Ashley330
A330-200 Ultra Long Haul
Tue Apr 17, 2018 9:32 am
Could an A330-200 operate between LHR and SYD non stop.
I know previously the a330 operated from toulouse to melbourne fror delvery with 20pax, is 20 the max or could it fly with more?
LH707330
Re: A330-200 Ultra Long Haul
Tue Apr 17, 2018 5:00 pm
Yes, but not profitably. The A332 has the same fuel tank volume as the A342 and 343, but because it's got a much lower MTOW, you fill the tanks and then there's not much weight left to put revenue payload in.
Tue Apr 17, 2018 7:03 pm
QF used to operate the A332 from the west coast via AKL to Australia. I would not call that ultra long haul.
hitower3
Thu Apr 19, 2018 9:26 am
Let's put some numbers here:
OEW: 120t
MTOW: 234t (the version of the -200 back in 2003 when the TLS-MEL flight took place, current MTOW is at 242t and the -800NEO would go up to 251t)
Max fuel: 109t.
Therefore with full tanks, there is still 5 tons left for payload, so it would be roughly 45-50 pax.
I cannot guarantee that this 20h flight would have been possible with 50 instead of 20 pax, as their added weight slightly increases fuel consumption. In any case, these kind of missions are WAY beyond the economically reasonable mission scope for this aircraft.
Pellegrine
Fri Apr 20, 2018 10:30 am
Qantas also flew A332 AKL-LAX.
bhill
Fri Apr 20, 2018 7:19 pm
So pretty much a flying gas tank then? Does that 5 tons count both passengers and their baggage?
trex8
Fri Apr 20, 2018 11:14 pm
@100kg per person and baggage is pretty standard, so 50 pax, 5000kg, 50 metric tons, I think airbus actually use 90 or 95kg .
WIederling
Sat Apr 21, 2018 12:25 pm
@100kg per person and baggage is pretty standard, so 50 pax, 5000kg, 5 metric tons, I think airbus actually use 90 or 95kg
trex8
Sat Apr 21, 2018 6:47 pm
well I was almost within an order of magnitude!!! :lol:
Its a US metric ton! Historical note, the reason US volumes are smaller than British imperial ones is because when those ships used to sail from mother England to the 13 colonies the captains routinely stole a little out of each barrel!
But this in 5 gallons!! Really!! These goods dont travel well if they totally fill the container!
WIederling
Sun Apr 22, 2018 8:11 am
fun:
my understanding was that the Brit 112 lbs "cwt" was the real "CWT/hundredweight" with some nefarious tax added.
( with quite a lot of that UK/US disparity stuff you can see when the "export" happened.)
truth is slightly different, apparently:
https://en.wikipedia.org/wiki/Hundredweight
Users browsing this forum: aballack50, TangoandCash and 37 guests
