kabq737
Boeing 737 Interchangeable Cockpit Items
Thu May 18, 2017 11:24 pm
Hi all,
A long time ago I saw a photo here on A.net of a Boeing 737 classic series with a PFD that had brown borders. This would imply that the PFD on that aircraft came from a 757 or 767. Is this possible? Are the PFDs on early 757 and 767 aircraft interchangeable with the PFDs on 737 classic aircraft? I also saw a photo of a 737 NG aircraft using a 737 classic FMC. Does the FAA let airlines interchange parts like this?
Thanks for all of your answers and information!
320, 321, 333, 733, 73G, 738, 739, 744, 752, 764, 789, C208, CR7, CR9, BE20, MD88, MD90, E70, E90, TRIM, SEEKER
BravoOne
Re: Boeing 737 Interchangeable Cockpit Items
Fri May 19, 2017 1:26 am
Yes to all of the above, but when you get into the FMC/CDU there are a lot of restriction. Obviously a 757 FMC will not work in a 737.
kabq737
Fri May 19, 2017 1:56 am
Interesting. So it just depends on the model but it is possible and legal to swap some components from one model onto a completely different model?
N353SK
Fri May 19, 2017 3:30 am
When you say "FMC" I'd assume you're referring to the keypad/screen unit. This is called the Control Display Unit (CDU) ... the actual FMC computers are located elsewhere. I've flown on fleets with different, interchangeable CDU units ... the main difference was CRT vs. LCD, but it was common to see two different versions in the same aircraft.
kabq737
Fri May 19, 2017 4:17 am
Oops my bad yes I am referring to the CDU! Do you have any specific examples? I'm just curious about this stuff I hope you guys don't mind!
77west
Fri May 19, 2017 6:05 am
If you think about it, a screen is a screen, so as long as it is the same part number or an approved part, there is no reason why you couldn't swap them around.
77West - AW109S - BE90 - JS31 - B1900 - Q300 - ATR72 - DC9-30 - MD80 - B733 - A320 - B738 - A300-B4 - B773 - B77W
fr8mech
Fri May 19, 2017 12:42 pm
As long as the part numbers show up in the respective IPC's, there's no reason not to be able to do it.
I haven't looked at it in a long time, but there was a time when the FDR was common across our fleet (B747/B757/B767/MD11), except the A300.
When seconds count...the authorities are minutes away.
BravoOne
Fri May 19, 2017 1:45 pm
Boeing uses the term FMCC in lieu of FMS so it gets confusing at times. I do not know if a FMC/CDU is interchangeable between models but I doubt it. Maybe 757 to 767 Pegasus but even that has me doubting it. There so many sub sets of these FMC/CDU that one really needs to be careful when applying this logic.
kabq737
Fri May 19, 2017 2:33 pm
So it sounds like it's a case by case thing. Nothing is guaranteed but it is possible in some cases.
Thanks for the help guys!
