RJMAZ
Re: Airbus offers longer range A35K for QR
Fri Jul 20, 2018 6:14 am
MoKa777 wrote:
None of us, not even Boeing, probably could have foreseen Airbus improving the A35K to the point where it will have 77L/8 rivalling range (maybe not exact range but close enough).
The thing that makes the 778 special doesn't seem so special anymore.
This is a bit ridiculous.
The A35K hasnt even reached the 777L range and is 1000nm short of the range of the 777-8 with the same payload. Boeing didnt have to forsee anything the 777-8 is still a step above anything on the market.
A 3T MTOW increase is required to match the 777L.
A 15T MTOW increase is required to match the 777-8.
The first increase is possible the second is a pipedream.
Mrakula
Fri Jul 20, 2018 7:38 am
You are probably right but when you calculate fuel burn per hour from your calculation B777-8 will burn at least 5% more fuel per hour than A350-1000 that is big diffrence. If you can reach that range with slightly less payload burning a lot of less fuel that will not justify more capable frame. But it is only theory without accurate numbers.
RJMAZ
Fri Jul 20, 2018 10:16 am
The 778 might burn less fuel than the A35K
The 777-8 definitely wont burn 5% or more fuel per hour. I would estimate the 778 will burn within 1% of the fuel of the A35K when taking the same payload the same distance.
Fuel burn is easy to calculate. You need surface drag, lift to drag ratio and engine SFC.
The 778 and A35K fuselages have equal drag, identical volume and wetted area. To push them through the air requires the same amount of thrust.
Aircraft flying weight has a lot to do with fuel burn. Add 40T of payload and 120T of fuel to both aircraft and the A35K will weigh 315T and the 778 will weigh 328T. The 778 will weigh only 4% more. So far the 778 should burn 4% more fuel but that would assume the wings and engines are the same.
Now the wings come next as they are used to determine lift to drag ratio. Each A35K wing has a span of 29.38m. Each 778 wing is 32.8m. The 778 has a massive 12% greater wingspan. This wingspan advantage gives it a superior lift to drag ratio. It would easily offset that 4% weight disadvantage when it comes to the amount of thrust required to push it through the air. Fuel burn is probably close to identical at this stage.
Last but not least we have engine SFC. The GE9X is predicted to have slightly better fuel burn than the trent XWB. This would then allow the 778 to burn less fuel than the A35K.
So when the A35K is at maximum takeoff weight the 778 would be around 20T below its maximum takeoff weight while taking the same payload the same distance. This allows the 778 to tank an extra 20T of fuel to fly 1000nm further or load the belly with cargo. On a 7000nm route the 778 would be able to carry 40% more payload while having sinilar fuel burn.
StTim
Fri Jul 20, 2018 11:30 am
Why aren’t the airlines signing up for 778’s then? It is a very nice plane.
par13del
Fri Jul 20, 2018 11:48 am
Same reason why airlines are not lining up for the A359K and Airbus is talking about increased range, they are both nice planes so something else must be afoot...
tommy1808
Fri Jul 20, 2018 3:34 pm
Stitch wrote:
tomcat wrote:
An A359 fuselage with the A35K wing / landing gear / engine would be a very interesting basis for a freighter.
At launch, Airbus discussed a possible future A350-900F using the landing gear, operating weights (at the time, 295,000kg) and engines from the A350-1000.
With the weights the A35k is throwing around now, it probably makes an excellent base for an cargo aircraft. What would fit? 100+LD3, 44LD3+ 30-32 pallets or 44-46 pellets ?
Best regards
Thomas
mig17
Fri Jul 20, 2018 3:47 pm
I don't understand the hipe around the 778 being a perfect base for a futur cargo plane. Even if it is technicly true, from a market point of view it makes no sense. Boeing is already selling the 3 best frigthers out there, 767F, 777F and 748F. Airbus tried to compete with the A330F and did not realy make it. A 778F would simply kill 747 and replace the 77F based on the LR version.
It seems to be a big investment for no gain at all.
mig17
Fri Jul 20, 2018 5:00 pm
On the A35K front, more it will gain in payload range capability, more the A350 family will detached itself from the 787 for prenium or longer mission and more it will make the 777X a niche aircraft being far more flexible than the 8 and closer to the 9.
Mrakula
Fri Jul 20, 2018 5:54 pm
In terms of drag cross section of B777 has more drag than A350. In general, more wing span and area has also more drag but it depends also on a profile of the wing. Bigger engines more drag also. Heavier frame needs more lift and it comes with more drag in general. Engines will have slightly better SFC but also more thrust so fuel burn per hour could be higher anyway. Also climbing of the heavier A/C consumes more fuel.
