dfwjim1
Single digit flight numbers question
Mon Oct 10, 2016 10:51 pm
I was just taking a look at flights between JFK and FLL on FlightAware and noticed that there are two flights between these airports that have single digit flight numbers, Delta #2 and Jet Blue #1. Delta's flight #2 (a lowly 717) connects off of Delta's flight #2 from LHR to JFK while Jet Blue's flight #1 is on a A321 and was one of Jet Blue's first two routes out of JFK. In the world of airline management do flights with single digit flight numbers carry a greater significance and warrant more attention than flights that carry two, three and four digits? Obviously the vast majority of the traveling public could care less about flight numbers...
Thanks for your responses.
Viscount724
Re: Single digit flight numbers question
Tue Oct 11, 2016 2:44 am
Single digit flight numbers like 1 and 2 are often used for flights the airline considers the most "prestigious". It doesn't mean those flights warrant any more attention, whatever you mean by that.
For example AA1 has been an AA nonstop JFK/IDL-LAX since DC-7 nonstop service started on that route in 1953. Even the departure time hasn't changed much in the 60+ years since. Prior to the DC-7 nonstops, AA1 had been a multi-stop LGA-LAX flight for quite a few years.
Interestingly, when AA1 (then a 707) crashed just after takeoff from IDL in March 1962, killing all 95 aboard, AA didn't change the flight number, which airlines often do after a fatal crash.
mandargb
Tue Oct 11, 2016 4:28 am
Yes, single digit flight numbers are given to those route(s) which that airline considers a most prestigeous.
SQ has been operating SQ1/2 for long time on SIN/SFO route. (even today)
masi1157
Fri Oct 14, 2016 1:24 pm
Lufthansa flights 1-9 (and further up into the 30s) are all between FRA and HAM, with FRA to BRE following in the 40s. Not exactly the most prestigeous routes in my opinion.
Gruß, masi1157
494 different segments on 97 airlines to 205 airports in 54 countries
N644US
Wed Jul 05, 2017 11:14 pm
The same thing happens with Delta. DL tends to put possible connections onto the same flight number (like how DL159 is both BOS-DTW and DTW-ICN). The 'most prestigious' flights DL has are from JFK-LHR, and as a result, flight numbers are from 401 upwards from JFK and are 1 and onwards leaving LHR.
Trust me, this flight is not the most prestigious route in the DL system -- it only connects with one, and as a result shares the same flight number.
Aviation: the field where (almost) anything can be solved using math and science.
KanaHawaii
Fri Jul 07, 2017 12:12 am
Hawaiian Airlines single digit flights represent the first routes they established between Hawaii and the mainland. For instance HA1 - LAX to HNL and HA2 - HNL-LAX. And so on.
DocLightning
Fri Jul 07, 2017 12:16 am
JL's SFO service is #1 and #2.
-Doc Lightning-
-Carl Sagan
ASQ400
Fri Jul 07, 2017 12:48 am
LY's single-digit flights are for more "flagship" runs
1/2 and 7/8 for TLV-JFK, 5/6 for TLV-LAX, etc
TLV, BRU, ZRH, CDG, FRA, EWR, JFK, DEN, SFO, AUS, RNO, SEA, YYC, YYZ, IAH, ATL, IAD, DCA, ORD, SJC, SNA
Bostrom
Sun Jul 09, 2017 1:00 pm
SAS SK1/2 are Swedish domestic flights, LLA-ARN and back. Hardly their most prestigious route.
ro1960
Tue Jul 11, 2017 3:12 pm
AF Concorde flight CDG-JFK was 001 not 1. Any reason? Most flight numbers are 3 or 4 digits nowadays so technically flight 1 is 0001.
qcpilotxf
Tue Jul 11, 2017 3:38 pm
Actually according to most reservation systems and ATC that flight is 1 not 001. AF might be different but there are no leading numbers at most airlines.
ro1960
Tue Jul 11, 2017 4:22 pm
AF has been using leading zeros on their flight numbers since the late 40s. You can see here flight 009 ORY-LGA or 065 ORY-BUE:
http://www.timetableimages.com/ttimages/af/af48s/af48s-03.jpg
It still does today.
rambleriver
Wed Jul 12, 2017 1:22 am
The leading zeros are purely stylistic and for AF only. ATC doesn't recognize them.
http://flightaware.com/live/findflight? ... ation=KJFK
Wednesdayite
Wed Jul 12, 2017 5:31 am
BA007 is now LHR to HND.
But unless I dreamt this... I'm pretty sure that BA used to have a greater sense of humor and that they sent 007 to Moscow every day.
A318/19/20/21/30/40. B717/27/37/47/57/67/77. CN235. CR2/7. ER145/190. FKR50. IL62. MD11/82/83/88. TU154.
AA AC AF AI AR AS AT AV AZ BA BW BY CO DA DL F9 FR JJ KL LH MA NW NZ OS RG SU TK U2 UA US VS WN
novarupta
Wed Jul 12, 2017 11:27 am
In an ATC callsign every digit has a significance....and often callsigns can differ from the actual flight number seen by passengers. For example, "AFR1" and "AFR001" can count as different callsigns.
CosmicCruiser
Wed Jul 12, 2017 1:02 pm
I can't say for sure but I always assumed that Fedex 1/ 2, STN-MEM-STN, was so numbered because it was the first European leg we flew. Originally though it was MEM-STN-BRU-STN-MEM where now it's one leg MEM-STN-MEM. Of course now it is a prestigious flight.
ro1960
Thu Jul 13, 2017 4:41 am
Thanks for the replies.
Users browsing this forum: DFWflightpath, DocLightning, Google Adsense [Bot] and 34 guests
