big difference. Both SFO and LAX routes the aircraft will take off fully fueled, the only way to allow the aircraft to fly further is to significantly reduce payload.
The normal 278T A350-900 would do the LAX-SIN route easily with full passenger loads in the middle of winter. It wouldnt even need the ULR model. The A350-900 payload range cliff starts to drop off about 300-400nm after the 787-9.
Singapore will start SIN-LAX later this year with the A350. I expect UA will also start flying the route again when they get their A350's.
I would expect UA to use the A350's on all routes over 7000nm. The A350 allows for nearly 50% more payload when compared to the 787-9 with a penalty of less than 10% extra fuel burn on routes above 7000nm.
We've already had three people here confirm a 250kg^hr or 4.5% fuel burn difference. So lets call that peer reviewed.
Wed Nov 07, 2018 6:13 am
What you do not realise is I sent my spreadsheets to the thepinkmachine and oldaeroguy by PM. I didn’t publish that data in this thread, just the graphs from the resulting information.
The manufacturers data includes data points beyond MTOW which is why the A330 data is like that. I since added dynamic MTOW so that those points are not displayed.
The A330 displayed on the graph is the A330-200 which has some legs on it. I have since added the A330-300.
I have updated the graphs to include the A330-200/300, A340-300, 777-200ER/LR, and 777-300ER from 1000 nm to 7000 nm.
You have yet to show any data to support your claims, nor have you apologised for your previous insults directed at me.
sciing
Wed Nov 07, 2018 6:41 am
You might be right but can you explain me 2 things?
Why don‘t they fly heavy loaded ULHs near MTOW on max altitude right from the start if coffin corner is far away? Why is SQ21 flying sometimes almost 1700km longer than GC and goes eastbound if winds are overestimated?
Whatsaptudo
Wed Nov 07, 2018 12:17 pm
For discussion. Tonight’s QF9 has a flight time of 16:54 with a flight fuel burn of exactly 91.0. Take off weight is 249.3/ 254.0, and it arrives with 4.5T of fuel. Carrying 210 POB so 26 empty seats all of which are in economy.
Incidentally that arrival fuel gives the QF9 and Endurance over the destination of 1:10 with a landing weight of 158.1T. I’m not a mathamatician so make of those figures what you will.
MoKa777
Wed Nov 07, 2018 12:19 pm
Will it be possible to add the A350-1000 to the graph with what is known about its performance so far..?
Never be proud. Always be grateful.
gloom
Wed Nov 07, 2018 1:40 pm
Since CX is the user of A350-1000, and probably that gives Zeke an access - I'd say most likely. But it's Zeke's to confirm. I certainly would look very much into that, especially with range/payload at the same levels. How much does it cost to have "extra seats in plane", when they're not used to the same extent? 359 vs 35J would answer that quite well.
Adam
thepinkmachine
Wed Nov 07, 2018 4:08 pm
Hi Whatsaptudo,
Thanks for input. It’s great to have insight into QF9 data. Your figures are pretty consistent with FCOM calculations.
If you have access to the flightplan, may I know the following:
- What is the ESAD (equivalent still air distance) for tonight’s QF9.
- What is their contingency fuel? According to european rules it should be at least 3%, or approximately 2700 kg on top of of the fuel required - unless they were using RCF procedure, or some such...
Whatsaptudo
Wed Nov 07, 2018 8:23 pm
There is No ESAD on the plan, but the Contingency fuel is 1.2. It’s 10% up to a maximum of 1.2, but that is considered to be burnt in the Min fuel required over destination. The actual Min required fuel is 95.1, but the “build up” to get them there with 70 minutes is 95.8. Final reserve is 1.9, with the approach and Arrival allowance. Min required over destination is 2.6 but QF policy is a minimum of 70 minutes hence the 4.5. The distance on the plan is 8082nm with an average overall wind of 242/20kts with an average component of 7 knots of headwind. That’s an average of the entire 17hrs
In QF we don’t carry alternates if the weather doesn’t require it, but as you can see, contrary to popular belief, we never arrive anywhere with min fuel.