B778 can lift more payload further but it could burn more fuel. If burn similair fuel with 40% more paylod Ohhh Jesus it will be huge diffrence and A35K will be left in the ashes:-)
RJMAZ
Sat Jul 21, 2018 1:07 am
Cross section only plays a small part. The length of the tube is also very important. The A350 is a longer tube so total fuselage drag is nearly identical between the two. For instance the 787-10 has more drag than the 787-9 if both aircraft are at the same max takeoff weight the 787-10 will require more thrust to move through the air.
Wing area is nearly identical but the 777-8 has a massive aspect ratio advantage. So similar drag but greater lift in favour of the 777-8.
The 777-8 wing produces more lift than than the 4% weight increase. It will be able to climb faster while burning less fuel. Thats how lift to drag ratio works.
The 777-8 will have less drag than the 777-9 due to the shorter fuselage and less wetter area. So with equal engines it means the 777-8 is slightly overpowered. This will allow it to climb quicker and fly higher reducing fuel burn.
The A35K has a lower service ceiling than the A359 partly due to the smaller wing on the larger frame.
Usually aircraft get a big surge of orders after the first flight. The A35K got no surge which suggests the market demand is not as strong. The 777X has not flown yet so final judgement of its sales success should wait a year after the first flight.
The A350 family has a payload range advantage over the 787. The 777X family has a similar payload range advantage over the A350. Any argument that says the A350 is superior to the 787, that same argument can be used to explain why the 777X is superior to the A350.
ZK-NBT
Sat Jul 21, 2018 1:33 am
The thing is many airlines replaced 744’s with 77W’s, sure it was the best frame for the job by some distance for most, however how many airlines will upgauge again to the larger 779? Yes I’m aware it’s about operational costs etc but also which of A or B gives the better deal. I am really interested particularly for NZ and QF as to which way they go as a 772 replacement for NZ and project sunrise for QF, if QF go 778 they are more likely to get some 779’s aswell ditto for the A350.
WIederling
Sat Jul 21, 2018 6:55 am
MZFW doesn't significantly grow with the MTOW increases. I don't think they can push payload through the roof. needed for turning the MTOW markups into a good freighter option.
Mrakula
Sat Jul 21, 2018 11:42 am
787-10 has more powerful engines 76k pounds vs. 787-9 71k pounds.
A330NEO has higher aspect ratio then 787 and slitl is less efficient.
Where you got 777-8 produce more lift with same wing area??? Still is much heavier!
With same TOW it will climb similair to bigger sibling. Lift with same power cannot go faster then lighter one it is physics:-)
777X does not flying yet so that is only speculation:-)
Sorry but you bent facts us you like
SQ22
Sat Jul 21, 2018 5:14 pm
As well as the back in the days so called A350-900R (not to confused with the A350-900 Regional) to carry passengers which would have been the base model for the freighter.
RJMAZ
Sun Jul 22, 2018 3:25 am
Exactly as I said 787-10 has more drag than the 787-9 so it needs nore thrust at the same weight.
The wing tips make the 30 year old A330 wing nearly match a 10 year old 787 wing. Its not the same as the 777X vs A350 which are both recent brand new wings. In this case the wing with the higher aspect ratio wins and the 777X is newer so it will most likely have some newer technology.
Wingspan is just as important as wing area when it comes to lift. So with equal area the wing with greater span will produce more lift. This is fairly basic aerodynamics.
Climbing has a large portion of horizontal flight. The longer aircraft will have more drag so it will require more thrust to move forward even though the weight is the same. So if the 777-8 and 777-9 both take off a full throttle at 350T weight the 777-8 will climb faster.
Its pretty easy to calculate.
kevin5345179
Sun Jul 22, 2018 6:23 am
1. GE is actually working on increasing GE9X thrust because 777X will climb too slow .... In fact, 77W climb so much slower than A350 flying on the same route. With identical MTOW and further reduction in engine thrust, the performance only gets worse ......
2. The OEW for 778 is 13 tons more than A35K and that's almost 10% of the OEW. There is no way the fuel burn will be within 1% for same payload and flying same distance. Physics doesn't add up .....
ap305
Sun Jul 22, 2018 6:45 am
EH? I thought the folding wingtip lightweight megawing would provide enough lift to ensure that there were no climb issues?. Clark and Al Redha have taken a big gamble by chucking their lot in with Boeing and dumping the a350... Hopefully its not going to come back to bite them later on.
