Balerit
Russian aviation manufacturing
Sat May 13, 2017 7:01 pm
I was reading an article on CNN money and this caught my attention:
But Airbus wants to simplify the process, nixing slow and expensive high-pressure ovens called autoclaves. Airbus is closely watching Russia for clues, where the country is developing its own western competitor with advanced manufacturing.
What processes does Russia use?
http://money.cnn.com/2017/05/09/news/companies/airbus-a322-boeing-797/
Licensed Aircraft Maintenance Engineer (retired).
VSMUT
Re: Russian aviation manufacturing
Sat May 13, 2017 7:11 pm
The Russians use cold-curing instead of autoclaves.
Wayfarer515
Sun May 14, 2017 3:12 am
Some more info. regarding the MS-21 carbon infusion technology here:
http://www.compositesworld.com/articles ... nd-wingbox
WIederling
Tue May 16, 2017 11:35 am
IMU it is not "cold cure" you still need to heat the resin to
A: turn it to low viscosity and b: start the curing process.
IMU the first big part made via resin infusion was the A340NG rear bulkhead.
( followed by same for A380 and 787..A350 ...)
Murphy is an optimist
Balerit
Wed May 17, 2017 9:14 am
Interesting article, thanks for posting.
VSMUT
Thu May 18, 2017 8:22 am
If I am not mistaken, you still need to "bake" the part, right? Just not in the autoclave.
Balerit
Thu May 18, 2017 10:25 am
Normally you don't need to, depending on the resin used. Thermosetting resins create their own heat. Here is a link to an article on this method:
http://www.vacmobiles.com/resin_infusion.html
r2rho
Fri May 19, 2017 12:11 pm
The MC-21 will feature the very first out-of-autoclave composite wing and wingbox. This is a pretty big deal. Even Boeing with the 77X has stuck to autoclave.
Out-of-autoclave offers cost advantages, as well as greater manufacturing flexibility, such as when ramping up or down. If Irkut can pull this off consistently and reliably in series production, it is a significant advantage.
