Apprentice
Which fAR Part?
Sun Jun 17, 2018 9:35 am
Hi:
Same questions, difficult to me.:
A Cessna 172M, wich a Cerificate for “Normal and Utility activities, fliew by his owner some time for fun and rented to a Pilots formation Center, (rent by flight hours), which 14 CFR Part?
I look a Certificated and did not find. Where to find?
Appreciate
Sincerely
Apprentice
Re: Which fAR Part?
Sun Jun 17, 2018 9:37 am
Sorry. Read “flew” instead of “fliew”
GalaxyFlyer
Re: Which fAR Part?
Sun Jun 17, 2018 8:53 pm
Everything, well everything regarding the type certification, is on the TCDS.
Here it is
http://www.airweb.faa.gov/Regulatory_an ... E/3A12.pdf
GF
Apprentice
Re: Which fAR Part?
Wed Jun 20, 2018 3:24 am
GalaxyFlyer, good evening and thanks., still I have several questions, but I will try myself.
Is there any official document, explaining TCDS.
Appreciate
GalaxyFlyer
Re: Which fAR Part?
Wed Jun 20, 2018 9:31 pm
Read thru it, it should be pretty self-explanatory. You might go the FAA (or EASA) TCDS listing for a overview of the format, but for specifics, you might need to have enough engineering background to understand FAR 23 certification.
GF
747Whale
Re: Which fAR Part?
Sun Dec 16, 2018 12:57 am
Part 91 operations, unless the school has a Part 141 certificate, or uses the aircraft for charter work, which then incorporates Part 135. Maintenance is done under Part 43, unless the school has a repair station certificate, in which case it incorporates Part 145.
TCDS is type certificate data sheet; best considered the pedigree or birth certificate for a line of engines, aircraft, etc. It spells out the certification limitations and details (parameters) for a given piece of equipment. It is what the FAA issues when the aircraft is given it's blessing to press forward: the aircraft is recognized as a type, and the TCDS holder becomes the manufacturer. The Type Certificate Data Sheet is regulatory and conformity to the TCDS is required, unless authorization is given to deviate (eg, STC, or Supplemental Type Certificate), or through the use of a CDL (configuration deviation list) or MEL (minimum equipment list) or field approval (form 337) or properly altered by 91.213.
The certification regulation for the Cessna 172 is 14 CFR Part 23, which will be detailed in the type certificate data sheet.
https://www.ecfr.gov/cgi-bin/text-idx?S ... 2_02.tpl#0
Users browsing this forum: No registered users and 37 guests