JustSomeDood
Sun Jul 22, 2018 6:51 am
What the 77W does against the A35(9) in terms of climb performance is irrelevant, given the 777X will have a much more aerodynamic, higher aspect ratio wing that generates more lift for a given airspeed and altitude. (Not to mention that the A35K has a "worse" wing, aerodynamically speaking, than the A359 due to the lower AR)
ap305
Sun Jul 22, 2018 6:57 am
Airbus actually improved cruise performance with the trailing edge extension to the -1000 wing.
Planesmart
Sun Jul 22, 2018 9:26 am
Wasn't climb performance previously very relevant when comparing the 777 to A340?
JustSomeDood
Sun Jul 22, 2018 10:14 am
Read the original post I was replying to, extrapolating the 777X's climb performance from the 77W is a pointless and dumb endeavor since the wing that generates the lift is totally different for the former vs the latter.
mig17
Sun Jul 22, 2018 10:21 am
You estimate the 778 will burn within 1% of the fuel of the A35K when taking the same payload the same distance and to proove that you "calculate" the efficiency of both plane for the same payload over the same range ... with the same fuel on board. So yes only 4 % more weight for the 77X which with slightly more efficient aerodynamics has the same fuel burn. You are turning in circles. Now what happens if you add a few more tons of fuel to carry the heavier 778 plus 40T payload over the same distance? Which is more realistic since even if the 77X has better aerodynamics, he still is heavier.
waly777
Sun Jul 22, 2018 1:06 pm
No offence but i will politely have to call BS on number 1 as performance data has not been publicly released for the 77X and GE9X seems to remain a 105Klb engine. What the 77W lacks in wingspan, it makes up for with excess thrust. The 77X on the other hand has a mild reduction in thrust coupled with a larger and more aerodynamic wing.
How did you arrive at 77W vs 359 climb ability? Same %payload? Same % fuel? Same %derated thrust? Same ATC restrictions? The 77W is no slouch during the climb phase.
Mrakula
Sun Jul 22, 2018 4:10 pm
As you said 30year old wing wit new wing tips is competing with 10 year old wing. I am not expecting 777X wing and engines can bring enought margin over A350 to make it more efficient with such hevier frame!
In climbing weight will make higher impact than drunig cruiser so I do not expect 777-8 will climb much faster then 777-9. In cruise that will be another story.
Per Lufthansa known comparison fuel burn per pax of A350-900 is in pair with 777-9. That means 777-8 would be slightly worse but Im expecting A350-1000 will be in pair with A350-900 or better!
Stitch
Sun Jul 22, 2018 4:38 pm
The 777X wing is based on the 787's wing, not the original 777's wing. So it is on a similar "tech level" as the A350.
anrec80
Sun Jul 22, 2018 5:07 pm
ap305 wrote:
As far as performance is concerned AAB already stated that aircraft is beating spec and CX will shortly introduce it on a 17:30 hr mission.
Hmm - which mission is that? I always thought CX was never into ULH business.
aemoreira1981
Sun Jul 22, 2018 5:14 pm
Airbus should also invite Delta Air Lines and Qantas for their input. D: will eventually need an aircraft that can do ATL-JNB without significant penalty on the worst days, and right now, only the B77L can do it among twinjets (did management at the time ever consider the Airbus A340-500 or -600)? Qantas would want an aircraft that can do SYD-LHR or JFK nonstop both ways in a 3-class configuration (and they have already pushed the B789 to its absolute limit.
Besides the ME3, I can think of these airlines desiring an MTOW increase on the A35K:
Americas: Delta Air Lines
Europe: British Airways (to go to Australia nonstop; the B789 is too sparse), Turkish Airlines (same)
Australasia: Qantas, Air New Zealand (they have stretched the B789 to Chicago but it can't make it to Newark)
Can this be increased to maybe 320-325t?
Mrakula
Sun Jul 22, 2018 5:20 pm
I know but I was react to RJMAZ post. Comparing wing of A330NEO with 787 and A350 with 777X.
kevin5345179
Sun Jul 22, 2018 6:19 pm
heard the #1 from friends in GE
look at full load for both planes and check their climb profile and it'll be pretty obvious; especially 777 is more altitude restricted compare to A350
sabby
Sun Jul 22, 2018 6:35 pm
I think it is the upcoming HKG-IAD, the new longest CX route. They already serve ORD, JFK, EWR, BOS - quite a few of ULH routes.
