jacoblaurie04
737 Types
Sun Aug 12, 2018 7:16 pm
I was recently looking at a fleet list for Jet2 and I realised there there were not just the 737-300 and 737-800 but there were many different types of the 800 variant 737 for example:
-737-86Q
-737-85P
-737-86N
-737-808
-737-8K5
-737-8K2
I also know that this is the case for Jet2’s 757-200 fleet:
-757-236
-757-27B
-757-23A
-757-21B
I wondered, what is the difference between all these different varients and what does each stand for? Can anyone help me out, thanks in advance.
GalaxyFlyer
Re: 737 Types
Sun Aug 12, 2018 9:50 pm
The numbers to the right of the hyphen are Boeing codes for who the original buyer was.
GF
XAM2175
Re: 737 Types
Sun Aug 12, 2018 9:54 pm
BWIAirport
Re: 737 Types
Mon Aug 13, 2018 12:35 pm
Airlines who's aircraft come from many sources will end up with a wide variety of customer codes like the airline you mentioned. Even DL has 757-232s. 757-2Q8s, etc. Airlines that have gone through recent mergers will often have two large groups of codes (UA has fleets of 777-222(ER)s, sUA planes, and 777-224(ER)s, sCO planes. Airlines that fly pretty much exclusively their own original aircraft, like AS, will all have the same codes (737-790/890/990/990(ER)).
Also, to save you from the confusion I had when I first learned about Boeing customer codes, they of course work differently on Airbus aircraft. The last two digits are the engine identifier.
As a note: Boeing discontinued customer codes recently, after a certain L/N on 737, 747, and 777 aircraft, (all 77W will be officially 777-300(ER)s), and the last two digits have been dropped entirely on the last 747s, MAXes, 777X, and 787s.
VSMUT
Re: 737 Types
Mon Aug 13, 2018 1:42 pm
Same with Airbus, although they did it a bit earlier.
In the past, airlines were able to order specific variants, such as a 737 with lavatories in the middle, or 777s with smaller cargo doors, different door configurations and other minor but structural things. That meant that an aircraft would forever more be stuck with an extra door or whatever the modification was for its entire life. The unique customer code would then indicate which specific variant/customer modification of the 737 it was.
Since then Airbus and Boeing have standardized their products, so an A320 for EasyJet is in theory structurally identical to one for Lufthansa, except for the easily replaceable interior fittings.
These days the last 2 digits usually indicate something like which engine option is fitted, and if available, which door configuration the aircraft has. Example is the ATR: I forgot what the first digit indicates, but I the second is the engine (0 = PW124, 1 = PW127), last is door configuration (1 = front door, 2 = aft door). Then they can add A after the last number, which means it has the 6-bladed propeller. An ATR 72-212A is therefore a PW127 powered aircraft with a aft entrance door and 6-bladed props. A -201 will be PW124 powered, fore-entrance door and 4-bladed props.
BawliBooch
Re: 737 Types
Mon Aug 13, 2018 1:53 pm
Interesting!
I dont think any of the PW127 powered variants were actually offered/sold with front passenger door? All -500's are -212A's?
Channex757
Re: 737 Types
Mon Aug 13, 2018 2:17 pm
-737-86Q
-737-85P
-737-86N
-737-808
-737-8K5
-737-8K2
-757-236
-757-27B
-757-23A
-757-21B
You missed the most important one!
737-8MG. Jet2's own relatively recently issued Boeing code for the new 738 fleet.
Channex757
Re: 737 Types
Mon Aug 13, 2018 2:23 pm
GF
They can also denote the first leasing company to order the plane and have it delivered to an airline client.
For instance, 6N is GECAS so 737-36N would indicate a 737-300 ordered by them.
Not always though. If it's a longer lease they would often use the client code. Shorter leases tended to use the lessor code.
I can see why Boeing is phasing it out. It doesn't add anything and is a pain to administer. In recent years the trend is for airlines to order planes then sell them to a lessor.
XAM2175
Re: 737 Types
Mon Aug 13, 2018 7:12 pm
Straight from the link I posted:
In 2016, Boeing announced that they would no longer apply customer codes to any aircraft produced after a certain point, which would lead to their designators being the "generic" type for the model. The codes were removed from the type certificates for each model with effect from the production line number shown below:
    Boeing 737 Next Generation: line number 6082
    Boeing P-8 Poseidon: line number 6020
    Boeing 747-8: line number 1534
    Boeing 767: line number 1102
    Boeing 777: line number 1422
Further, customer codes have never been used for the 787 and 737 MAX, and will not be applied to the 777X either.
This is not actually the case - Boeing have for a long time used an arcane combination of different codes to identify particular aircraft configurations, while the customer code being discussed here relates simply to the purchaser, more as a first step toward organising the various further configuration specifications, which is why for example all BOAC- and latterly BA-ordered aircraft have "36", even though within those aircraft they may have changed the exact configurations they took several times. You'll see references to things like "variable numbers" and "block numbers" and "effectivity codes" that are part of this.
Just taking a quick dive into this wonderful world for two sequential 747-400s shows some of the joy:
Line No    Serial No    Type       Basic No    Variable No    Effectivity Code
811        24383        747-422    R2476       RT606          176
812        24833        747-481    R2477       RT752          429
So the customer codes have gone but the basic numbers and many other such things live on, with the 787 family for example getting Basic Numbers starting ZA for the 787-8, ZB for the 787-9, etc etc.
Plus there was a ferocious amount of pointless duplication and overhead in the system - the Royal Australian Air Force has two customer codes (DF and ES) as a result of the exact means by which they sourced certain aircraft, and Qantas Defence Services have DT but it's only ever been used for two 737BBJs they bought from Boeing on behalf of the RAAF.
And then there's a odd variability in what exactly will and won't get a code changed, like how QF's first tranche of 738s were actually ordered by AA but taken over by QF after September 11 - they ended up with QF's 38 code but kept the hideous AA cross-hatch wall panelling :p
Wacker1000
Re: 737 Types
Tue Aug 14, 2018 1:58 am
But what trivia will aviation geeks argue over and try to use to attract mates in 10 or 20 years?
bunumuring
Re: 737 Types
Tue Aug 14, 2018 2:11 am
Hey XAM2175,
Yes the old story about 'the first 15'...
The QF 737-800s actually ordered by AA but taken over by QF.
I didn't actually mind the cross-hatching !
Back on topic.... I actually will miss the use of the Boeing customer code system. It really appealed to avgeeks with OCD like me, lol!
Bunumuring
Re: 737 Types
Tue Aug 14, 2018 2:49 am
My wife and kids have learned to zone out when I get going... :D
Users browsing this forum: No registered users and 40 guests
