Max Q
B747 Pushback and towing
Wed Feb 14, 2018 10:03 am
When pushing back or towing the 747 is the body gear steering activated ?
I believe this system is hydraulically powered, how is it pressurized before an engine is started, electric hydraulic pumps ?
If it’s normal to use body gear steering for push back and towing Is there a reason where you would not use it ?
fr8mech
Re: B747 Pushback and towing
Wed Feb 14, 2018 10:25 am
Yes it is. Body gear steering (along with the nose) operates off the #1 hydraulic system. The #1 hydraulic system can be powered by the Engine Driven Pump (EDP) or the Air Driven Pump (ADP). Additionally, the -8 has a AC Motor Pump (ACMP) installed in the #1 system.
The -100/200's were essentially the same as the -400, though some did have the additional ACMP in the #1 system.
If you're towing a dead airplane, there is no body gear steering available.
Max Q
Wed Feb 14, 2018 10:49 am
Thanks for that, with engines off does this ADP receive bleed air from the APU ?
I assume if you have to tow a dead aircraft you have to make fairly wide turns with no body gear steering or you could get tire scrubbing?
fr8mech
Wed Feb 14, 2018 10:54 am
Yes, the APU can supply the ADP's. On the -400 and -8, they are installed in systems 1 & 4. On the -100/200, they are installed in all 4 systems.
Yup, slow, wide turns. You can turn tight, but you will get scrubbing...the lighter the aircraft, the better. Same thing if you're taxiing the aircraft with an inop BGS system. Slow, wide turns. The way we park aircraft here, an inop BGS system is a tow in and tow out of the parking spot.
Max Q
Wed Feb 14, 2018 11:04 pm
Thanks for the information
Users browsing this forum: 747Whale, caoimhin, hughnz, jking629, mmo, paracetamol, trex8, Wednesdayite, WildcatYXU and 21 guests