OldAeroGuy
Sun Jul 22, 2018 7:52 pm
The high wing loading of the 77W is responsible for its low Initial Cruise Altitude, not engine thrust.
The larger wing of the 779 at the same MTOW will give it higher Initial Cruise Altitude than the 77W even if the GE9 has a lower thrust rating compared to the GE90-115B.
kevin5345179
Sun Jul 22, 2018 9:24 pm
actually they are related ....
lighter wingload -> better climb rate and less thrust requirement during cruise
which means you can go the opposite direction:
better thrust -> better climb rate and allow higher wingload
anyways, the 777X wing area grows 7% as compare to 77W while thrust of GE9X is only 91% of GE90-115B
7% gain in wingload and 9% lost in thrust while MTOW remained unchanged
I guess no additional comment required
waly777
Sun Jul 22, 2018 10:22 pm
The wingloading is responsible for the initial low altitude not the ability to climb. The 77W has more than enough thrust to take it very quickly to altitude as quickly as other wide body twins if not quicker than most thanks to the engines which over compensate for the perhaps slightly small wing.
By the same logic, are you suggesting the 380 outclimbs the 77W because it has a higher initial cruise altitude? You should check a few in-flight videos and you'll see this is not the case.
waly777
Sun Jul 22, 2018 10:40 pm
The % are correct but there is a false assumption that it is the same wing just made larger. It's a more aerodynamic wing using lighter materials which should further improve lift and reduce drag.
The % increase in wing area is not directly proportional to the increase in lift. The fact that the thrust was reduced is evidence the wing should be sufficient enough to not require GE-90 thrust levels.
I remember it was first planned to be a 99.5klb engine and then officially launched as a 102klb engine. It was later increased to 105klb (with a slightly larger fan) likely due to requests by the ME3 due to the heat etc.
kevin5345179
Mon Jul 23, 2018 12:16 am
simple logic:
lower wing loading -> slower stall speed -> higher AOA is allow -> faster climb rate
waly777
Mon Jul 23, 2018 12:52 am
simple logic:
Assuming thrust is equal..... and this is not the case. Thus the logic is incomplete. E.g Q400 vs ATR72. The former has a higher wingloading but will outclimb the ATR anyday.
RJMAZ
Mon Jul 23, 2018 12:55 am
Cruising attitude depends on lift. Wings are more complex than simply comparing wing area.
A 70m wing with 350m2 will produce more lift and cruise higher than a 60m wing with the same 350m2 area.
A wing with 20degrees sweep will also produce more lift than a similar shaped wing with 40degrees sweep.
This is why gliders have super long and straight wings.
You must combine aspect ratio with wing area and sweep angle together to estimate total wing lift.
30 years ago you needed 40degrees of wing sweep to hit mach 0.9 today you can hit that speed with only 30 degrees of wing sweep. 30 years ago wing aspect ratios were limited to 9:1 due to aluminium, any more span and the weight incressed exponentially eliminating any performance increase. Today with composite wings aspect ratios of 12:1 can be used on a modern airliner.
The 777X had the lowest sweep and the highest aspect ratio of any widebody. This means its wing produces more lift than its wing area suggests.
So comparing wing loading using area will show the 777X is worse than the 777W but that is simply not the case. It is vastly superior to the 777W and even more superior to the 787 and A350 in terms of lift to drag ratio.
OldAeroGuy
Mon Jul 23, 2018 1:24 am
simple logic:
No, slower stall speed does not lead to better rate of climb and the AOA is irrelevant.
Basically, Climb Gradient = (Thrust/Weight-Drag/Lift)/(1+0.467M^2) for a constant Vi climb.
for the takeoff comparison we're talking about:
Thrust: GE9X = 91%GE90-115B
MTOW: 779 = 77W
Drag: 779 = 90%77W (higher wetted area drag is more than offset by the higher span and reduced induced drag along with other aero technology improvements including a variable camber wing
Lift: 779 = 77W
So
779 Thrust/Weight = 91% 77W Thrust/Weight
but
779 Drag/Lift = 90% 77W Drag/Lift
The higher T/W of the 77W is offset by the lower D/L of the 779.
The 779 climb gradient should be at least as good if not slightly better than the 77W.
OldAeroGuy
Mon Jul 23, 2018 1:27 am
OldAeroGuy wrote:
simple logic:
MTOW: 779 = 77W
Lift: 779 = 77W
So
but
At the same time, the 779 Initial Cruise Altitude should be better than the 77W due to its lower wing loading.
