phugoid1982
Why did the Soviets never try making a domestic twin IL-96 using the Lotarev D-18T engine similar to the A330 and A340?
Thu May 16, 2019 3:40 pm
I was rather bored this morning thinking of the whole quads vs. twins debate and wondered why the Soviets never attempted to use the higher thrust Lotarev D18T engine used on the AN-124 and An-225 on the IL-96? I did some calculations matching the engine out climb performance of a twin engined IL-96 equipped with D-18Ts to a quad and calculated that for this to hold the max fuel capacity would have to be almost 1/3 of the original. The max range using Breguet range equation and taking into account the TSFC of the D-18T relative to the PS-90 would translate to a still air range of approximately ~3900 miles. This would still be respectable for a domestic aircraft and the on par with the early IL-62's which did transcons. Moreover, the maintenance costs would of course be signficantly reduced. I was thinking akin to the development of the A330 and A340 where the A340 was intended to be long range version to circumvent ETOPS and the A330 relegated so shorter segments, although this obviously changed with more powerful economical engines. Any thoughts appreciated.
anshabhi
Re: Why did the Soviets never try making a domestic twin IL-96 using the Lotarev D-18T engine similar to the A330 and A3
Thu May 16, 2019 3:49 pm
After USSR collapse the economies collapsed/goals changed. Most of the Soviet civil aircraft were a spin off from military aircraft.
Further, the companies got split. For ex Antonov is based in Ukraine while most of its products were used in Russia and USSR sponsored the process as a whole.
There's a ton of material available online on collapse of Soviet aerospace industry along with USSR
dcajet
Thu May 16, 2019 3:54 pm
Probably a good dose of reality as well. In the 90s Russia was broke and any market for such a plane had evaporated. Even today, with Russia in a much stronger position, its struggles to sell its designs beyond its captive markets.
Slash787
Thu May 16, 2019 4:32 pm
And Im still waiting for the Il-96-400 to fly and hopefully be delivered to Cubana in this lifetime.
luckyone
Thu May 16, 2019 5:18 pm
That's not really the case for most of the post-war aircraft, particularly Ilyushin. The last jetliner to be produced in big numbers that was derived from a military aircraft was the Tu-134. The Tu-154, IL-62, and 86 were all purposely developed for civilian purposes.
To answer the question, at the time I would imagine the cost of development for the wing would have been beyond the means of the time.
drdisque
Thu May 16, 2019 5:30 pm
My guess is that the D-18T was designed for thrust at all cost and had poor fuel economy by modern standards.
Progress was also possibly not interested in building many more of them. They've only built 188 to date.
End result, economy may not have been better than the IL-96M.
Also, there may have been packaging issues as the D-18T was designed for high wing applications and the IL-96 sits relatively low.
workhorse
Thu May 16, 2019 8:43 pm
Also, you have to take into account that in the 90's Russia, the Il-96 was simply too big.
What was the main long haul aircraft of Aeroflot at that time? The A310. Only in the 2000's they started switching to 330s and 77Ws.
ewt340
Thu May 16, 2019 9:24 pm
They don't have enough customers.
ewt340
Thu May 16, 2019 10:00 pm
Also, IL-96 is too big for domestic operations.
The bigger question is, why don't they make a copy of B737 instead?
Pudelhund
Thu May 16, 2019 10:05 pm
Surely you mean the modernized M version? The -400 already exists and is flying, same with the -400T which is the freighter variant.
PSAatSAN4Ever
Thu May 16, 2019 10:14 pm
Spare parts.
Servicing and repair of the aircraft.
Customer support.
Soviet/Russian aircraft - while fabulous aircraft in their own right - simply don't have the sales support for airlines the way that Boeing, Airbus, Embraer, Bombardier, and all others do/did.
Slash787
Thu May 16, 2019 10:30 pm
I know, I was talking about the M version or whatever new version Cubana has on order since god knows how many years now.
PlymSpotter
Thu May 16, 2019 10:36 pm
The Il-96 was based on the Il-86, meaning the entire architecture was orientated towards it being a quad jet.
The A330/340 meanwhile was designed to be a dual quad / twin jet from the outset.
Phosphorus
Thu May 16, 2019 11:37 pm
USSR was burned once by inability to fly Tu-104 transatlantic (something to do with international rules to have diversion field handy, unless you have three engines or more). They were not about to forget that easily.
Now Il-96 and its powerplant were a result of many political and design compromises. Sufficies to say that PS-90 on Il-96 was a result of a project to standardise engine pool between Il-96 and Tu-204
A leap of faith, required to redesign Il-96 around two engines, built to maximize thrust per military requirements (and all else be damned), would be massive.
AN4 A40 L4T TU3 TU5 IL6 ILW I93 F50 F70 100 146 ARJ AT7 DH4 L10 CRJ ERJ E90 E95 DC-9 MD-8X YK4 YK2 SF3 S20 319 320 321 332 333 343 346 722 732 733 734 735 73G 738 739 744 74M 757 767 777
Ceterum autem censeo, Moscovia esse delendam
leleko747
Fri May 17, 2019 12:14 am
Just a little update to your info: as far as I know, the only 400s flying are now in service for the Russian Government. These were ex-Polet Flight, 400T version, and were converted to passenger (yes, converted from cargo to pax!!!) interior.
I wonder when people will understand:
Embraer 190 or simply E190, not ERJ-190. E-Jets are NOT ERJs!
