benbeny
Wing sweep at 25% MAC, why?
Thu Sep 14, 2017 4:38 pm
Apology if this has been asked before.
The title says it all. Why do we measure wing sweep angle at 25% MAC instead of leading edge? Where's the rationale behind it?
Thank you very much :)
Re: Wing sweep at 25% MAC, why?
Fri Sep 15, 2017 1:48 am
Probably to make a standard for comparison.
trijetsonly
Fri Sep 15, 2017 8:07 am
It is standard assumption that the center of lift is located at or near 25% MAC.
To quote Wikipedia: [For symmetric airfoils in subsonic flight the aerodynamic center is located approximately 25% of the chord from the leading edge of the airfoil. This point is described as the quarter-chord point]
With that in mind, the wing sweep angle is mostly used for aerodynamic considerations. It is logical, that the wing sweep angle at the aerodynamic center is used for that, ergo at 25% MAC.
WIederling
Fri Sep 15, 2017 11:19 am
Does that actually stil apply for the rearloaded ( actually more evenly loaded ) supercritical profiles?
Just asking.
OldAeroGuy
Sat Sep 16, 2017 3:47 pm
Still close enough that there is no need to give up on the 25% standard as a basis for comparison.
benbeny
Tue Sep 19, 2017 10:05 am
Thanks guys!
So it's basically just because in average, wing lift is centered around 25%, so it is simple to compare one wings and other :D
SCAT15F
Wed Sep 20, 2017 8:00 pm
The 747 has significantly higher wing sweep (well over 40 degrees) between 25% MAC and the wing root, so that one is skewed a bit. Not sure if any other current aircraft wings have a non-constant sweep angle.
LH707330
Wed Sep 20, 2017 10:02 pm
How do you figure? If anything, the kink and the reduced trailing edge sweep would reduce the sweep there, no?
WIederling
Thu Sep 21, 2017 7:18 am
Given as 37.5° for all 747 models : -100 to -8
The jehudi is not counted ?
LH707330
Thu Sep 21, 2017 4:45 pm
I guess not, nor apparently the reduction in leading edge sweep at the outside pylon:
This also raises the question: where on the wing spanwise is the 25% MAC measured? Think about an A330/340 wing that has three trailing edge kinks: one between the aileron panels, one at the middle flaptrack canoe, and another one inboard. Add to that the wing-glove like inner slat that adds a subtle kink at the inboard pylon....
trijetsonly
Fri Sep 22, 2017 12:24 pm
It is measured at a calculated average wing chord. The wing root length, wing tip length and wing taper ratio go into that equation. The result is an extract of the wing with average chord length.
The basics behind this will look like this:
The result at a complex wing will look like this:
LH707330
Fri Sep 22, 2017 8:27 pm
That's pretty cool, thanks for that explanation!
Users browsing this forum: No registered users and 30 guests