Casablanca
Mon Jul 23, 2018 6:56 am
A little off topic but just comparing a real world 15 hour flight today on A359....maxed takeoff, zfw limited, hauling 30 tons
same flight time on 77w, maxed out, zfw limited, hauling 44 tons
approx same time on 77LR, hauling 38 tons payload but could take another 23 tons of payload and fuel.
don't have anything on A35k
Just some very rough calculations , and 350K will be better, but wouldn't describe it as a game changer.......slight improvement but for the latest and greatest I would hope so.
ap305
Mon Jul 23, 2018 7:01 am
Not off topic but not factual.... As has been pointed out to you before, you are wrong. The a350 hauls close to 40t on ewr-hkg which is 15:30min on a daily basis. As zeke has pointed out, beyond 13hrs the a359 has a payload advantage on the 777w.
RJMAZ
Mon Jul 23, 2018 7:14 am
Were all three flying the same route?
A350 would be a 268T model yea?
Casablanca
Mon Jul 23, 2018 7:38 am
the 359 is a 275 ton model
not same route...but flight time with minutes of each other, except the 77LR was additional 25 minutes further
mtow....275, with fuel load max zfw was a 30ton payload
be very interested to see ac dry operating weight that allows another 10 tons
Casablanca
Mon Jul 23, 2018 7:45 am
I have found some of the very newest 359 with about a 5 ton drop in OEW..... obviously that makes a difference
Boeing74741R
Mon Jul 23, 2018 8:19 am
I'm not convinced about BA wanting an aircraft to go to Australia non-stop, or more specifically LHR-SYD. That route looked like it was going to be culled a few years ago, but it was saved by swapping the aircraft to a 77W and using Mixed Fleet crew. The real test will be if that route survives an economic downturn, because if it doesn't then it's a waste of time acquiring a small sub-fleet for one route.
In any case, Willie Walsh appears to have ruled out BA running non-stop UK-Australia services and seems happy to leave that to Qantas whom they can code share with. If anything, returning to other cities such as Melbourne is more likely than non-stop, but who knows what the future holds...
https://uk.reuters.com/article/uk-airli ... KKCN1J200Z
http://australianaviation.com.au/2018/0 ... australia/
talonone
Mon Jul 23, 2018 10:49 am
What!?!?!?!?!
Let's if I get that clear.
So a plane that has more.weight, a bigger wingspan, a bigger thrust, will be able to carry 40% more payload????
:lol: :lol: :lol:
Do you have the formula how to build a "perpetum mobile" also!?
RJMAZ
Mon Jul 23, 2018 12:29 pm
talonone wrote:
What!?!?!?!?!
That is correct.
Why is it so hard to understand?
An aircraft can weigh fractionally more yet burn the same fuel. It is called progress.
If you combine a bigger wing and more fuel efficient engines then it can carry more payload with the same fuel burn.
If you look at a payload range charts you can see payload weight suddenly drops away at a certain point.
787-9 it drops at 7500nm
A350 it drops at 8000nm
777-8 it drops at 8500nm slightly better than a 777LR.
At 7500nm range there is only a 10-15% payload difference between the three aircraft. However once you hit 8000nm the 787 drops away first. The A350 can carry nearly 50% more payload than the 787 at this range.
At 8500nm the same thing happens with the A350 dropping away. The 777-8 can carry 40% more payload and more than double the payload of the 787.
talonone wrote:
:lol: :lol: :lol:
I do, it's in my cabinet where I keep all my awards and trophies I've received for my work in aerospace engineering.
Mrakula
Mon Jul 23, 2018 4:16 pm
RJMAZ wrote:
talonone wrote:
What!?!?!?!?!
That is correct.
According to ACAP for A350 and your propositions A35K MOTW 308t on 8500nm trip can carry 124t fuel with 29t payload while 777-8 carry 143t fuel and 40t payload. Am I right?
Exeiowa
Mon Jul 23, 2018 5:23 pm
But is it economically viable to produce the number of planes that would use this capability at 8000nm. How many city pair routes does that apply to and how frequently could they get flown, once you have that number then you can figure out how many frames would get ordered and how many the cost gets spread across. Then consider if you can move your freight with a stop and don't burn fuel to move fuel if it still makes sense. Then we can worry about efficiency.
frmrCapCadet
Mon Jul 23, 2018 6:53 pm
Rather than contentious posts a really useful thread for us less technical folks would be particularly niches every model of plane does well or better than any other plane and why. It might also include examples of older planes which do well because of low capital costs. RJM... that last post of yours is the sort of thing that makes it clearer to us non-techs.
