Flanker7 wrote:D6 does exist and is a non schengen bus gate. So if you arrive from a schengen destination you will need to clear immigration and depending on the day that could be busy.
VSMUT wrote:Flanker7 wrote:D6 does exist and is a non schengen bus gate. So if you arrive from a schengen destination you will need to clear immigration and depending on the day that could be busy.
Thanks. Does that mean I have to pass through the passport control under the Park Cafe?
VSMUT wrote:Is it realistic to make a 45 minute connection in Amsterdam from the B concourse (almost certainly from a bus gate) to gate D06 (the bus gate for flights to the UK)?
And speaking of which, where is D06 even located? It doesn't appear on any maps
