ikolkyo
Re: Boeing 737 MAX Production Thread - Part 1
Fri Jul 14, 2017 4:55 pm
Also Lion Air has started 737 MAX operations. First flights were today and it flew 6 flights.
https://www.flightradar24.com/data/aircraft/pk-lqj
StTim
Fri Jul 14, 2017 5:00 pm
More like Edinburgh
ikolkyo
Fri Jul 14, 2017 5:02 pm
StTim wrote:
More like Edinburgh
I just saw it descended into EDI since my last post, wonder what is going on..
Polot
Fri Jul 14, 2017 5:11 pm
ikolkyo wrote:
StTim wrote:
More like Edinburgh
Training? Positioning? Norwegian was planning on flying SWF-EDI as the inaugural route back in June. Don't know if that changed with the delay.
ikolkyo
Fri Jul 14, 2017 6:30 pm
Got some information on what the Norwegian aircraft were up to.
EI-FYA: Positioned to EDI to operate the first MAX service for Norwegian, it will be NAX1640 EDI-OSL.
EI-FYB: Positioned to BFS to operate tomorrows BFS-SWF service.
Source: https://twitter.com/AirportWebcams/stat ... 3870767105
ikolkyo
Sat Jul 15, 2017 12:13 am
Small Correction, EI-FYA will operate EDI-BDL. Both aircraft are heading straight to TATL service.
ADrum23
Sat Jul 15, 2017 1:09 am
So will WN start using these to fly to Hawaii?
ikolkyo
Sat Jul 15, 2017 4:27 pm
First of 2 aircraft for Norwegian have entered service straight onto TATL flights.
https://www.flightradar24.com/IBK1751/e19fe0d, EI-FYA will follow soon.
PlanesNTrains
Sat Jul 15, 2017 5:31 pm
Impressive start to their MAX ops.
Oykie
Sat Jul 15, 2017 8:01 pm
Impressive indeed :-)
opticalilyushin
Sat Jul 15, 2017 10:34 pm
First revenue flight in Europe, Transatlantic and I also safely assume North America for the MAX today, Belfast to Stewart/New York, followed shortly behind by an Edinburgh aircraft. They replace the regular 738s that have been operating the routes with payload restrictions recently. I wonder if the MAX has any restriction in place?
ikolkyo
Sun Jul 16, 2017 8:30 pm
N8703J seems to be flying again, has the aircraft even started rework? I know aircraft #1, 2 and 4 are currently in that phase.
https://www.flightradar24.com/data/aircraft/n8703j
hibtastic
Sun Jul 16, 2017 9:25 pm
The DY MAXs aren't ETOPS 180 cleared yet therefore they are taking a much more northerly route between EDI and the US than the 737NG on the other service.
I don't think they are capacity restricted though.
WJtter
Tue Jul 18, 2017 9:00 pm
Norwegian is having two more MAXs delivered today...Currently on-route to OSL. EI-FYC & EI-FYD.
Sooner787
Tue Jul 18, 2017 9:58 pm
Any updates on when Southwest will take delivery of their new Max's?
ikolkyo
Tue Jul 18, 2017 10:46 pm
Indeed, nice to see deliveries start to get rolling.
https://www.flightradar24.com/NAX3L/e237f2f
https://www.flightradar24.com/NAX7M/e243b92
barney captain
Wed Jul 19, 2017 12:20 am
FR shows them going NS BFI-OSL.....even empty with great winds that seems unlikely.
ikolkyo
Wed Jul 19, 2017 12:28 am
Considering that the latest 737-800 deliveries are direct BFI-OSL and there was a trip report on the Norwegian 737 MAX delivery flight with 33 passengers and crew onboard. The aircraft can handle the flight no problem.
Trip Report: https://airwaysmag.com/events/norwegian ... -operator/
travaz
Wed Jul 19, 2017 1:02 am
It seems they are following each other across the pond. Maybe they should da a formation flight!
