DocLightning
A350 materials selection
Mon Jul 23, 2018 2:54 pm
I was looking through the Aircraft Description for Airport Planning documents on the A350 and I noticed something interesting.
Each wing has seven LE slats, one inboard of the engine pylon and six outboard. If we number them 1-7 starting from inboard, then slats 1,3,4, and 5 are made of an aluminum alloy, as is the airplane skin surrounding the flight deck. (https://www.airbus.com/content/dam/corp ... 0-1000.pdf, Section 10-0-0, pg. 12-13)
Why are these slats made of AL alloy when the others are not? What's special about those specific locations? Also, why is the nose made of aluminum?
smaragdz
Re: A350 materials selection
Mon Jul 23, 2018 6:04 pm
From what I recall, the nose section was made from aluminium due to damage tolerance from impact, such as birdstrikes and the likes. Composites can have complicated damage behaviour from impact strikes when compared to metallic structures. I believe a similar constraint is at play for leading edge devices (A380 has some interesting materials from LE devices too I think, but could be wrong), however I can't comment on why different materials are used for different slats.
trpmb6
Mon Jul 23, 2018 7:42 pm
Could be a number of reasons. Could just be that they were supplied by different suppliers who sourced and bid different pricing etc. Could be the contours make it easier in different spots. Could be icing considerations - would be beneficial to have two different material systems which will respond differently in icing conditions so you still have half of your slats available.
Leading edge is aluminum because of the radome and easier to repair if hail strike or bird strike. (A copper mesh imbedded in composite layup for lightning strike does not bode well for radomes - can cause a faraday cage problem if i recall correctly)
WIederling
Mon Jul 23, 2018 8:03 pm
What ever the radome over the weather radar is made of : it most definitely is not made from Al :-)
trpmb6
Mon Jul 23, 2018 8:11 pm
Fiberglass
stratclub
Tue Jul 24, 2018 4:51 am
Most likely because those slats are heated to prevent/abate icing. Also, heated L/E's are not painted either. If you mean the radome, it is made out of fiberglass. On an aluminum airplane, the aluminum structure ends just forward of the cockpit and the fiberglass radome is attached to the aluminum structure.
DocLightning
Tue Jul 24, 2018 12:59 pm
And four of the seven are not?
stratclub
Tue Jul 24, 2018 5:04 pm
That would be my guess. The leading edges of the horizontal and vertical stabilizers on Boeing aircraft are aluminum and they are not heated. I think that polished clad aluminum just might be a better material for critical aerodynamic areas than composite because it is less likely to degrade from airflow erosion than painted composite. Perhaps those two slats per wing are not considered to be in an aerodynamic critical area so they are composite to save weight.
Sun Jul 29, 2018 10:06 am
On the A350, slats 3, 4 and 5 can be heated, The rest cannot be heated. Slatsare counted from outboard.
Thus, starting from the outside, the first two slats are not heated, then the next three are, then the next one is not. The last one, inboard of the pylon, is not
Sun Jul 29, 2018 10:47 am
I would think for both the leading edge and nose the reason for the use of AL is for bird strike certification. While composite could be used it would require titanium reinforcement to meet bird strike requirements, making it uncompetitive on cost.
Part of the design requirements for a wing is that systems need to be protected against damage of a bird strike.
DocLightning
Sun Jul 29, 2018 4:12 pm
OK, but what about the LE surfaces that are made of composite?
Sun Jul 29, 2018 10:04 pm
All of the slats have a hybrid construction, all have LE skins made from aluminium.
The difference with slats 3/4/5 is behind them there is a piccolo tube for bleed air to be used for wing anti ice and its predominantly metallic to enable heat transfer to the outer surface. They have a aluminium rear skin.
The outer slats (6/7) do have an aluminium outer skin, the slat tracks on them are made from steel, the attachment lugs and drive links from aluminium, the actual slat has a composite and aluminium box structure with a composite rear skin and aluminium front skin.
