anthonycII
Tri Jet Production
Tue May 15, 2018 10:20 am
Would anyone have a link to a video of the production of a tri jet? I'm very interested in the installation of the middle engine utilizing the S-duct?
tb727
Re: Tri Jet Production
Tue May 15, 2018 5:51 pm
This is a sped up video of one on the 727. There are attach points on the tail for hoisting the engine, pretty cool seeing it done in person. https://youtu.be/jbVX45lEK2Y?t=8m11s
Max Q
Wed May 16, 2018 2:49 am
Well that’s something I haven’t seen before
Pretty cool, except for the music..
BravoOne
Wed May 16, 2018 10:52 am
Well, at least they didn't do it like American did with a fork lift.
fr8mech
Wed May 16, 2018 12:00 pm
We used a forklift on B727 engines all the time. Not an issue.
BravoOne
Wed May 16, 2018 3:49 pm
Sorry I was referring to the AA, DC10 accident at ORD where they used an unauthorized procedure to hang the engine with a fork lift.
tb727
Wed May 16, 2018 7:13 pm
lol, oops sorry, I had it muted and didn’t know!
fr8mech
Wed May 16, 2018 8:04 pm
I know what you were referring to, but that’s apples to broccoli. The AA (and Continental) procedures removed the engine and pylon as an assembly.
At PanAm we used a forklift to pull B727 & B747 engines.
Center engine changes were pretty simple on the B727. Access to the firewall connections were ridiculously easy as compared to the side engines.
Never changed a #2 on an L-1011, so I can’t really comment on it.
exFWAOONW
Sun May 27, 2018 1:00 am
Here is a time-lapse video of the removal of the #2 (center) engine from a DC10 in what appears to be an airplane graveyard.
The plane is missing the #1 and #3 engines, and I assume has no ballast fuel in the tanks, so what is keeping the nose wheel on the ground?
https://www.youtube.com/watch?v=Z06ygrLhknk
Is just me, or is flying not as much fun anymore?
Max Q
Sun May 27, 2018 2:41 am
They probably have the nosewheel attached with a steel cable to a large concrete block or a ring embedded in the ground
I’ve seen FED EX do this while loading / unloading rather than use a tail stand
Tristarsteve
Sun May 27, 2018 11:56 am
The Tristar Nbr 2 was similar to the DC10.
You needed a couple of technicians to do the clever parts, and about ten labourers to do all the heavy lifting.!!
I worked in BAH with Gulf Air and we changed Nbr 2 engines outdoors using the bootstrap chains. The hangar was not tall enough for a Tristar tail.
The engine stand was hoisted up to the engine on four chainhoists, then the engine was released from the airframe and the stand plus engine was lowered. The hoists were all manually operated, and the engine weighs 7 tonnes, and to keep it moving we had three men on each chain, taking turns to pull. After that you didn't need to visit the gym for a while!
The whole operation was pretty simple, just lots of heavy lifting. With a team that knew what to do, a remove/install took about 12 hours.
trnswrld
Sun May 27, 2018 1:55 pm
Number 2 on a DC-10/MD-11 must have been a real treat. That thing is up there!
unimproved
Mon May 28, 2018 9:31 am
Water tanks and concrete in the fwd cargo hold.
UGLYRAED
Sun Jun 03, 2018 6:13 pm
as a tristar lover, this story was fun to read!! I will remember it forever
Users browsing this forum: No registered users and 31 guests
