BENAir01
Busiest airports without full length taxiways
Tue May 22, 2018 2:02 pm
I was scrolling through Wikipedia and found that Malta airport carried over 6,000,000 passengers last year, however MLA does not have full length taxiways, and as such requires backtracking followed by a 180 in the runway before takeoff or after landing.
LTN had almost 16,000,000 pax yet also doesn’t have full length taxiways, although the backtracking required at LTN is less than that at MLA.
Any other relatively large airports tha require backtracking? Does anyone know what the biggest one is?
User001
Re: Busiest airports without full length taxiways
Tue May 22, 2018 2:07 pm
While not quite as busy, Leeds Bradford (LBA) and Funchal Madeira (FNC) require backtracking for full length runway usage.
Andy33
Tue May 22, 2018 2:10 pm
London City (LCY) has 4.5 million passengers a year and no full length taxiways.
airtrantpa
Tue May 22, 2018 2:30 pm
SXM doesnt have taxiways
AVL as well, well maybe once the new runwayis completed
george77300
Tue May 22, 2018 2:38 pm
Florence carried 2.5million and that has virtually no taxiways. Full backtrack required on landing.
Newbiepilot
Tue May 22, 2018 2:42 pm
Male has no taxiway at all. Airplanes pushback onto the runway. Probably one of the only airports in the world that has multiple widebodies on the ground at the same time and no taxiways
winGl3t
Tue May 22, 2018 2:51 pm
I guess Porto, Portugal (OPO), must be on TOP 3: +10,7 million passengers in 2017.
Quite a few busy airports in Brazil too:
Porto Alegre, Brazil (POA): +8 million passengers
Curitiba, Brazil (CWB): +7,2 million passengers
Fortaleza, Brazil (FOR): +5,7 million passengers
Florianópolis, Brazil (FLN): +3,8 million
Belém, Brazil (BEL): +3,2 million
FatCat
Tue May 22, 2018 2:53 pm
And on takeoff too, as planes should take off heading southbound; northbound departures are possible, but with restictions on weight.
Last time on the flight to FRA we had to disembark 8 passangers to take off northbound. Plane was an Air Dolomiti E195.
Northbound takeoffs are a thrill, as wet landings are.
NZ321
Tue May 22, 2018 3:13 pm
WLG New Zealand was around 6M+-
ZaphodHarkonnen
Tue May 22, 2018 3:17 pm
Pretty sure WLG has a full length taxiway. https://www.google.co.nz/maps/@-41.3276 ... a=!3m1!1e3
FlyHappy
Tue May 22, 2018 3:22 pm
ha! ya made me look!
that's not an airport, its an airstrip with some "stuff" nearby ;)
but somehow perfect for the ocean paradise feel.
rbavfan
Tue May 22, 2018 3:42 pm
Arial views in Google earth show reclaimed land being done opposite side of current terminal with plenty of space to do a real terminal.
rbrunner
Tue May 22, 2018 3:51 pm
[quote="winGl3t"]I guess Porto, Portugal (OPO), must be on TOP 3: +10,7 million passengers in 2017.
Absolutely. The taxiway only goes about halfway down the runway. Quite a bummer when the airport is operating in LVO and rwy 17 is the active rwy...
Thibault973
Tue May 22, 2018 5:07 pm
FOR does have a full length taxiway, POA an almost full length one, as for FLN, one of its 2 runways does have a full length taxiway
Rafabozzolla
Tue May 22, 2018 5:58 pm
Lisbon deserves a special mention. At nearly 27M pax in 2017 it does have a full length taxiway, but each part on a different side of the runway. To reach the treshold of runway 21 planes must cross it.
BoeingGuy
Tue May 22, 2018 6:36 pm
KTM doesn’t have full length taxiways either. Domestic prop planes do a mid field takeoff from where the taxiway ends. Jets enter the runway at that point and back taxi to the end.
Virtual737
Tue May 22, 2018 6:37 pm
PNH / VDPP Phnom Penh requires backtracking for both ends for takeoff.4.3 million passengers last year.
gwrudolph
Tue May 22, 2018 6:42 pm
Does OGG or is it really just the apron connected at the ends to the runway? Seems to me that I was there once and we had to taxi to cargo area to wait for a gateand it got very messy trying to get back to the gate because we were going against pushback traffic on the apron
airbazar
Tue May 22, 2018 7:08 pm
I'm pretty sure those are different taxiways so LIS definitely counts.
zrs70
Tue May 22, 2018 7:33 pm
Gibraltar comes to mind.
Kadish
Tue May 22, 2018 7:37 pm
Lanzarote if I’m not wrong
BENAir01
Tue May 22, 2018 10:41 pm
Except you are wrong ;)
Not to be rude haha. But yes, ACE does have full length taxiways.
BENAir01
Tue May 22, 2018 10:42 pm
I wouldn't count it. Yes, you do have to cross the runway, but you dint have to backtrack or back taxi so Id say its good.
noviorbis77
Tue May 22, 2018 10:47 pm
Islamabad Airport (Benazir Bhutto).
The runway is the taxiway.
A350OZ
Tue May 22, 2018 10:48 pm
Canberra (CBR) is the same, but I wouldn't count this as no backtracking on an active runway is required.
Downunder, CNS (5.2m pax, #7 in Australia) and ZQN (2m pax, #4 in NZ) would be the largest that qualify in those countries.