Someone83
Wed Jul 19, 2017 7:43 am
Even a 737-800 can do this fine, under most circumstances. Almost all Norwegian's 737s have been delivered nonstop BFI-OSL
KarelXWB
Wed Jul 19, 2017 7:49 am
I believe August was mentioned several times.
Dogbreath
Wed Jul 19, 2017 8:41 am
Not a problem in the slightest at all. Ryanair have been delivering 400+ 737-800's direct from Seattle to Dublin (a great circle distance of 4536nm) for well over 13 years with no issues. For info: The GC distance from Seattle to Oslo is 4552nm. Norwegian have delivered 100+ 737-800's (and now 4 MAX's) and from that tally only two -800's have not made it direct. This was not due to the distance, but on arrival to Norwegian airspace, Oslo being regulated due to Low Vis conditions, and the potential for holding exceeding fuel reserves for their Alternate diversion.
ikolkyo
Wed Jul 19, 2017 7:48 pm
The first 737 MAX for Fly Dubai is on its first flight, https://www.flightradar24.com/BOE326/e27522b
barney captain
Thu Jul 20, 2017 5:02 am
While I readily admit I'm surprised they routinely do this non-stop, to say it's "not a problem in the slightest" (at least wrt NG 800's) is hardly accurate.
Some back of the envelope numbers reveal that these flights are hardly a "gimme". My last leg in an -800 showed a burn of 22,500lbs (sorry - Yankee numbers) for 3+52 of flight time. This was just the enroute burn, not taxi or alternate. This falls very much in line with a standard NG burn of 7k lbs for the first hour and 5k lbs for every hour after that. Again, these are very rough estimates. The -800 holds 46,100lbs of fuel giving a rough endurance of 9 hrs. The flight from BFI to OSL was 8:46. Obviously they weren't landing on fumes and had adequate alternate fuel, but I would say that is near the maximum endurance for an NG (I realize these were MAX in this case).
seabosdca
Thu Jul 20, 2017 5:18 am
The longest 737 flights on record are a couple of 737-700 delivery flights BFI-BTS, 4700 nm great circle distance, about 9:30 flight time. I expect it's just a matter of time before a MAX 8 does a longer one.
barney captain
Thu Jul 20, 2017 4:15 pm
Great info - thanks!
At the risk of continued thread creep. is it safe to assume all of these flights are with normal fuel cells - ie, no ferry tanks?
KarelXWB
Thu Jul 20, 2017 4:19 pm
That's a correct assumption, no ferry tanks are installed.
ikolkyo
Sat Jul 22, 2017 7:10 pm
N8703J is doing some circuits around Glasgow airport in Montana, https://www.flightradar24.com/BOE003X/e317992
Aircraft has been very active in the past week, wonder what they are up to.
737max8
Sun Jul 23, 2017 3:09 am
^Still certifying some new equipment. Wonder if the current operators are using the current stuff. I think WN will still be first to launch a lot of the new bells and whistles up front.
ikolkyo
Sun Jul 23, 2017 3:17 am
Got any details? Curious as to what kind of equipment we are talking here.
ikolkyo
Sun Jul 23, 2017 8:31 pm
N8703J is visiting Roswell today, https://www.flightradar24.com/BOE003/e34308b
MAX 9 test aircraft also been getting a good amount of flight time since Paris, https://www.flightradar24.com/BOE901/e34183b
barney captain
Sun Jul 23, 2017 11:26 pm
Does anyone know if the MAX has achieved ETOP's certification and whether or not the WN deliveries will all be ETOPS?
Stitch
Mon Jul 24, 2017 12:17 am
The LEAP-1B engines received ETOPS-180 from the FAA and EASA last month. As of this month, the MAX 8 is still performing ETOPS and FAR testing.
737max8
Tue Jul 25, 2017 5:05 am
Sorry, not sure if I am able to share details. I just know of a few components being certified still.
