Bdlgr
Checkride failures
Mon May 15, 2017 10:07 pm
So I just busted my Instrument checkride and it got me thinking how many checkrides can you fail and still get a job in aviation? This is my first one yet and I made a dumb mistake that's easily fixable but it's got me worried. Has anyone here ever failed a checkride? How did you respond? Thanks
CriticalPoint
Re: Checkride failures
Mon May 15, 2017 10:17 pm
A failed check ride is not a death blow. Just own it, don't make excuses and be honest with the interviewer and more importantly yourself. As long as you don't make a habit of failing the airlines won't hold it against you.
Learn from it pick your head up and move on.
molitvic20
Mon May 15, 2017 10:54 pm
I failed my Instrument check ride back in the day, and my current job didnt even asked about it when I put it down on my application. Now it really depends on the situation too. If you fail a checkride multiple times, it may raise a few eyebrows. Honestly as a CFI if your consistently failing check rides... this may not be the industry for you.
32andBelow
Mon May 15, 2017 10:57 pm
Right now if you have 2 DUIs and 3 failed check rides someone will give you a shot at the sim
f35
Mon May 15, 2017 11:15 pm
As long as you're able to explain what happened and what you learned from it in a positive matter, it's not even a hurdle.
exunited
Tue May 16, 2017 1:24 am
Right now there are plenty of applicants without these impairments to their records at the US3 at least. If you want to fly an RJ forever, the regional will overlook this as things are today. Believe it or not, the sim is a mere formality, the hardest part is passing the HR/technical interview.
Tue May 16, 2017 1:31 am
Indeed. In the sim they're not looking for skill as much as the ability to listen and take instruction.
The interview is where you get the job or not. And even there getting some technical stuff wrong is not the end of the world. What they really want to see is that you are a good fit for the company, and that the other pilot won't want to kill you after sharing the cockpit with you for a few hours.
BravoOne
Tue May 16, 2017 7:06 pm
In the US your check ride failures are a permanent part of your PRIA records that every airline or employer will see during your application process. What ever you do, don't tell a lie about the failure. Tell them that you learned from the experience and your a better pilot for the experience and move on.....and up!
Users browsing this forum: jownes, kalvado and 21 guests
