MoKa777
Airbus beefs up A350-1000, A350-900
Tue Jun 27, 2017 4:38 pm
Hey everyone.
Did not see this posted as yet.
Moderators, If already posted or discussed, please delete.
https://leehamnews.com/2017/06/27/airbu ... more-23972
I always had high hopes for and a lot of faith in the A350. Glad to see these high hopes and faith coming to fruition.
MoKa777
Re: Airbus beefs up A350-1000, A350-900
Tue Jun 27, 2017 6:01 pm
http://www.aircraft.airbus.com/support- ... teristics/
The A350 ACAP seems to be missing entirely on the Airbus website... possibly being updated.
Slug71
Tue Jun 27, 2017 6:30 pm
Very interesting.
Just keeps getting better. Really hope SAA will pick up some of these in the future.
Polot
Tue Jun 27, 2017 6:42 pm
MoKa777 wrote:
http://www.aircraft.airbus.com/support-services/airport-operations/aircraft-characteristics/
I tried checking last week (for something completely unrelated) and while the link was up it wasn't working. I think the Airbus website redesign broke a few pages (including, unfortunately, links to old press releases).
94717
Tue Jun 27, 2017 6:44 pm
How will A350-10 compare to the B77W with these new figures?
mjoelnir
Tue Jun 27, 2017 7:59 pm
Only a slight initial payload difference left, 1 or 2 t. But the A350-1000 will fly that initial payload over a longer distance.
3 t increase in MZFW to 223 t, equals 3 t increase in max payload to about 68 t. 8 t MTOW increase to 316 t, brings 5 t more fuel with 3 t more max payload.
At 366 pax, 8 t more fuel should give more than an hour increased endurance, that means at least 450 nm more range, bringing that to about 8,400 nm.
Chaostheory
Tue Jun 27, 2017 8:25 pm
The pessimist in me says the bump in the mzfw is to cover a higher empty weight for the -1000. The last update from Airbus 8 weeks ago was giving oew of 158t. I don't know how that compares with the original targets.
MoKa777
Tue Jun 27, 2017 8:27 pm
Slug71 wrote:
Very interesting.
Me too. Excellent option indeed.
817Dreamliiner
I think the original was 155t.
MoKa777
Tue Jun 27, 2017 8:29 pm
As much as I love the -1000, it always felt a tad bit anemic.
As you point out, the changes go a long way to bulking up its specs.
Hopefully it is going to be as robust a performer as the -900.
parapente
Tue Jun 27, 2017 8:48 pm
One can see how an 1100 is possible if they ever need to.
mjoelnir
Tue Jun 27, 2017 8:50 pm
Airbus has bumped the MZFW for the higher MTOW version of both the -1000 and -900. The A350-900 got 3.7 t. The -900 seems to be on spec regarding weight.
gatibosgru
Tue Jun 27, 2017 8:52 pm
Does this also mean a "beef-up" for the ULR?
Planesmart
After a respectable interval, will the A330NEO see similar, but scaled improvements?
Polot
Tue Jun 27, 2017 9:10 pm
The A359 "beef up" is actually not a surprise. Airbus has talking about it since the ULR, they just haven't had it in their ACAP yet.
Chaostheory
Tue Jun 27, 2017 9:48 pm
I've just done a little digging through the airbus website and from the weights given in the firefighting and rescue charts, it would appear that I'm closer to the mark. The weights given in those documents are manufacturer (not dry) empty weights and I've corroborated that by looking at our current Airbus fleet (eg A320 41t airbus figure vs 42.3t for our fleet). Airbus lists 160t for the -1000 and 140t for the -900.
http://www.aircraft.airbus.com/support- ... ng-charts/
Presumably, the 158t I saw quoted in the brochure was an optimistic preliminary figure.
LAX772LR
Wed Jun 28, 2017 5:09 am
Other way around: the beef-up that the -ULR has had since conception, is now (officially) being placed on the standard -900... though that's been no secret for well over a year now.
If however Airbus decides to construct an aircraft to fit the QF rfp, THEN you'll definitely be looking at a beefed-up A350, way beyond anything we've seen thus far.
Ruscoe
Wed Jun 28, 2017 5:35 am
You all sure.It doesn't mean that flight testing has shown the 1000 falls short in some area and this is the standard way both Airbus and Boeing fix these problems?