Whatsaptudo
Wed Nov 07, 2018 8:34 pm
By comparison the QF10 is 15:56 for 84.8. 4.7 over destination. Distance 7957 with an average overall component of 16kts tailwind.
ZFW of the QF9 153.8
ZFW of the QF10 157.0
Both carrying about the same Pax load but the QF10 has about 3t more in the holds.
LH707330
Thu Nov 08, 2018 3:28 am
1. It's less efficient to fly higher at the higher weights, there's always an optimum altitude, with weight as one of the factors
2. I worded that poorly. Wind does play a role, hence the routing changes, but the answer to the question "Should I fly faster or slower in a head/tailwind to save fuel?" is usually "It doesn't make much of a difference." Drag goes up pretty steeply after the optimum cruising mach for a lot of these transonic designs, so pushing up the speed to spend less time in a headwind usually doesn't yield much result. Now, in an aircraft not limited by sonic effects, that may be a different story. Regarding flying slower in a tailwind to save fuel, it sometimes brings a slight benefit, but not as much as many people think. The link I posted provides examples to back that up.
Thu Nov 08, 2018 4:11 am
As I explained up in the thread the A350 data is all digital, there is no performance books for it, to get the data out I have to use the onboard performance software. The version I have is the old database we had before the first aircraft arrived when I did my course, the -1000 database came later. For me to do the -1000 data I would need to update the database which I am in no hurry to do. I could do it at work, however when at work they would want me to be doing work.
People will not like it if I use the later database with the better performance numbers as I am already being accused of cheating !!!
The NAM = NGM*(GS-wind)/GS=8200 nm (where GS=8082/16.9)
We operate under EUOPS as well, there is no requirement under EUOPS or the ICAO Flight Planning and Fuel Management (FPFM) Manual to carry 3%, we use probability based contingency fuel. I mentioned further up in the thread how they carry a diversion point all engines prior to the destination.
I assume that is 70 minutes at 1500 ft ? is that a holding rate or straight and level rate (hold rate is normally around 3% higher on everything I have flown for the turns) ?
Whatsaptudo
Thu Nov 08, 2018 5:06 am
Based on holding at 1500’
Thu Nov 08, 2018 7:09 am
Does the plan also include the average ISA deviation as it has the average wind ?
Whatsaptudo
Thu Nov 08, 2018 7:31 am
It may have, but it’s gone now. It looks like it burns less than 5.4/h in either direction at almost MTOW. More than 400kg/h less than stated earlier.
armchairceonr1
Thu Nov 08, 2018 7:37 am
Yes but around 15 tonnes less payload?
armchairceonr1
Thu Nov 08, 2018 7:42 am
Have you released that updated chart here?
Whatsaptudo
Thu Nov 08, 2018 7:49 am
Terrific. Thank god we got that settled.
Do we need a percentage of fuel burn delta vs a percentage of payload delta? Maybe that would satisfy somebody.
I’ve given you the actual numbers to dispel the incorrect info given earlier in this thread. Make of the data what you will, but personally I could care less.
armchairceonr1
Thu Nov 08, 2018 8:04 am
Sorry, I didn't realize that you mean zeke's post about QF9/10, I thought that you mean comparison made with 40 tonnes payload.
tommy1808
Thu Nov 08, 2018 8:17 am
So.. you honestly think flying 17 hours westward and 17 hours westward at 5t/hr yield different total fuel burn? :)
The only difference wind makes in both scenarios is how much ground you cover in those 17 hours.
Best regards
Thomas
This Singature is a safe space......
tommy1808
Thu Nov 08, 2018 8:23 am
Shorter can refer to time and distance, in this case it is time.
The 8% or so lighter aircraft arrives with half the fuel remaining? The difference is because of different flight planning at both airlines, not because the 789 burns 1 or 2% less fuel.