FrmrKSEngr
Wed Aug 01, 2018 2:22 am
stratclub wrote:
That would be my guess. The leading edges of the horizontal and vertical stabilizers on Boeing aircraft are aluminum and they are not heated. I think that polished clad aluminum just might be a better material for critical aerodynamic areas than composite because it is less likely to degrade from airflow erosion than painted composite..
On the 787 Boeing STRONGLY discourages, and will not support, polishing Aluminum exterior surfaces.
stratclub
Wed Aug 01, 2018 3:03 am
Boeing does not use this stuff https://en.wikipedia.org/wiki/Alclad on the 787 anymore for unpainted aluminum surfaces? What does Boeing recommend for maintenance/repair on unpainted Aluminum surfaces on the 787? Do you have AMM, SRM or general references for your statement?
In general, it has been found by Boeing that polished surfaces are more costly to maintain than painted surfaces.
https://www.boeing.com/commercial/aerom ... 01txt.html
FrmrKSEngr
Thu Aug 02, 2018 12:53 am
AMM References, No. I have personally asked Boeing for technical guidance and been told flat out don't polish exterior aluminium on the 787. And it was not a quick conversation. There was quite a bit of back and forth. We wanted shiny metal.
As for the use of Alclad, yes they do use Alclad, they just don't want you polishing the finish off. Per Boeing, No shiny brite work on 787s.
stratclub
Thu Aug 02, 2018 4:34 am
Thanks for replying. It would be great to know the reasoning. I guess polishing the bright work throw a monkey wrench in Boeing's maintenance estimates. We had a couple of retired AAL B707-320's on lease and the bright work sure looked nice for old airplanes.
Same bright work as ours:
Talking about cost effective, I was doing some interior work on a contract we had with NMB miniature bearing's DC10-30F at TIJ and one day the hanger boss had must of been 30 or more of their local "mechanics" polishing the Leading edges by hand. This was IIRC 8 months into a "D"- check that they were doing.
DocLightning
Sun Aug 05, 2018 1:27 am
I'm sorry, Starlionblue. I seem to have missed your answer. Thank you (and Zeke).
Why are these slats unheated? And if they are, it seems like an awful lot of trouble to redesign the components out of composite just because they aren't heated. What's the reason for this?
Sun Aug 05, 2018 2:53 am
Simply not required to meet the icing requirements, not sure where you get this information that they were redesigned. As far as I am aware the configuration was very deliberate at design freeze.
DocLightning
Thu Aug 09, 2018 11:11 pm
Forgive me. I don't mean that there was a change from design freeze. But it strikes me that it would be simpler to design all LE slats to be made of the same material, heated or not. Obviously, the people at Airbus are neither inexperienced nor stupid, so I'm sure there's a good reason for their decision to alternate materials.
Fri Aug 10, 2018 12:38 am
None of the slats are the same size, why do you think it would be best to construct the same way ? They would all have different loads to carry and would all be attached to the aircraft at different widths.
Also I would assume they would come from multiple suppliers.
WIederling
Fri Aug 10, 2018 2:15 pm
Didn't Airbus start to use fiber reinforced thermoplastics for some aero surfaces on the A350XWB?
The thermoplastics would perfectly work in a non heated environment. heated :: less so ;-)
Just a guess.
FrmrKSEngr
Sat Aug 11, 2018 3:52 am
That sounds a bit like the 89th at Andrews and their obsession with polishing the VC-25s.
stratclub
Sat Aug 11, 2018 9:39 pm
I'll bet the MEL for the VC-25 is a blank sheet of paper....................
Sun Aug 12, 2018 1:07 am
Walking around the plane yesterday I had a good look at the slats. As far as I could tell, the non-heated ones have what looks like a black "liner" behind the outside skin that sticks out a bit on the bottom side, while the heated ones do not. I don't know what the "liner" is made of or if it is on the entire rear of the slats.
Users browsing this forum: No registered users and 28 guests
