Chaostheory
Re: What is the difference between the A350 and the A350ULR
Sun Oct 30, 2016 8:30 pm
Hi Zeke
I assure you there is nothing testicular in nature about the 144t OWE/OEW for Finnair's initial A350s and I have no agenda to peddle. Suffice it to say, I was a little shocked too.
Sun Oct 30, 2016 9:03 pm
Sorry
It's bullocks, the first finair airframe is msn18, our was msn29. Someone has misrepresented things significantly. You just don't get such a large variation (20% of the available payload), given we know what the MEW was for msn006.
Media reports had the initial batch around 3t overweight, what has been represented on this thread is double the problem the terrible teens had on 787.
KarelXWB
Sun Oct 30, 2016 9:16 pm
thepinkmachine wrote:
I can confirm 136T OEW, straight from the manual. This is for a slightly denser config than CX
Thank you thepinkmachine.
Clearly the newer A350s are significant lighter than the early production frames.
MoKa777
Mon Oct 31, 2016 10:17 am
Will it be possible at all for an airline to get Airbus to manipulate for them the MZFW up or down to adjust the range the of the A359ULR?
Never be proud. Always be grateful.
WIederling
Mon Oct 31, 2016 11:40 am
While obviously having to stay inside the MZFW for payload you can adjust range by tankering a variable amount of fuel.
ZFW + Fuel <= MTOW. Payload versus Range. As simple as that.
Murphy is an optimist
ap305
Thu Nov 17, 2016 8:46 pm
The SQ sfo-sin westbound flights are showing a interesting trend of climbing to lower initial cruise levels(fl320/340 vs fl360) than they did in the early days of the operation. Perhaps they are lifting greater loads with increasing confidence in the aircraft performance? The photos of the aircraft being loaded at SFO appear to show healthy amount of freight going on board.
Racing, competing, is in my blood. It's part of me, it's part of my life; I've been doing it all my life. And it stands up before anything else- Ayrton Senna
MoKa777
Fri Nov 18, 2016 7:54 am
It would be very interesting indeed to know what this standard version of the A350-900 is actually capable of on this mission and the return...
Sat Nov 19, 2016 2:11 am
FL340 would be the highest westbound level that could be achieved with MTOW, FL350 eastbound.
WIederling
Sat Nov 19, 2016 9:54 am
Why the difference in FL for the same MTOW ? ( or do we talk about different TOWs ? )
.. or do I make some principal error? )
enzo011
Sun Nov 20, 2016 9:43 am
My guess would be that the different directions of flight would have different flight levels that they operate at. I guess the maximum is FL350 but seeing as you need 1000 feet separation between westbound and eastbound flights the one will have a lower altitude than the other, even though it is capable of reaching the same altitude.
Thu Nov 24, 2016 12:42 am
Just in a nutshell how much different is the Airbus A350-900ULR (is there a short for it) from the A345 or 772LR. I know for one fuel consumption and perhaps the range...but what is that wow factor?
RacheyFlies
Thu Nov 24, 2016 1:29 am
ULR means an A350 that can reach nonstop SIN-NYC maybe like on the A340-500. But the A359 may only operate the same as the 789 does.
The best plane I've flown is an A380. They were the biggest and the best than other plane I've been on. :lol:
Stitch
Thu Nov 24, 2016 5:10 am
The dramatically lower fuel consumption IS the "wow factor".
MoKa777
Thu Nov 24, 2016 7:20 am
And also possibly that it will only be able to achieve said range with a far lower payload than the A345. I could be wrong but all I have heard and read so far points in that direction.
Amazing aircraft, nonetheless...
WIederling
Thu Nov 24, 2016 10:16 am
With a bit of penceling into the payload range chart of the regular 900
I get about 9000nm for a 29t payload.
( and a payload derate of 1t per 100nm )
A350-500 has nominal 8700 for max PAX painted in at ~29.5t payload.
( and a payload derate of 1t per 70nm or the inverse: 1.4t per 100nm)
The step in fuel economy is rather obvious.
ojjunior
Thu Nov 24, 2016 11:04 am
The difference is: The A350 is ugly and the A350ULR is ultra ugly.
MoKa777
Thu Nov 24, 2016 11:30 am
I was about to ask, what then is the point of the ULR, and then I realised that its purpose is to increase available fuel capacity since I believe that even though the standard version can do a route like this, you will need more fuel on-board than it can hold. Is that assumption of mine correct?
Also, like I asked once before but probably not clearly enough, is the MZFW on the ULR limiting? Is it only good for +-200 to allow for the extra fuel weight (since MTOW is not increasing by the same amount that the additional fuel would weigh)?
SQ is allegedly planning on only outfitting this aircraft with +-170 seats (granted, those will be fairly heavy premium seats) to operate with 20 hour endurance on some days on SIN-NYC.