Less furniture weight but much more passenger weight. The 787-9 flights carried slightly more payload once you deduct fuel and empty weight. The payload plus remaining fuel upon landing are nearly identical between two flights. [/quote]
That was my point. Glad you confirm that the A350 took the same payload over a longer flight with neglectable, 2 to 2.5%, more fuel burn, despite load being light, favouring the smaller bird, and the A359 being the heavier frame.
Best regards
Thomas
RJMAZ
Thu Nov 08, 2018 9:18 am
Thanks for the numbers!
QF10 burnt 84.8T of fuel over 15:56 = 5322kg^hr
QF9 burnt 91t of fuel over 16:54 = 5384kg^hr
SQ22 burnt 101.4T of fuel over 17:22 = 5838 kg^hr
Ladies and gentlemen that is a 9-9.5% fuel burn advantage to the 787-9 :praise:
Do we have any more samples from the Singapore flights?
thepinkmachine
Thu Nov 08, 2018 10:45 am
Thanks for detailed info. I just wanted to crosscheck your data with FCOM. Unsurprisingly, they match pretty closely… Out of curiosity, what Cost Index do you guys use for this flight?
If you have it calculated in the OFP, we'd appreciate that info too.
I stand corrected. EU-OPS allows 4 methods of calcuating contingency fuel: 5%, 3%, 20 min and statistical analysis. Having said that, none of the companies I worked for ever ventured beyond the good 'ole standard 5%, hence on most flights we have an extra of ~2 tons over destination at our disposal… Hence the usual 7-8 tons of fuel remaining at landing. Because of that I hardly ever bother to take any extra fuel - as there is a lot of 'fat' built into the OFP figures...
How does the statistical method work? Does it cover for 95% worst case scenario, 99%? Is it calculated on by route basis, or for the whole fleet?
It makes no sense to fly at max altitude, since the optimum altitude (yielding the highest mileage per unit of fuel used) is normally 3-4000 ft below the 'buffet limiting' altitude, or 'coffin corner'.
Furthermore, max altitude may be limited by aerodynamics, or by available thrust - so that your jet will stop climbing before it ever gets to the 'coffin corner'.
According to the FCOM data, the 789 max altitude is generally 'buffet limited', whereas the 788 is 'thrust limited', but not by far - so they will both fly close to the 'coffin corner' if you, for some reason, climb above the optimum altitude.
OTOH, the A333 I flew before was 'thrust limited' by a wide margin of ~2-3000 feet. You just ran out of available thrust waay below the 'corner'.
Thu Nov 08, 2018 11:44 am
I was only going by what was posted on Oz Aviation. From the numbers you have presented the landing weight for QF9 was 158.5 which included the 4.7 tonnes of additional fuel on arrival, the FCOM data we have shows the burn at that landing weight and 8200 nm should be 89.77 tonnes (our numbers were based upon LRC). Up in the thread we were working on a 40 tonne payload, and landing with 8 tonnes in the tanks, which gave a landing weight of 176.85 tonnes. FCOM data says it just does not have the performance to fly PER-LHR with that payload.
Working backwards from your ZFW (153.8) minus the payload (210 pax approx 21 tonnes) gives a DOW of 132.8 tonnes, I was working on an OEW of 128.85 for the 787-9, that would allow about 4 tonnes for catering.
Did SQ actually burn 101 tonnes ?
Read the posts by Whatsaptudo carefully and not just the headlines. The fuel required at dispatch in the case of the QF flights is "built up" to have at least 70 minutes on arrival. The total fuel, required fuel, and trip fuel are 3 different numbers at the planning stage, and fuel burnt is only available after shutting down.
Also your previous comment was stating that the 789 burns 10% less carrying the same payload, there is nothing to suggest that is the case, QF9 looks like it is lifting around 20 tonnes on the route.
Up in the thread I mentioned the effect of ISA variations, over 8000 nm an ISA variation on of +14 degrees resulted in a 4.2 tonne increase in trip fuel. Had a look at todays GPWT to the NW of PER at FL300 it is ISA+2 (-42 deg), out of SIN to the NE it is ISA+16 (-29). QF9 is not maintaining a constant level, the tracks show it doing a continuous climb for the first 5-7 hours which I assume is to maintain optimum levels via some form of block clearance. The routes that SQ traverse are fixed due to the number of crossing routes.
