Faro
A350 vs NEO/MAX Noise Suppression
Mon May 22, 2017 11:09 am
I had the opportunity to witness one of QR's A350's land at GVA recently and the low level of the noise on final approach was amazing.
Will the NEO/MAX have as good noise suppression characteristics compared to the A350?
Faro
StereoTechque
Re: A350 vs NEO/MAX Noise Suppression
Mon May 22, 2017 1:15 pm
Engine noise is caused due the shearing effect caused by high velocity of the gases exiting the engine. Modern turbofans however derive thrust more from the bypass duct rather than the core. NEO/MAX engines are using bypass ratios upto 12:1. So definitely the noise emitted is less compared to older engines
precure787
Fri May 26, 2017 6:49 am
The NEO/MAX would be quieter than the A350, given the bypass ratio.
masi1157
Fri May 26, 2017 9:24 am
StereoTechque wrote:
Engine noise is....
...not the major noise source during the landing he observed.
Gruß, masi1157
StereoTechque
Sat May 27, 2017 12:41 pm
Engine noise is....
Gruß, masi1157
I didn't notice he said during landing. :) But definitely it reduces noise by a small margin. During approach the major noise sources are Apu and deployed devices (L/G, flaps, slats).
M564038
Sat May 27, 2017 12:54 pm
Engine noise is....
Gruß, masi1157
On most A320s the loudest percieved noise for much of the approach is actually a resonance from air passing over the fuel vents.
StereoTechque
Sat May 27, 2017 1:52 pm
They have reduced the noise by adding a vortex generator just forward of the fuel vent on newer built frames including the NEO.
Link :arrow: http://www.euractiv.com/section/transpo ... aft-noise/
M564038
Sat May 27, 2017 4:20 pm
Yes. That is why I wrote "most" for simplification.
Users browsing this forum: gregorygoodwin, SamYeager2016 and 41 guests
