fspro
Empty weight of 777x vs 747
Thu May 17, 2018 9:49 pm
I read that the empty weight of a 777-9X is higher than that of a 747. Is that true?
If so, why is that? If I'm not mistaken, the 747 was made of aluminum with aluminum wings, but the 777x fuselage is made of Aluminum and Lithium and the wings are made of CFRP. Seems to me that the 777x was built with more advanced materials and holds fewer people and so I'd expect it to be lighter than the 747.
Matt6461
Re: Empty weight of 777x vs 747
Thu May 17, 2018 10:08 pm
They have about the same cabin area, actually - 779's cabin is much longer. 747 has a higher exit limit but Boeing specifically chose to limit max capacity to save on exit space.
The weight difference is primarily due to 779's much greater wingspan (235ft vs. 213). This makes for a slightly heavier plane but is the main reason for 779's ~17% higher L/D. You'd easily trade 17% higher L/D against a small weight delta.
CFRP saves ~10% wing weight but wing bending weight scales cubically with span, so on net the 777-9's wing will be heavier.
shantahan
Thu May 17, 2018 11:58 pm
L/D = load/drag? length/diameter?
OldAeroGuy
Fri May 18, 2018 12:46 am
Aero performance engineers will recognize L/D = Lift/Drag. It's a primary measure of airframe efficiency.
shantahan
Fri May 18, 2018 1:07 am
(I saw this in the civil forum before it got moved to tech ops).
Stitch
Fri May 18, 2018 1:27 am
Boeing has not formally released OEW figures yet for the 777-9X. Leeham.net projects it will run around 185,000kg and Aspire Aviation states that in four-classes (300 seats) the airframe was at 188,000kg at Revision E. In three classes (406 seats), it was at 164,000kg at Revision E.
The 747-8 Intercontinental in a Boeing three-class OEM configuration (467 seats) is 220,000kg. The 747-400 in a Boeing three-class OEM configuration (416 seats) is 179,000kg.
MoKa777
Sat May 19, 2018 6:38 am
Is the 164,000kg a typo?
Stitch
Sat May 19, 2018 3:30 pm
It's what was written. But note that many on a.net view Aspire Aviation's blog as "junk journalism" and view their content as worthless.
WIederling
Sat May 19, 2018 4:12 pm
ref:
https://web.archive.org/web/20171023174 ... battle.pdf
AspA wrote:
• Boeing 777X weight figures revealed for first time
• 3-class 406-seat 777 -9X MEW at 362,000lbs, MZFW 527,000lbs, MLW 557,000lbs
• 4-class 300-seat 777-9X has OEW of 415,000lbs
• 777-9X 8.8% lighter in MZFW per seat than-300ER, 6.3% lighter than A350-1000
translates to metric:
• 3-class 406-seat 777-9X MEW at 164t, MZFW 239t, MLW 253t
• 4-class 300-seat 777-9X has OEW of 188t
so it is orange vs peeled orange or something like that :-)
no apples where harmed in this posting.
I will keep mum about the per seat MZFW number comparison <gnaaagrrr>
Users browsing this forum: No registered users and 31 guests