For the answer to your 2nd question, look at photos of all of the WN MAX airplanes sitting around Seattle and see if you see ETOPS written anywhere ;)
ikolkyo
Tue Jul 25, 2017 4:50 pm
A6-MAX, FlyDubai #1 is up in the air again, interesting that it is operating as a FlyDubai flight on a B2 flight, https://www.flightradar24.com/FDB002/e39d232
EI-FYE is also flying what I think is a B3 flight, https://www.flightradar24.com/BOE305/e39f3c7
N8703J is still doing testing at Roswell and I expect N7379E to be flying again later.
barney captain
Tue Jul 25, 2017 5:16 pm
Good info - thank you!
barney captain
Tue Jul 25, 2017 5:25 pm
I don't see anything, but I'm not sure that's conclusive. They may have the equipment just waiting on certification. Additionally, I asked if all will be ETOP's. Obviously some will - but how many?
Do you know?
Last edited by barney captain on Tue Jul 25, 2017 5:27 pm, edited 1 time in total.
ikolkyo
Tue Jul 25, 2017 5:26 pm
I don't see anything, but I'm not sure that's conclusive. They may have the equipment just waiting on certification. Do you know the answer?
Answer is no, WN's ETOPS 738s have them printed on the nose gear doors. The first few MAX planes that have been built so far for them do not have them printed.
ikolkyo
Tue Jul 25, 2017 6:59 pm
9M-LRD hasn't flown since July 3rd and 9M-LRF has yet to fly its first revenue flight since delivery on June 29th are there issues with LEAP-1Bs? I know -LRD had a delayed EIS because it was delivered with loaner engines for delivery and it had to wait for new engines to be shipped so I wonder if that is the same issue with -LRF,
barney captain
Tue Jul 25, 2017 7:09 pm
They also have it on the aft fuselage just beyond the service doors - but again, is the absence of that conclusive for aircraft that don't yet have certification? Dunno.
ikolkyo
Tue Jul 25, 2017 7:42 pm
With how many aircraft they have on order they will probably take the first few without and later deliveries with ETOPS if they want them.
KarelXWB
Wed Jul 26, 2017 11:04 am
The engine is ETOPS certified, the airframe/engine combination not yet.
https://www.easa.europa.eu/system/files ... EAP-1B.pdf
https://www.easa.europa.eu/system/files ... ssue12.pdf
737max8
Wed Jul 26, 2017 3:52 pm
Yup, this is my guess as well. Not sure which # MAX will deliver ETOPS ready but I'm sure we'll see one eventually.
ikolkyo
Thu Jul 27, 2017 3:04 am
A6-MAX is currently getting some A2A photos done, I think delivery is getting pretty close for FlyDubai.
https://www.flightradar24.com/BOE326/e3ca634
https://twitter.com/AeroimagesChris/sta ... 2989751296
ikolkyo
Thu Jul 27, 2017 5:21 pm
Southwest will receive its first 737 MAX 8 in August, they should have 10 on property by the end of the 3Q. EIS is still set for October 1st.
https://twitter.com/airkarp/status/890615736032403459
Sooner787
Thu Jul 27, 2017 9:41 pm
Looking forward to seeing those beauties at KDAL :)
KarelXWB
Fri Jul 28, 2017 10:15 am
One of the better liveries.
Boeing 737 MAX 8 flyDubai A6-MAX by Huy Do, on Flickr
ikolkyo
Fri Jul 28, 2017 5:15 pm
Indeed, beautiful livery.
ikolkyo
Sun Jul 30, 2017 12:27 am
Lion Air's 2nd 737 MAX has been delivered.
Lion Air 737 MAX 8 PK-LQF C/N 42990 / LN6344
Oykie
Sun Jul 30, 2017 7:36 am
Congratulations to Lion air and Boeing. Is this MAX number 8 delivered in total?