Ruscoe
LAX772LR
Wed Jun 28, 2017 6:30 am
If the increases in range and/or revenue payload potential weren't commensurate with the increases in weight, then it's usually a pretty good sign that it's a patch-up (witness the A345)... but that doesn't seem to be be the case here.
Polot
Wed Jun 28, 2017 10:43 am
To be fair we dont know that about the A350's increases yet. Everyone is talking about range/payload increases under the assumption that it is not covering any unexpected extra weight. AFAIK Airbus has yet to officially comment on the MTOW increases on the -1000 and the performance enhancements they will give.
a320fan
Wed Jun 28, 2017 10:49 am
An 8ton increase in MTOW for the 1000 is really quite impressive.
Flighty
Wed Jun 28, 2017 11:54 am
Turns it into a true, TRUE longhauler. And a true 77W owner.
speedbored
Wed Jun 28, 2017 1:31 pm
Well it seems to be back now but ..... it's back to the old one from last year.
I wonder whether some over-enthusiastic employee posted the updated ACAP before they should have done, especially given the absence of any formal announcement of the new weight variants from Airbus. I'm guessing the new ACAP will come back after they formally announce the new variants.
luv2cattlecall
Wed Jun 28, 2017 3:17 pm
I'm not fully up to speed on the 350, but how will this beefed up version compare to the 77L?
Flighty
Wed Jun 28, 2017 3:31 pm
The manufacturers do not quote range in a way that is easy to compare. AFAIK this appears to show that A350-10 has longer legs than both 77E and 77W, both considered true longhaulers. It will not beat the 77L, which is a ULH machine. The A359 might match r beat the 77L for range now.
MoKa777
Wed Jun 28, 2017 8:42 pm
I really believe that, if true and confirmed, this 'performance augmentation' will be adding capability and not just bring the A350 up to spec.
Obviously, a more pessimistic view is the latter and that is 100% reasonable and plausible until we have more information from Airbus themselves.
RL777
Wed Jun 28, 2017 8:58 pm
Well Airbus has only had 13 or so years to produce a better aircraft.
Motorhussy
Wed Jun 28, 2017 9:42 pm
Really hope Airbus can make the right offer - delivery time, finance, maintenance, training etc - to Air New Zealand when it comes to the RFP for replacing the 77E and 77W fleet. The performance of the the A359 would make AKL-NYC a no-brainer, and would make AKL-GRU possible too.
Tedd
Wed Jun 28, 2017 10:01 pm
It can take time to beat the best. Airbus can rightly be proud of the A350 series, the -900 is
proving itself to be very competent, the -1000 could & should follow suit, providing a real
alternative to B777-9. It will be interesting see how orders go in the next few years.
Motorhussy
Wed Jun 28, 2017 10:16 pm
Tedd wrote:
...providing a real alternative to B777-9. It will be interesting see how orders go in the next few years.
Yes, I think it'll be interesting to see how many airlines find the 779, and 778 for that matter, just too much aeroplane for the services they need them for. The performance and lighter weight of the A359 and A35J, and marginally smaller size, may just be more attractive to many in the 77E and 77W replacement cycle. And it may be seen as an easier aircraft from which to develop new long-haul routes.
OA940
Wed Jun 28, 2017 11:18 pm
Too bad PAS17 is past us now...
LoganTheBogan
Wed Jul 12, 2017 7:55 am
Airbus were originally uncertain about building the type and now we have this beauty! Airbus really ought to be proud of themselves!
77H
Wed Jul 12, 2017 8:25 am
With all the improvements Airbus is making to the 359/K I imagine we can expect similar performance improvements to the 778/9 as development marches on. In this case Boeing has an advantage as the 77X is still largely a paper plane and Boeing will have specific metrics from the 350 in order to try and best the 350.
The engines for the 77X are also still in development correct? Is it possible for Boeing to go to GE and ask them for improvements to the GE9X to assist in improving performance?
77H
WIederling
Wed Jul 12, 2017 8:27 am
link from there:
http://www.aircraft.airbus.com/fileadmi ... 0-1000.pdf
exists. Last but one, just above the A380. ( Still the Nov 1, 2016 issue )
WIederling
Wed Jul 12, 2017 8:32 am
77H
IMU Boeing is done with paper shuffling. First items are in production.
i.e. no further major changes. MTOW is maxed out anyway.
Afaics engine and airframe don't have significant margin.
mjoelnir
Wed Jul 12, 2017 8:42 am
77H
IMO the 787 is not open to improvements in the same way as the A350 are. Airbus seem to have build in extra capabilities and the A350-1000 is much more than a stretch. Just look at wing sizes and the MLGs.
