cloudboy
Jet-powered flying boat technical feasability
Fri Apr 07, 2017 7:49 pm
Would it be technically feasible to built a jet-powered flying boat? Something large enough for a large cabin, along the size lines of a Martin Mars. I would think you would want it capable of landing on both water and land. I am not concerned with the financial feasibility, that is a different topic so please keep that part of the discussion to another thread.
"Six becoming three doesn't create more Americans that want to fly." -Adam Pilarski
Wayfarer515
Re: Jet-powered flying boat technical feasability
Fri Apr 07, 2017 8:04 pm
Ever heard of the Russian Be-200?
https://en.wikipedia.org/wiki/Beriev_Be-200
Channex757
Fri Apr 07, 2017 8:16 pm
As Wayfarer says, Beriev have already got there first and the Ekranoplan ground effect boats are technically waterborne aircraft.
The biggest issue here is salt water. New generation engines run hot and have exotic alloys in the core. Salt water is corrosive to a lot of these alloys so making a jet powered amphibious aircraft gets a little complicated as there is the need to deal with this, and it won't be easy. There is also the general issue of corrosion on the entire aircraft and making it waterproof will add to the weight, as will pressurisation.
It points to a lot of work being needed to mitigate the problems of operating off water.
Dutchy
Fri Apr 07, 2017 8:23 pm
How about this one, Convair F2Y Sea Dart: https://en.wikipedia.org/wiki/Convair_F2Y_Sea_Dart
This was a jet fighter concept for the USN, in the fifties. So yes it is possible to build a jet powered a/c, something as large as an small jetliner, perhaps, but why would you like to?
Ekranoplan technically isn't an airplane, waterborne aircraft is a nice term for it. ;)
flyingclrs727
Fri Apr 07, 2017 8:24 pm
Besides the problems of salt water causing corrosion, wouldn't water landing gear make high speed flying problematic? If a flying boat lands on pontoons, wouldn't they cause lots of air resistance. What would be the point of her engines on such an aircraft?
BobPatterson
Fri Apr 07, 2017 8:29 pm
Bring back the Spruce Goose (using modern materials)
Facts are fragile things. Treat them with care. Sources are important. Alternative facts do not exist.
Egerton
Fri Apr 07, 2017 8:52 pm
Just for fun, Google the Saunders-Rowe SR jet fighter
Aesma
Fri Apr 07, 2017 9:16 pm
The Be-200 is on my shopping list for when I'm a billionaire, with the island to go with it.
coolian2
Fri Apr 07, 2017 9:28 pm
Ditto. I'm gutted I was too young to remember it being landed in Auckland harbour.
Q300/ATR72-600/737-200/-300/-400/-700/-800/A320/767-200/-300/757-200/777-300ER/
747-200/-300/-400/ER/A340-300/A380-800/MD-83/CRJ-700/-900
TripleDelta
Screener
Fri Apr 07, 2017 9:41 pm
Beriev had entered those waters (pun intended) far earlier - in the mid-50s to be precise - with the Be-10. A modified example (designated the M-10) had in its time held several world records in its class, including top speed (472.9 knots, http://www.fai.org/fai-record-file/?recordId=3655) and altitude (49,088 ft, http://www.fai.org/fai-record-file/?recordId=3498).
Hawkeye: "It doesn't make any sense."
Radar: "Well, none of it makes any sense. You just have to send in the right number of forms." - MASH 4077
NZPM
Sat Apr 08, 2017 3:36 am
I believe it was a Beriev A-40 Albatross that visited Auckland in the 1990s.
Spacepope
Sat Apr 08, 2017 4:12 am
The us was flying the Martin Seamaster in the 50s as well. Reportedly did Mach 0.9 on the deck.
WIederling
Sat Apr 08, 2017 4:46 am
A flying boat never lands on pontoons :-)
Amphibians land on pontoons.
Murphy is an optimist
kurtverbose
Sat Apr 08, 2017 11:26 am
They do have outrigger pontoons though.
loranfair
Sat Apr 08, 2017 2:24 pm
Actually, only some amphibians are on pontoons. However there are plenty of amphibians that land on their hulls, for instance Albatrosses, later model PBYs, and a number of others.
cloudboy
Sat Apr 08, 2017 2:37 pm
I did not. I knew about the Ekranoplanes, but my understanding was they were never designed to be flown at altitude. Even the Be-200 looks like it doesn't have much of a service ceiling, why is this?
Sat Apr 08, 2017 3:03 pm
I'm going to go with drag. Big fat drag.
Boat hulls are draggy.
Spacepope
Sat Apr 08, 2017 3:07 pm
The Seamaster fixed this with 4 17,000 pound thrust J-75s. The whole "given enough thrust even a brick will fly" hypothesis.
Sat Apr 08, 2017 3:22 pm
True. However our beancounters would like to introduce you to this thing called "specific fuel consumption". ;)
scbriml
Sat Apr 08, 2017 11:30 pm
It was so good, it could take off uphill! :wink2:
FrmrKSEngr
Sun Apr 16, 2017 4:53 am
To be clear:
Flying boats use their fuselage for primary flotation. The fuselage is a boat.
Seaplanes float of pontoons
Amphibians can be either sea planes (e.g.Cessna Caravan or Twin Otter) or flying boats (PBY-A Catalinas , CL-215, Beriev B200)
ZyreaxPlayz
Wed Apr 19, 2017 3:51 pm
It's certainly feasible! I guess the #1 example I can give is the Martin SeaMaster. It was a test nuclear bomber/seaplane that was scrapped because of some big technical and electrical problems. Pretty neat idea, however. I do wonder, however, why you ask this question?
Bostrom
Wed Apr 19, 2017 6:53 pm
8.000 m service ceiling according to Wikipedia. My guess is that the designers considered 8.000 m enough for fire fighting, search and rescue and maritime patrol.
kurtverbose
Wed Apr 19, 2017 8:29 pm
FrmrKSEngr wrote:
To be clear:
I agree with your definitions but I'm struggling to place the Grumman Duck.
WIederling
Thu Apr 20, 2017 12:13 pm
kurtverbose wrote:
FrmrKSEngr wrote:
To be clear:
Floatplane. The float is a distinct added design element.
"flying boat" has the float function integral to the fuselage structure.
IMHO and all that jazz:
The Flying Glog ( BF138 ) still is a flying boat. https://en.wikipedia.org/wiki/Blohm_%26_Voss_BV_138
while the Mitsubishi F1M is a floatplane https://en.wikipedia.org/wiki/Mitsubishi_F1M
BaconButty
Thu Apr 20, 2017 2:23 pm
It's because they're designed to be flown in "ground effect", i.e. when you're low enough that the high pressure you create under the wing has something solid the other side to push against. Like flying wing passenger aircraft, always interesting, big theoretical advantages, always the next big thing. Until the next big thing shows up.
Down with that sort of thing!
bhill
Thu Apr 20, 2017 7:01 pm
Well of course...you take off and land INTO the current.......................... ;)
Carpe Pices
Users browsing this forum: StereoTechque and 13 guests
