Fri Aug 03, 2018 11:18 pm
Thanks for your reply.
When i said that the cost was $15000 per hour that includes fuel and crew and maintenance and whatnot. based on the amount of fuel required given to me by rocket route, it would only cost $20000 for fuel for the WHOLE flight.
In the program, it lets you put in the following weights:
Max ramp (248115kg)
MTOM (247210kg)
MLDGM(201848kg)
MZFM(190508kg)
Basic Empty weight (159570kg) Arm (cm) (0.00)
Crew (680kg)
Options to add 17 reserve weights
Baggage weight (10000kg)
Fuel Balance table
+ Tai Fuel (499.07kg)
It then lets you alter various stages of flight
Climb
FL <190 - Flow 250, FPM 2500, TAS 300
FL >190 - Flow 250, FPM 2500, TAS 300
Cruise
FL <190 - Flow 250, TAS 480
FL >190 - Flow 250, TAS 480
Descent
FL < 190 - Flow 250, FPM 1500, TAS 250
FL > 190 - Flow 250, FPM 3000, TAS 250
Not sure what i need to adjust or where, but when i add weight to the reserve 1, 2, 3 etc, it requires more fuel to be uploaded.
Any help is gratefully appreciated