WIederling
Wed Jul 12, 2017 9:38 am
For the A359 all the accommodations for early baby fat were folded into real product enhancement after "right sizing" the OEW.
I'd expect the same for the A3510 ?
( Actually looks like Airbus has a little box of wonders at their hands.)
KarelXWB
Wed Jul 12, 2017 9:42 am
It's just another weight model, nothing much to see here. Airbus offers more than a dozen weight models on the A320 and A330, and even the A350-900 already has like 8 different weight models. The A350-1000 won't be different.
WIederling
Wed Jul 12, 2017 10:03 am
Expanding MTOW while also expanding MZFW is slightly more than "just another weight model, isn't it? :-)
( IMU most of th WVnnn variants are either lower MTOW or different balancing of MTOW and MZFW.)
kimimm19
Wed Jul 12, 2017 10:15 am
With all these improvements to the A350 models and that perceived impact on bringing it closer to the 777X, does that not shift the power to the 787 in that particular market segment?
KarelXWB
Wed Jul 12, 2017 10:26 am
Let me put it this way: I'm not surprised to see a MTOW increase, 316t is in line with my expectations. The landing gear was designed to allow some growth and we may even see a 318t weight model in the future.
KarelXWB
Wed Jul 12, 2017 10:34 am
A formal announcement is not required though. When the A350-900 was certified, the ACAP documents suddenly listed 273t and 275t models without much fanfare.
PC9
Wed Jul 12, 2017 2:55 pm
Very interesting.
The potential A350-1200 was mentioned to have a MTOW of 319t.
I would assume this could be reachable, or would this need strengthening and/or more power?
Stitch
Wed Jul 12, 2017 4:23 pm
Well the 787-8 theoretically has plenty of TOW headroom left by leveraging 787-9 components, just as the A350-900 could leverage A350-1000 components to grow her TOW into the 300,000kg tier. However, both would really only benefit UULH operations (allowing more fuel to be loaded at higher payload weights) and that market is probably too small to justify the expense.
SCAT15F
Wed Jul 12, 2017 6:28 pm
This is the arena where the A350's significantly superior wing loading comes into play. Lots of room to for growth without significantly affecting performance.
Never been a fan of Boeing's 25 year-long high wing loading approach to aircraft design.
WIederling
Thu Jul 13, 2017 6:56 am
788 is a production nightmare and "incompatible with the 789/-10.
789 got beefed up quite a bit. ( see the significant OEW increase despite
a strong drive towards slimming down the frame during redesign.
Boeing would have to redo the 788 as a 789 shrink. ( as happened to the 737-7.)
( Won't happen due to lackluster interest in the frame. 788 will be discontinued.
Newbiepilot
Thu Jul 13, 2017 11:27 pm
I agree that another weight model isn't a industry changing initiative. Most planes have between 5 and 15 weight options with higher MTOWs and varying MZFW and MLW. Raising MTOW and MZFW at the same time is less common. Customizing weights helps airlines with their specific needs. It is also very profitable since Boeing and Airbus charge more money for higher weight configurations even though it is just a software change and minor modification to the landing gear.
For reference (not meant as A vs B, but comparing two large twins), the MTOW range from basic to maximum on the 777-300ER is from 700k lbs to 775k lbs.
Here are some 747-400 numbers (excluding the ER)
One difference we are seeing now with the 787 and A350 is that the airframes aren't designed using the most powerful engines available. It used to take years for engine thrust to increase as engine manufacturers created more and more powerful versions. Now the A350 and 787 have engine thrusts customized for the airframes so it doesn't take years for MTOW increases.
Of course this won't stop some members of the Airbus fan club, many of whom have never seen an Airplane Flight Manual in their lives, from raving about how great Airbus is and also slamming the 787.
trex8
Sat Jul 15, 2017 3:30 am
KarelXWB
Sat Jul 15, 2017 2:00 pm
FYI here are the current A350-900 weight models as certified by the EASA.
A new 277t MTOW variant has been added. Airbus also offers 210t and 280t models, but those have not been certified yet.
https://www.easa.europa.eu/system/files ... 6%2030.pdf
WIederling
Sun Jul 16, 2017 9:10 am
Glasshouse, stones and all that.
That graphic is about worthless without proper tagging of who is who in that presentation.
Users browsing this forum: No registered users and 41 guests
