seb146
Routing Of Some LAX-HNL Flights
Fri Nov 03, 2017 3:17 am
I look on flightradar24.com and have noticed that some flights leave LAX and head north up the California coast to about Monterey before turning West to Hawaii, usually HNL. When we flew to HNL two years ago, we flew west from LAX on a DL 757. What is the point of flying north then turning? There are 737 and 321 flights SEA-HNL and YVR-HNL all the time, so I don't understand what the difference is LAX-HNL. Two flights I am looking at are DL 1149 757-300 and AA 285 Airbus 321.
CARST
Re: Routing Of Some LAX-HNL Flights
Fri Nov 03, 2017 12:35 pm
I've been on one of these flights before and have no explanation. My guess would be winds and/or traffic on the fixed air route.
Coptyright: www.gcmap.com
The route via Monterey is 102nm longer and takes about 13 minutes more, if you not consider winds. Of course the winds on that day could have made this route longer route viable.
High altitude winds over the USA:
http://www.aviationweather.gov/windtemp
CARST
Fri Nov 03, 2017 12:39 pm
I think this graphic / wind simulation explains it nicely (set to 250hpa, because that's the usual atmospheric pressure at cruising altitude of moder airliners between 10 and 11 thousands meters):
https://earth.nullschool.net/#current/w ... 32.78,1474
RetiredWeasel
Fri Nov 03, 2017 2:06 pm
CARST's guess of trafiic would be my explanation. There is a track system to Hawaii and most airliners will be assigned to one of the tracks. They can get saturated and occasionally you either take a ground hold or accept one that is less optimal. Winds could be a factor during the winter as the jets do migrate south, but I doubt that is the case in this instance.
Adispatcher
Fri Nov 03, 2017 4:02 pm
Active military areas off the LA coastline.
Scroll down to ZLA https://sua.faa.gov/sua/siteFrame.app
seb146
Fri Nov 03, 2017 4:53 pm
Thanks for all the replies.
I don't think winds are really a factor. When I was watching last night, it was only two flights and there was a significant storm blowing into Northern California and the Pacific Northwest. I think traffic is probably a better explanation.
Crackshot
Sun Nov 05, 2017 2:35 am
This is one of the published departures for LAX, and you can see the dinty transition, which according to flightaware is often the first waypoint for LAX-HNL flights, there. I'm not sure what the geography of the waypoints is, but could this be it?
http://flightaware.com/resources/airport/LAX/DP/DARRK+ONE+(RNAV)/pdf
Sun Nov 05, 2017 2:52 am
The DINTY transition leaves the coast around Santa Barbara. Even STOKD isn't halfway to SFO.
DINTY transition plotted in Skyvector: https://skyvector.com/?ll=34.34388961440677,-120.08770751584694&chart=301&zoom=7&fpl=%20KLAX%20DARRK%20FIXIT%20IKAYE%20RIZIN%20DINTY
Crackshot
Sun Nov 05, 2017 2:57 am
Wow I was way off there. :oops: Interesting stuff, thanks.
Sun Nov 05, 2017 2:58 am
It was worth investigating.
Users browsing this forum: No registered users and 28 guests
