lightsaber
Re: Boeing discussing 40-50 klbs MoM engines with OEM's
Fri May 05, 2017 4:10 pm
KarelXWB wrote:
LAX772LR wrote:
Who's up for betting that PW gets shut out of any bidding for this, relatively sooner than later?
P&W started working on the second generation GTF several years ago and aims to have it ready by 2025. They need an application for that engine.
I would love to see a Pratt. But...
Many customers of Boeing's will ask for a CFM.
RR appears to have lined up customers...
Neither Boeing or Airbus will ever offer three engines again. The added costs for three engines never pay off.
So sadly, mostly due to a poor PW1100G on wing time issues (yes, issues), Pratt will be locked out.
But indications are RR is willing to have Pratt as a junior partner. Sadly, the earlier Pratt accepts this offer, the better for them. RR has been investigating GTFs for years. Heck, Whittle proposed the idea.
Waaaaa!! I hate it when rational logic excludes my favorite. :(
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
SCAT15F
Fri May 05, 2017 7:25 pm
Devilfish wrote:
OA940 wrote:
So Boeing are looking into a 757 replacement... :hyper: :bouncy:
:shakehead: No.....a replacement for this..... ;) .....
http://www.aviationexplorer.com/Various ... 67-238.jpg
Not if they are talking 40-45k thrust, that's 753 size...
OA940
Fri May 05, 2017 9:51 pm
Yeah, but modern engines/materials could allow 762 sized planes.
A350/CSeries = bae
keesje
Tue May 09, 2017 7:54 am
Revelation wrote:
flipdewaf wrote:
If I remember correctly the 787 was touted as a 757/767 replacement and its grown into a 77E replacement.
It may have been back in the 7E7 days, but by the time they were cutting metal / baking plastic it was bigger than the 767-400 and pretty much over lapping the A330 family members ( but with an eXtra wide body allowing for 9X seating in Y ). Also the thrust and MTOW ranges always made it a long range plane.
Before the 7E7 days, I expected the 787 and A350 to be MoM's.
200-250 seat aircraft in the 3000 -5000 Nm range. Longer N/S Americas stretches, North Atlantic flights, intra Asia flights etc. are growing as is demand for short range high capacity aircraft.
http://www.airliners.net/forum/viewtopic.php?t=142541
Incorrectly obvisously :shy:
DocLightning
Wed May 10, 2017 7:31 pm
Gee, whyever? It's not as if they have managed to screw up everything BUT the gearbox (the rotor, the casing, the combustor, the oil system) on the PW1000.
It's getting harder and harder to be a PW fanboy these days.
-Doc Lightning-
-Carl Sagan
LAX772LR
Wed May 10, 2017 7:37 pm
...and the PW4092
......and the PW4098
.........and the PW4173
............and.... ;)
KarelXWB
Thu May 11, 2017 1:12 pm
LAX772LR wrote:
Sure, but that doesn't mean they'll get one, at least in a commercial application; especially if they don't have Boeing/Airbus' confidence for reliability.
Of course, you just made it sound like P&W will give up quickly. I'm convinced they will try really hard at Boeing.
LAX772LR
Thu May 11, 2017 5:22 pm
I never said anything about them not trying.
Just that I'd wager any amount against their success as an exclusive provider; and to a lesser extent, being included at all.
Too many f#ckups, on too many platforms, too recently/consistently. The risk to Boeing would be incredible.
But I will say this:
if by some fluke they did succeed, then I'd give anything to read the performance guarantees+penalties in THAT contract!! :eek:
lightsaber
Mon May 15, 2017 2:20 pm
reidar76 wrote:
TP313 wrote:
reidar76 wrote:
If the engine requirements for the MOM really is between 40,000 to 45,000 lbf, then the MOM would have a MTOW somewhere around 120 and 135 t?
How do you get to these numbers? Using latest technology example (787), for 40,000 lbf I get an MTOW from 134 to 143t.
It's just an assumption based on MTOW and engine trust requirements for the nearest sized aircraft.
Thrust per 1000 kg (1 ton) .
A321LR, MTOW 97,000 kg / 35,000 lbf = 2.77 (under-winged)
787-8, MTOW 228,000 kg / 64,000 lbf = 3.56 (over-winged)
Doing the same for the A300/A310 and the 767, gives us a thrust per 1000 kg on average between 2.8 and 3.1. For the 757, 2.6 to 2.8. Bombardier CS-300, 2.91. For the larger, ultra-long range widebodies, about 3.35 on average. The latter is the number that you used.
I made a conservative assumption of 3 t per 1,000 lbf, taking into account that this aircraft should be capable of flying into smaller airports, just like the narrowbodies, considering the folding wingtips and C-gate compatibility.
I don't think there is a right or wrong here. I don't think even Boeing have decided yet. :-)
Excellent post.
Due to folding wingtips and CFRP wings, I expect the ratio of MTOW/Thrust to start beliw 3.0 and work up with MTOW increases. I fully expect a later stretch.
Lightsaber
SCAT15F
Mon May 15, 2017 5:13 pm
LAX772LR wrote:
...and the PW4092
Out of curiosity, what did happen to the 4073?
LH707330
Mon May 15, 2017 11:10 pm
SCAT15F wrote:
LAX772LR wrote:
...and the PW4092
The 4173 required more titanium in some parts to deal with the higher temps, and PW didn't want to commit to making that change.
viewtopic.php?t=759305
SCAT15F
Tue May 16, 2017 1:12 am
Hmm. Too bad, might have been a good engine for the higher gross weight 332/333...
lightsaber
Tue May 16, 2017 2:58 am
LH707330 wrote:
SCAT15F wrote:
LAX772LR wrote:
...and the PW4092
More specifically, Pratt had to retrofit USAir's entire A330 fleet at Pratt's cost with the new parts, so that contract severely limited what Pratt was willing to change it. Sigh... My neighbor worked the PW4175! It was always intended to be the highest thrust A330 engine, but failed on compressor bleed overtemping the nacelle. Sigh...
I'm not aware of the PW4092, I know the PW4098 issues and that the PW4084 was brought up to 90k.
Let's leave the history to the actual impressive list of failures. :(
Lightsaber
LAX772LR
Tue May 16, 2017 9:05 am
IINM, they wanted to bring it up to 92k, but couldn't pass NOx... hence having it artificially limited within the USA. Main reason UA's PW 77Es are capped at 648K MTOWs.