A lot of relevant details which you simply do not understand, or are simply dismissing them as it does not meet your agenda..
We keep a track of every flight by city pair, type, and flight number. Also the actual fuel burn vs flight plan, taxi out time, holding time, extra burn vs flight plan, track flown, contingency left on arrival, departure/arrival times for every flight number by type. That means if we have a city pair that is flown by more than one type, we will have that city pair broken down by time of departure (flight number) and the aircraft used to fly it.
thepinkmachine
Thu Nov 08, 2018 12:01 pm
Thx,
What kind of contingency fuel do you usually get in kg or in terms of flight time on LH flights? Just trying to get an idea of how much can be saved compared to traditional 3-5% method...
Thu Nov 08, 2018 12:42 pm
Well with PBC (probability based contingency) you need to take the good with the bad, generally I will arrive with around 15 minutes above minimum diversion fuel, however if the port has a history of delays that will be built up or short cuts that will be taken out of the contingency. ICAO requires flight plans to include the expected SID and STAR, however with PBC if you are always getting track shortening your total contingency might be as as low as 300 kg. The ICAO Flight Planning and Fuel Management (FPFM) Manual which can be downloaded from IFALPA ( www.ifalpa.org/store/doc9976.pdf ) has some good information in it, our system is just a mirror of that.
thepinkmachine
Thu Nov 08, 2018 1:00 pm
Well with PBC (probability based contingency) you need to take the good with the bad, generally I will arrive with around 15 minutes above minimum diversion fuel, however if the port has a history of delays that will be built up or short cuts that will be taken out of the contingency. ICAO requires flight plans to include the expected SID and STAR, however with PBC if you are always getting track shortening your total contingency might be as as low as 300 kg. The ICAO Flight Planning and Fuel Management (FPFM) Manual which can be downloaded from IFALPA ( http://www.ifalpa.org/store/doc9976.pdf ) has some good information in it, our system is just a mirror of that.
Thanks, so it seems there's a saving of ~15 minutes or more per flight, with higher savings on longer sectors. I'd love to have a look into the FPFM, but unfortunately it is behind a paywall and cost some 170$… I'd definitely buy it though if I ran an airline… :D
MoKa777
Thu Nov 08, 2018 6:05 pm
I undertand.
Aviaponcho
Thu Nov 08, 2018 9:46 pm
Hello everybody
One question
We are comparing fuel burn per hour
Perfect
Are the cruise speed for both comparable ?
Fri Nov 09, 2018 2:24 am
Coffin corner is certainly relevant today. The margins can be pretty slim at times. (Granted, the "limits" contain a 0.3g pad...) And then you get some mountain waves... :)
The max altitude we can actually fly at any moment isn't a constant. "Coffin corner" moves down with higher weight and higher temperature.
WIederling
Fri Nov 09, 2018 10:42 am
Aviaponcho wrote:
Hello everybody
One question
Perfect
simplistic copy from WP:EN:
A350XWB: Mach 0.85 (488 kn; 903 km/h) Typical, Mach 0.89 (513 kn; 950 km/h) Maximum[122]
787: Cruise: Mach 0.85 (488 kn; 903 km/h) Max: Mach 0.90 (516 kn; 956 km/h);[419]
gloom
Fri Nov 09, 2018 10:49 am
That's true concerning standard cruise (standard CI). However, LRC or MRC would be a little lower, and also could be a bit different for both planes. For example, 773 has a .84Ma cruise at default CI, and IIRC below .82 at CI=0 (this would be MRC, if I understand the Boeing concept correctly).
Cheers, Adam
strfyr51
Fri Nov 09, 2018 11:24 am
In reading this thread I have to ask.. Is any of this relevant as to what airplane the Airline should or could buy? Because none of you would be in on the FIX as to What any airline would purchase. OR? Whether they even Paid List price for either model. And that's what makes the difference. The Negotiations where United got the original A320/A319 Order didn't come as a purchase. It came as a LEASE.