If my airline wants to fly 18 hour endurance with this aircraft, and assuming 6-7t fuel per hour, can I uplift +-10-12t more? So, 100 more pax or the same 170 pax plus 10t of fish in the lower holds?
Forgive me if this is a dumb question and if I am missing something obvious.
MoKa777
Thu Nov 24, 2016 11:32 am
LOKL! That made my day!
Although, beauty is in the eye of the beholder, and I find her rather beautiful...
WIederling
Thu Nov 24, 2016 12:12 pm
afaics: no.
138kl max fuel would put the A350 in a harder endurance limit at the targeted range.
( The range / payload swapout is more than twice as high )
This is unpleasant as ejecting passengers on the way to fix your weight issues is frowned upon :-)
165kl gives you a payload range curve similar to an A330-200. i.e. you can tanker up/down? to about zero payload.
280t (MTOW) - 165kl * .8 ( max fuel mass ) ~= 148t
178 business class seats ( @ 100..140kg) could present 18t..25t of the OEW.
MoKa777
Thu Nov 24, 2016 12:21 pm
So it is quite a robust aircraft.
ojjunior
Thu Nov 24, 2016 2:00 pm
Absolutely pal...
That's why I won't apply for a position at Airbus' design team but Boeing's.
But I need to be honest, no matter how ugly they can be outside, flying the A350 was pretty comfy.
Stitch
Thu Nov 24, 2016 5:13 pm
Yes, the maximum payload of the A350-900 is around 10,000kg less than that of an A340-500, but on a ULR mission you can't lift your maximum structural payload due to the weight of the fuel, so it's not really going to be an issue.
Physical tank volume is the same across all models of the A350XWB family, but actual usable volume differs per the model. In the case of the ULR, the usable volume is 165,000 liters, which is 15,000 liters more than the baseline A350-900.
ULR missions trade payload weight for fuel weight so no, the lower MZFW (I'm guessing 190,000kg or less) doesn't impact your payload because you're already limited on how much you can carry.
WIederling
Thu Nov 24, 2016 6:17 pm
Independent of your correct argument ( max payload irrelevance )
The A350-900 ( non ULR ) shows max structural payload of 53..54t
ref: Airbus-AC_A350-900-1000-Nov16.pdf
The A340-500 shows max structural payload of 54t ( the -600 has 66t! )
ref: Airbus-AC-A340-500-600-Jan16.pdf
MZFW of the ULR version appears to be still open.
Stitch
Thu Nov 24, 2016 7:47 pm
Interesting. Earlier ACAPS gave the A340-500's MSP as 62,000kg and 75,000kg for the A340-600.
I'll update my numbers to reflect the new figures from the latest ACAP.
WIederling
Thu Nov 24, 2016 8:07 pm
Still have a copy around? Oftentimes interesting to compare.
could the docs have been freshened to accomodate changed ( with time ) cabin arrangements?
Boeing recently and significantly rewrote their complete set of range informations on those grounds.
Stitch
Thu Nov 24, 2016 8:37 pm
No. I overwrite the old ones as the OEMs update (and then update my spreadsheet numbers as necessary).
Looking at the design ranges (maximum passenger capacity line) in the ACAP, it's a bit lower than what Airbus quotes for the HGW models. So the data I had might have been for the HGW models, but even taking into account the higher MZFW of the HGW models, the spread looks too large. So it might very well be that the ACAPs now reflect more modern cabin outfitting and more conservative mission rules as you suggested plus using lower operating weights than the HGW models (I notice even the latest A330 ACAPs still use the 233,000kg MTOW even though you can get close to 10,000kg more).
WIederling
Fri Nov 25, 2016 8:25 am
zeke wrote:
Was the ULR offer made when the regular -900 still came with 268t "design max" MTOW ?
The 100t fuel number you gave earlier is that with or without reserves?
What I noticed: the regular 138kl fuel capacity is ~ 110t mass
Until that is maxed out the fuel for payload swap derates in a friendly fashion.
Beyond max fuel you have to derate more than twice the payload for every further mile of range.
( and the regular -900@268t should be just over the "brink" there.)
Fri Nov 25, 2016 9:57 am
Would be without alternate and reserve, that would be 2.5 tonnes for 30 minutes reserve and 2-3 tonnes for an alternate.
WIederling
Fri Nov 25, 2016 10:22 am
only 5% fuel for contingencies?
Fri Nov 25, 2016 12:56 pm
5% is the traditional number, but we often go with much less than 5%. Down to 1-2% on some flights. If you fly long haul and overfly a number of suitable alternates on the way, you don't need 5%.
bjorn14
Mon Dec 26, 2016 12:05 am
So what would a standard 2-class config on the ULH look like to achieve the 8400nm range? What is the price tag?
"I want to know the voice of God the rest is just details" --A. Einstein
Users browsing this forum: ChairmanRobbo and 7 guests
