stratclub wrote:Preliminary estimate from just one exterior picture: More than $1 and less than $5M.
Inspect, Replace or Repair:Apu and associated components
It is very difficult to tell the extend of the damage from a single picture.
*Rudder
*Fin rear spar
*Rudder actuators
*Rudder control cables and quadrants
Tail cone
Exhaust pipe
Stainless steel shroud around tail pipe
Forward fire wall
Firewall around apu
Apu engine mounting
Associated primary and secondary structure
Aircraft wiring
Aircraft fuel plumbing
Bleed air ducting
*If the rudder was powered when the incident happened it could have caused additional damage.
kalvado wrote:So, as nobody else asked... Is it a write-off?
At high end of an estimate, $5M, it is not impossible to be the case for a 16 year old frame...
darlyn wrote:E145 N14568 backed into a truck at EWR. See full image for details.
Repair estimates?