Q
Tue May 22, 2018 10:49 pm
An old airport Islamabad is closed now and moving to new airport Islamabad has better runways and taxiways than previous. Just few weeks ago opened.
Q
Q
Tue May 22, 2018 10:51 pm
There is a little bit no taxiways in Burbank end of runway 26. It has apron ramp connect runway 8-26.
Q
77H
Tue May 22, 2018 11:20 pm
OGG has a full length taxiway for runway 2/20. Runway 5/23 doesn't have a continuous taxiway along its length but it possible to operate from either end of the runway without back-taxiing.
As far as your experience waiting for a gate at the cargo ramp and having to wait this makes sense as Taxiway A would be the only way back to the main terminal ramp. You'd be going against the flow of departing traffic. In order to expedite movement you would have had to go on to the runway and exit a taxiway prior to the terminal complex. The main runway is used for departures and arrivals so ATC may not have had time to slot in a runway taxi which tends to occur at slower speeds. That being said, the terminal ramp is wide enough to allow a WB to taxi freely on A with another WB fully pushed back off a gate. Have experienced this twice now there. I'd imagine they do not allow taxiing on the the ramp in the opposite direction of traffic.
77H
zakuivcustom
Tue May 22, 2018 11:45 pm
For LIS there's also Runway 17/35 that has a full-length taxiway, which would eliminate it from an "airports without full length taxiway".
Another busy airport that doesn't have full taxiway is HKT (Phuket, Thailand), at 16M pax. Don't have to backtrack for 09 but has to backtrack for 27.
Samrnpage
Wed May 23, 2018 12:25 am
I think IKA Airport has a half length taxiway - around 10million pax a year :)
Kadish
Wed May 23, 2018 3:30 am
Must be in another canary island...I remember flying there a long time ago n there was no taxiway
ggflyboy
Wed May 23, 2018 4:08 am
PLS - 30+ ops per day, no taxiway. They do get wide bodies. More of that island feel.
SAN should be an honorable mention. Something tells me that the 747 couldn’t squeeze down Bravo when BA flew it in. Not sure what the actual constraint is, if any.
HNL
Wed May 23, 2018 4:36 am
Nadi Airport in Fiji (NAN) which handles about 2 million passengers a year.
777PHX
Wed May 23, 2018 4:54 am
Cairns, OZ doesn't have full length taxiways.
pdp
Wed May 23, 2018 5:35 am
Lublin - whilst having less than 500k passengers a year - has zero taxiways. No seriously, there's a short run from the ramp to the middle of the runway and that's it! Makes the middle of the day interesting if two flights are close together.
Luton has to be up there in terms of movements, the largest aircraft it can take realistically are 752s/A321s, and there's frequently a queue 5 or 6 deep at the runway before you count the aircraft sat on the ramp ready to go, but with no room.
Luton was recently found to be the most delayed airport in the UK, surely part of it is that fact is due to having to backtrack on the already very short runway!
armadillomaster
Wed May 23, 2018 7:45 am
Leeds Bradford (LBA-EGNM) has 4million+ passengers. Both ends require a taxi and a turning loop or full 180 depending on which end.
c933103
Wed May 23, 2018 8:03 am
Narita airport with 40 million passengers every year?
lugie
Wed May 23, 2018 10:24 am
Well neither GMZ (La Gomera), VDE (Valverde -> El Hierro) nor SPC (Santa Cruz de La Palma) have full length taxiways but GMZ and VDE would probably not qualify as "busy" airports.
SPC handled 1.3 million passengers in 2017 so while it's the largest airport without a full length taxiway in the Canaries it's most definitely not a contender for the overall first spot.
BENAir01
Wed May 23, 2018 10:43 am
Since when does Narita require backtracking?
mast2407
Wed May 23, 2018 11:48 am
Cork, EICK, 2.3m in 2017. Backtracking required for half the runway.
KlausU
Wed May 23, 2018 12:13 pm
Phuket, VTSP with almost 13m PAX in 2015 has no full length taxiway either.
AndrewJM70
Wed May 23, 2018 12:27 pm
I found it very odd that Luton have invested cash in building remaining taxiways but have not taken them quite to the ends of the runways. This doesn't seem to make much sense.
mackdad
Wed May 23, 2018 3:30 pm
CGH Congonhas Airport very busy without a full runway.
gwrudolph
Wed May 23, 2018 3:54 pm
77H
Makes sense
GolfBravoRomeo
Wed May 23, 2018 4:38 pm
Is LCY still scheduled to get a full length taxiway? IIRC there was talk of that.
aemoreira1981
Wed May 23, 2018 4:51 pm
No longer open to civilian traffic as of May 1.
Cunard
Wed May 23, 2018 5:51 pm
Recent press statements made by the management at Luton Airport have suggested that the taxiways will eventually be extended at both ends of the runway with work hopefully commencing in Q419.
Cunard
Wed May 23, 2018 5:54 pm
With the planned expansion which has just started at LCY the current taxiway will eventually be extended full length to the runway.
evank516
Wed May 23, 2018 6:59 pm
I would say CZM but it looks like it handles less than a million pax per year.
BENAir01
Wed May 23, 2018 7:52 pm
Not sure what a full runway in, bit CGH does not require backtracking.
