shantahan wrote:L/D = load/drag? length/diameter?
fspro wrote:I read that the empty weight of a 777-9X is higher than that of a 747. Is that true?
Stitch wrote:fspro wrote:I read that the empty weight of a 777-9X is higher than that of a 747. Is that true?
Boeing has not formally released OEW figures yet for the 777-9X. Leeham.net projects it will run around 185,000kg and Aspire Aviation states that in four-classes (300 seats) the airframe was at 188,000kg at Revision E. In three classes (406 seats), it was at 164,000kg at Revision E.
The 747-8 Intercontinental in a Boeing three-class OEM configuration (467 seats) is 220,000kg. The 747-400 in a Boeing three-class OEM configuration (416 seats) is 179,000kg.
MoKa777 wrote:Is the 164,000kg a typo?
Stitch wrote:MoKa777 wrote:Is the 164,000kg a typo?
It's what was written. But note that many on a.net view Aspire Aviation's blog as "junk journalism" and view their content as worthless.
AspA wrote:• Boeing 777X weight figures revealed for first time
• 3-class 406-seat 777 -9X MEW at 362,000lbs, MZFW 527,000lbs, MLW 557,000lbs
• 4-class 300-seat 777-9X has OEW of 415,000lbs
• 777-9X 8.8% lighter in MZFW per seat than-300ER, 6.3% lighter than A350-1000
