NYPECO
Red square on top of CRJ-200 fusulage
Tue May 15, 2018 8:02 pm
What is the painted red square on top of the CRJ-200 fuselage for?
AirKevin
Re: Red square on top of CRJ-200 fusulage
Tue May 15, 2018 10:50 pm
I believe in the event of an emergency, if rescue crew outside need to cut their way into the plane, that marks a spot where they can safely cut into the plane.
Captain Kevin
battlegroup62
Wed May 16, 2018 4:47 am
Absolutely right, It is a cut here mark for rescue workers. Its is not necessarily a requirement to have them in the US, but in some other countries it is. That area has been selected because its free of power cables and hydraulic lines so as not to endanger the rescue workers when they cut it.
We have to keep planes airworthy. That doesn't mean they have to fly.
Florianopolis
Wed May 16, 2018 5:09 am
Apprentice
Wed May 16, 2018 5:21 pm
Hi, You are Right. In this part of the fuselage, no structure’s reinforcement element should be found, in a way, cuting through it will be “easier”. By authorities requirement, this part should be located above flotation line.
Nevertheless, cutting operation is not easy and will take some time. There are some videos on-line of firebrigades training his tools/abilities in planes completely out of service. They are instructive!
“An AME, with just a Mechanic Role”, as per one of our pilots
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
Gr8Circle
Mon May 28, 2018 12:08 am
I've seen this on the 777 too....just behind door #1 on top of the fuselage
Mon May 28, 2018 1:02 am
You can find these marks in a few different locations.
PowerliftDrsTX
Thu Jun 07, 2018 1:24 pm
awesome picture, though
Coriander
Fri Jun 08, 2018 2:10 am
Has this ever been used in operation?
