a7ala
Boeing vs Airbus Landing Performance
Mon Jul 10, 2017 10:44 pm
Hi All,
One thing I have noticed is that it appears to me that boeing aircraft tend to have better landing performance than airbus. I have put together the following table outlining what I can find about similar aircraft types:
B787-8 B787-9 B787-10 B777-200ER B777-300ER A330-200 A330-300 A350-900 A350-1000
Length (m) 56.72 62.81 68.28 63.73 73.86 58.82 63.67 66.61 73.59
Tail height (m) 17.02 17.02 17.02 18.5 18.5 17.39 16.83 17.05 17.08
Wheels 2/4/4 2/4/4 NA 2/6/6 2/6/6 2/4/4 2/4/4 2/4/4 2/6/6
MLW (T) 172.4 192.8 201.8 213.2 251.3 182.0 187.0 207.0 236.0
MLW Runway (Dry) (m) 1620 1800 NA 1550 1750 1730 1780 1980 NA
MLW Runway (Wet) (m) 1850 2100 NA 1800 2050 NA NA NA NA
For example, the A350-900 requires almost 200m more than the B777-300ER on a dry runway despite the size difference. Is it the number of wheels, tail height or something else?
Re: Boeing vs Airbus Landing Performance
Tue Jul 11, 2017 2:17 am
The A350-900 best landing distance in ISA conditions nil wind is 4237 ft dry and 4688 ft wet at MLW. I would not fly like that for passenger comfort, but the performance is there to achieve that.
Those numbers come from the current flysmart performance software.
The problem with making threads like this is people often do not have the actual performance data in the first place and come to incorrect conclusions.
OYVKH
Wed Jul 12, 2017 8:32 pm
Zeke,
Those numbers you are mentioning are calculated using unfactored performance...?? If that's the case, then you are comparing apples to oranges.
By using the ''simple'' standard 1.67 formula for planning purposes...Your dry required runway length would be around 7076ft (2157m), which is HIGHER than the numbers A7-ALA posted.
OY-VKH
Thu Jul 13, 2017 3:06 pm
Required runway length is not landing distance, as you mentioned at dispatch required runway length is a factor applied above the dry landing distance with either 1.67 dry of 1.92 wet.
hivue
Thu Jul 13, 2017 5:51 pm
Not strictly on topic, but how's this for an A350-900 landing distance --
http://www.youtube.com/watch?v=rqSTVWw7twU
OYVKH
Thu Jul 13, 2017 6:46 pm
No, but all the numbers A7-ALA posted before were landing distances required at MLW and not unfactored distances. Therefore i would assume that comparing LFL with LFL would be the smartest thing to do.
Just my opinion.
To topic...
On the Boeing 787-8, those numbers are almost correct. 1650 m is required on a dry runway. Landing distance is 990 m and ground roll is 699 m. (172365 kg MLW and numbers are based using Piano-X)
Have a good one,
OY-VKH
a7ala
Thu Jul 13, 2017 10:09 pm
OYVKH wrote:
To topic...
Have a good one,
OY-VKH
Thanks - I was trying to scale from whats in the airport planning manuals.
Fri Jul 14, 2017 3:49 pm
Just my opinion.
To topic...
Got not idea what they posted, it was not the A350 pr 777 landing distance, fact is the A350-900 has a shorter landing distance than a 777-300ER at MLW. A large reason for that is the A350 has lower approach speeds. What I posted was the output of flysmart which is the factored operational landing distance.
The industry has gone away from using actual landing distance and using RCAM and operational landing distance for the best part of a decade after a number of overruns.
Why bother quoting piano x ? Is that because you don't have the actual performance data either ?
Users browsing this forum: B-787 and 9 guests