Boeing 747-8, not Boeing 747-800. Same goes for 787.
Airbus A320, not Airbus 320.
Airbii does not exist.
phugoid1982
Fri May 17, 2019 12:59 pm
Thanks for all the replies. To clarify I was thinking the twin engined IL-96 being developed simultaneously with the long range variant in the mid 80's when the Soviets where starting to pay attention to efficiency before the collapse and subsequent collapse of the domestic air travel market. The D-18T has a 25% higher TSFC but again the reduction in maintenance is what I was focused on. Also, I know the PS-90 was notoriously unreliable and I'm wondering how the D-18T compares in that respect? Also, even though the Il-96 was based on the Il-96 the wing is completely new supercritical wing so it could've been designed to be a twin, although as was pointed out the landing gear would've had probably had to have been designed to be taller to accomodate the engine.
Funny enough, I stumbled upon this article in Flight Global about UAC studying a twin re-engined with the PD-35 under development to breath some life into the program.
https://www.flightglobal.com/news/artic ... 96-445788/
Armadillo1
Fri May 17, 2019 1:06 pm
Tu-204 was here, 734 range enough for this side from Ural only. also, its funny to see question about 737classic copy with A320 in flight
wel well, nobody heard about IL-62
Ty134A
Fri May 17, 2019 6:10 pm
First of all, an ILW or IL9 is not an 330/340 fuselage. It is only marginally below the diameter of a 777, making it a rather wide bodied plane, not allowing for engines in the thrust area where the D-18 is situated. Three D-18 engines would work, two wouldn't. And there was no need for it, fuel was not a factor, nor other economical aspects that today do count. They had IL6 for long haul, and began flying the IL9. Up to 5000km they had ILW and TU5, with the T20 on the way. And with YK2 there was a turbofan jet with actually a D-18 family engine aboard, the D-36. This engine ist still in use today as D-436 with A81 and Beriev sea planes. Soviet SU most likely favoured the D-18 for strategic transportation on the A4F. With new noise regulations and emission standards, it basically ment that the SU was left with only a hand ful of engines, the D-30KU-154 had also it's clock ticking. So there were the PS-90A and the D-36. They had the ILW and they had the PS-90, so they made something out of it. The reason for the IL9 being so stubby is, by the way, the lack of adequate soviet engines. And sure nobody thought of a 346 like ILW with four D-18... So they had to shorten the fuselage, keep the diameter and use 4 PS-90.
I remember that SU IL9 had an CASM on par with their 763. But remembering that some airlines preferred the thirsty ILW over a low numbered IL9 (spares!!!) it somewhat shows that engines were not the main issue of this airframe. Neither was safety an issue. Only one ILW very unfortunately crashed (after maintenance) and one IL9 burned down while parked. Also T20 performed extremely well safety wise, and all late Soviet frames were really good, solid/safe aircraft, but with the usual downfalls. I also preferred classic Soviet T5M over the Russian built ones, so did pilots. Same goes for ILW... Yet thair safety statistics speak for them, and deserve a certain amount of respect, considering what Boeing came up with lately...
flown on: TU3,TU5,T20,IL8,IL6,ILW,IL9,I14,YK4,YK2,AN2,AN4,A26,A28,A38,A40,A81,SU9,L4T,L11,D1C,M11,M80,M87,
AB4,AB6,318,313,342,343,345,346,712,703,722,732,735,741,742,743,74L,744,752,753,763,772,77W,J31,F50,F70,100,ATP,
142,143,AR8,AR1,SF3,S20,D38,MIH...
Phosphorus
Sat May 18, 2019 8:45 am
Well, Il-62 was a quad. Unless you are trying to convey some other point, I guess it meets "three or more engines" requirement.
exFWAOONW
Sat May 18, 2019 2:30 pm
Don’t twins require a larger rudder to compensate if they loose an engine?
Is just me, or is flying not as much fun anymore?
Ty134A
Sat May 18, 2019 5:57 pm
Depends how long they are! Ask a 74L about large rudders...
VSMUT
Sat May 18, 2019 6:26 pm
FYI, the original Il-96 stretch is just Il-96M, no -400. The freighter was the Il-96T. The Il-96-400 is the new Russianized stretch that has yet to fly, and has been ordered by Cubana. The Il-96-400M is an even newer project which also hasn't flown yet, probably mostly for the Russian MOD.
Phosphorus
Sat May 18, 2019 8:50 pm
Then what am I looking at here, airborne in 2009 (not the only photo of the type in the database, I would assume):
https://www.airliners.net/photo/Polet-A ... 0T/1574277
Does this airframe meet your definition of Il-96-400 ?
VSMUT
Sat May 18, 2019 9:16 pm
The Polet freighters would simply be Il-96T.
Phosphorus
Sun May 19, 2019 7:35 am
That would be before conversion, while still equipped with PW engines.
After conversion to PS-90 in the last decade, at least one frame got both new factory number, and designation Il-96-400.
Another frame was directly built as Il-96-400T late last decade.
So the "new" airplane in the works is the Il-96-400M, otherwise there was a to convert an existing Il-96-400T into a pax version for Cubana (frame RA-96103). Not sure what came out of that, but that's hardly a new plane, is it?
SR380
Sun May 19, 2019 1:22 pm
Last August the aircraft was photographed in VASO with many Il-96. I haven't heard much since then.
