CanadaFair
Malaysia Airlines London routing over Pak-Afghan space?
Fri Apr 14, 2017 8:43 am
FR24 shows them using Pak-Afghan airspace once again, they had stopped doing so since the Ukraine incident and were flying through Iran and central /southern India. Right now they are doing a flight through there and heading into northern Iran, did weather force them this way?
MAS777
Re: Malaysia Airlines London routing over Pak-Afghan space?
Fri Apr 14, 2017 10:42 am
And the issue is..?
It's the same routing as SQ318 currently following behind it..
anshabhi
Fri Apr 14, 2017 10:47 am
Even Indian aircraft fly over Pak airspace, though they are restricted to FL300 & above if it's not an emergency.
I got some real work to do now. Bye!
CanadaFair
Fri Apr 14, 2017 12:08 pm
MAS777 wrote:
And the issue is..?
Issue was they had were avoiding that space after the Ukraine event, saw then using it and thought WTF! seems they do so often per flightradar but not always.
None of the other carriers chose to avoid that area, SQ flies over it multiple tiimes daily sometimes whole que of SQ planes doing that.
Fri Apr 14, 2017 12:20 pm
Is the question flying over Pakistan a concern? Tons of carriers fly over especially that little corner over Lahore into Delhi that appears to be a trunk route between Europe and South East Asia.
AngMoh
Fri Apr 14, 2017 12:21 pm
Almost every flight I take between Europe and south east Asia takes that route and this has been ever since the mess in that part of the world started. However, it seems to be a very specific and well defined corridor and every flight I take has taken exactly the same route. Above India and from Iran onward, you see variations but Pakistan and Afghanistan are always the same.
Most like it is a protected corridor.
727 732 733 734 735 73G 738 739 739ER 742 743 744 752 762 772 773 77W 788 A300 A310 A319 A320 A321 A332 A333 A343 A345 A346 A359 A388 DC-9 DC-10 MD11 MD81 MD82 MD87 F70 ERJ145 E175 E190 E195 ATR72 CRJ200 CRJ700 CRJ900 BAE146 RJ85
CanadaFair
Fri Apr 14, 2017 12:22 pm
Yes, only MH chose to avoid that area for sometime.
sadiqutp
Fri Apr 14, 2017 1:01 pm
What's your source of information that MH has a policy of avoiding Pakistani And Afghani Airspace?????
I checked the history of their past days routes and they flew there multiple times this month !
CanadaFair
Fri Apr 14, 2017 2:44 pm
MH do avid this region since 2014 https://tribune.com.pk/story/865951/mal ... -pakistan/
For them its an alternate route which they have reintroduced, their main route is through the Arabian sea and Iran, unlike Singapore Airlines, Thai and Vietnam Airlines for whom Pak-Afghan is a regular route and the southern route is an alternate one, which only SQ seems to use when need be.
PatrickZ80
Fri Apr 14, 2017 7:43 pm
Also it is believed that unlike in Ukraine there are no BUK-rocket systems or similar in Pakistan and Afghanistan. This makes flying over these areas at high altitude safe since nothing can hit the planes there. At lower altitude it might be less safe, but I believe there is a minimum altitude on this route.
Danny319
Fri Apr 14, 2017 8:26 pm
This always bothers me when I fly LHR-SIN-LHR with SQ, when they fly over Afghanistan. I'm probably worried about nothing but I feel safer / more at ease when I am out of that airspace and privately I wish they avoid it altogether even if it means longer flight times and more expensive tickets. That said they wouldn't fly if it wasn't deemed safe. The views on SQ318 are good though but I prefer it they fly over Iran on that route, which can be just as enjoyable.
AngMoh
Fri Apr 14, 2017 11:08 pm
I had an employee of me flying over that area in a LH 747 FRA-SIN and they got electrical problems: cabin went dark and there was a burning smell. The captain announced: "we have a problem and need to divert. However, I don't think you will like us land in Afghanistan and Pakistan is probably not a good idea either so we will try to make it to India". They diverted to New Delhi. That was around 2010 when there was more fighting going on than now.
CanadaFair
Sat Apr 15, 2017 10:02 am
United use this airspace all the time.
anshabhi
Sat Apr 15, 2017 10:09 am
India now has another airport, Amritsar about 260 miles Northwest of Delhi with 12,000 ft runway.
anshabhi
Sat Apr 15, 2017 1:34 pm
Btw, 2 Indian aircraft have made in emergency landing in Pakistan..
One AI: http://www.livemint.com/Politics/7UW5Dk ... istan.html
Another 9W, November 2016: http://m.indiatoday.in/story/jet-flight ... 05317.html
Users browsing this forum: tb727 and 24 guests
