767333ER
757/767 EICAS Maintenance Display Select
Sat Aug 05, 2017 7:49 pm
A bit of a strange question, but what exactly do these buttons do?
Been on: 732 733 734 73G 738 752 763 A319 A320 A321 CRJ CR7 CRA/CR9 E145 E175 E190 F28 MD-82 MD-83 C172R C172S P2006T
Florianopolis
Re: 757/767 EICAS Maintenance Display Select
Sat Aug 05, 2017 9:07 pm
Does this help?
7BOEING7
Sat Aug 05, 2017 9:19 pm
They display the listed maintenance pages on the lower center display while on the ground. Optionally some customers were able to display them above 10,000'. The adjacent panel allows "events" to be recorded for maintenance to display and erase after landing. Generally this panel is not used by the flight crew.
During production test flights we had access to this information throughout the flight to record data or get more inflight information relative to maintenance issues.
767333ER
Sat Aug 05, 2017 11:29 pm
This definetly helps, thanks for the replies!
Apprentice
Sun Aug 13, 2017 5:28 am
Hi: For instance, During flight there is an "Status Message" (or any other kind) about Air conditioning system.
When on Ground, Mx Crew will ask, pressing correspondent button for associated Mx fault message to this "Status:
With Both "Status Message" and "Mx Message" on hand, he have a Dual "Entry Point" on FIM (Fault Isolation Manual) to search for correct troubleshooting procedure and, eventually, determine what was wrong in the system and fixed.
“An AME, with just a Mechanic Role”, as per one of our pilots
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
Apprentice
Sun Aug 13, 2017 5:30 am
And in our case, Air Conditioning System together with Air Bleed and Anti-Ice system's faults will be found under "ECS"
Apprentice
Sun Aug 13, 2017 5:36 am
(In a side note, when working on B76,it was useful a B767 App for faults, "B767 EICAS". I repeat, it helps, but do not substitute Boeing Manual. In fact it explain what every message means, level and Fault Code, (used to search on FIM)
I recommend it as a complement.
Users browsing this forum: ChrisKen, greg85 and 19 guests