As a matter of fact?? A 5 yr walkaway lease. If the Airplanes didn't perform as advertised? United could just PARK THEM and airbus would come and pick them up. We've had them since 1989 so they must have worked as advertised. The A350 question will not be settled until the data can be compared on the SAME route in Real Time Conditions as the B787-9..When and if you have that data? Post it hem we can compare Apples to Apples
Fri Nov 09, 2018 11:53 am
Cheers, Adam
Don’t know enough about the 787 to comment on that. With the A350 basically everything is 0.85, best climb speeds, turbulence penetration, LRC. Bring the aircraft back to CI=0 you save next to no fuel. I put that down to the adaptive wings.
tommy1808
Fri Nov 09, 2018 12:40 pm
Most likely not, but it satisfied curiosity.
you probably can never get two flights on those models with the same seats, only a few less in the 789, same temperature, both on their respective optimum climb profile and cruise altitude, with the same wind, same reserves, same cargo, same temperatures, same ...... ,.....
Now this is giving me something to think about.
We know from an Interview with the TAP CEO that, going from the A359 to the A339 dropped the lease rate, same cabin, same equipment, same airline with the same credit worthiness and negotiation skills, by a third. In other words, Airbus charges a ~50% premium on the A359 vs. the A339.
From diverse "the A330neo is dead/in trouble" threads we know (well, many posters claim) that Boeing can and does match the A330neo prices with its 787. If true, that means that Airbus is also charging a ~50% Premium over the 787.
Now you don´t get to charge 50% more for a 10% bigger plane with 10% more payload and 10% more range if that aircraft also burns 10% more fuel (well, or the 787 10% less, which is a small difference). But you probably can charge said premium if the Aircraft is 10% bigger, can haul 10% more payload and carry the same payload 10% further, but carries the same payload over the same distance with just a small fuel burn disadvantage on top of extra revenue potential and route opportunities due to extra capacity.
Commercial reality, if 787 price claims hold water, would rather support what our resident 787 & A350 pilots have presented in this thread.
best regards
Thomas.
thepinkmachine
Fri Nov 09, 2018 2:23 pm
If you read carefully the title of thread, you will find that it says “787 vs A350 range”, rather than “Should airlines buy A350, or 787”.
Neither I, nor Zeke are Airline management specialists, nor do I pretend to have any knowledge on lease rates and such. Our job isn’t to choose most suitable airplanes for any particular airline.
We do, however, have some accurate data and knowledge regarding operations of these types and decided to share it to compare capabilities of both airframes...
The 787 is also .84-.85 airplane, and cruises on similar levels. It easily overtakes the A350 on approach, though... :mrgreen:
Fri Nov 09, 2018 3:09 pm
Yeah the A350 does everything at a lower speed closer to the ground compared to the A330/A340 (even been overtaken by a 737 !!). On a CONF 2 takeoff, V2 is basically F speed. on approach where I need to maintain CONF1 in a go around you can clean up in the A350. That beautiful big wing effortlessly lifts that aircraft, don't need to beat the air into submission with speed or thrust.
StTim
Fri Nov 09, 2018 8:11 pm
That you to Zeke and thepinkmachine for keeping this thread on track despite the efforts of some professional argumentors.
I have learnt a lot from reading it. Some of it didn't go over my head.
SEPilot
Sat Nov 10, 2018 3:45 pm
Sales figures are showing that the 789 and A359 are very competitive. If one of them had a clear economic advantage it would be dominating in sales, but in fact both are selling well. The 789 seems to be selling a bit better, which is to be expected as it is slightly lower capacity. When you look at the actual sales they mostly appear to be rational choices based on what the airline is seeking. The A350 offers slightly higher range and capacity, while the 789 offers slightly lower trip costs. If the A359 really offered more capacity at the same fuel burn it would be dominating the sales. But it isn’t. Clearly the airlines recognize that each one is optimal for certain missions, and are buying accordingly. This is not like the 767 vs. the A330, or the A320 vs. the 737Classic, where the newer plane offered clearly superior economics.
Eyad89
Sun Nov 11, 2018 1:58 pm
So, a few things here:
- first, we got the fuel burn figures for one flight for each type, and those flights were for different routes, different payloads, and different flying time.
- The difference in fuel burn was found to be 4.5% between the two. Then another sample was taken for another flight, and suddenly the difference became 9.5%, more than double! What happened? small sample size? Or apple to orange comparison? Or both?
- Let's compare the figures from QF9 and QF10. Even though QF10 had 3t more in hold (ZFW higher by 3t), it burned 1.2% less fuel than QF9 ON AVERAGE PER HOUR. Why? it flew for one hour longer, and so it had to carry the weight of that extra fuel the whole time. So at takeoff, QF9 was heavier by 2.5t (249t - 246.5t) even though its ZFW was less by 3t, and that increased induced drag roughly by 2%
Now, see how a slight difference between two almost identical flights gave a fuel difference of 1.2% for the same type just because one was heavier by 2.5t. How can you compare QF9 to SQ22 based on a single flight when we have the below major differences:
- SQ22 was heavier by 27 tons at takeoff than QF9 (but A359's OEW should be heavier than 789's by around 7-10t)
- SQ had 10t remaining fuel at landing, while QF9 had only 4.5t. A difference of 6.5t is the same as having 65 more passengers on board.
-SQ22 was half an hour longer, and so it had to carry around 2-3 more tons of fuel for the extra distance.
- The configuration of the A359ULR is heavier than the regular A359 by around 2-3 tons minimum.
- We don't know the cargo that SQ22 had in that flight, and we don't know its ZFW either.
There are so many variables that would completely alter the result of the final fuel burn numbers, so this comparison is completely useless IMO. If you wanna do it this way, we should get more flights samples, and the flight distance, remaining fuel, and payload should be identical.
On the other hand, we got the figures right from the FCOM, and they wwere confirmed by a 787 pilot and a A350 pilot. This gives you a more proper comparison for the fuel burn while carrying identical payload and flying the same distance. Remember, no one argues that 789 does burn less fuel than A359, but the your claim of 10% fuel advantage while carrying the same payload is way too much.
Sure, 789 has a clear advantage in the parasitic drag, and the parasitic drag accounts for most of the drag forces at cruise speed, but the A359 has the advantage in the induced drag and the engine's TSFC in a way that it would close the gap a bit. I am curious though, how did you calculate the 10% difference?
Eyad89
Sun Nov 11, 2018 6:26 pm
RJMAZ wrote:
The 787-9 flights carried slightly more payload once you deduct fuel and empty weight. .
Did they?
Payload = TOW - OEW - (trip fuel + reserve fuel)
For QF9
payload = 249 - 128.5 - (91+4.5) = 25t
For SQ 22 (remember, extra fuel that is optionally carried is considered payload as well)
Payload = 273 - 138 - (101 +4.5) = 29.5
I gave the SQ22 a reserve fuel of 4.5t to match that of QF9's flight. I counted the remaining fuel as payload as it was optionally carried.
Now, if you would want to compare those figures for identical payloads, you will have to add 4.5t of payload to the QF9, but then that would exceed 789's MTOW, and it won't be able to do that in the first place. For the sake of argument, let's say 789 was able to take off with a higher weight. Then, you will want to add another 2.5t of fuel for the extra half hour the 789 would have to fly in order to match the time SQ22 spent flying. Now that 789 became heavier by 7t with a supposed TOW of 256t, you will also have to add more fuel to carry that extra 7t, which will bring the TOW of 789 to what? 260t? more? If hypothetically 789 was able to take off with 260t, then it wouldn't burn only 91t of fuel for the trip as it would if took off with 249t.
See, you can't even compare those two flights to get a useful fuel burn figure. Let's stick to the FCOM, or get us some figures from flights with identical range and payload.
Users browsing this forum: No registered users and 28 guests
