UA857
NW MSP-NRT and JFK-NRT in the 1990s
Thu May 10, 2018 5:24 am
What aircraft did Northwest use on the MSP-NRT and JFK-NRT in the 1990s? Did they use 744 or 742s?
jetero
Re: NW MSP-NRT and JFK-NRT in the 1990s
Thu May 10, 2018 5:26 am
Didn’t NW have a modified 742 that could make JFK-NRT nonstop?
LAX772LR
Thu May 10, 2018 6:45 am
Even as of 1992, they used 744s for JFK
DTW, MSP, SEA, SFO, LAX, and HNL all used 742s
http://www.departedflights.com/NW121592p17.html
TC957
Thu May 10, 2018 7:15 am
From memory, I think it was a 744 that routed JFK-NRT-MSP-NRT-JFK as a W pattern.
eta unknown
Thu May 10, 2018 7:44 am
A NW 742 routed NRT-MSP-ORD-NRT. Flew on the afternoon MSP-ORD sector- fun! Plane overnighted in ORD then headed to NRT next morning.
compensateme
Thu May 10, 2018 8:56 am
From memory: NW had 10 B744 in the 1990s.
JFK-NRT was exclusively operated by the type thought the decade.
DTW-NRT operated with the type from 1992 onward, replacing the 742, when DTW-SEL was discontinued.
MSP-NRT also operated with the type beginning in 1992, also replacing the 742, when JFK-OSA-SYD-LAX-SYD was discontinued. HOWEVER, MSP reverted back to the 742 when SEA-HKG was launched circa 1995. Although the B744 made a few cameo appearances on MSP/NRT, it didn’t regularly operate it again until 2003.
Nobody cares what your next flight is...
mmo
Thu May 10, 2018 9:33 am
There was no modified 742. They had a 742B with JT9-7R4D engines. MTOW was 833 and MLW was 650. Could do JFK-NRT full all year long without any problem at all.
UA857
Thu May 10, 2018 2:07 pm
When was JFK-NRT completely switched to a 747-400?
OA412
Thu May 10, 2018 3:28 pm
1989. JFK-NRT was NWs first 744 route.
Hughes Airwest - Top Banana In The West
UA857
Fri May 11, 2018 5:34 am
What type of 747-200 did NW use on MSP-NRT was it the ones with 7Q engines or the ones with 7R engines?
DL757NYC
Fri May 11, 2018 7:16 am
I miss the 744 top deck from Jfk-NRT.
mmo
Fri May 11, 2018 8:55 am
Generally, it was a Q. However, if they needed to get an R powered back into the rotation they would use that one.
UA857
Thu May 17, 2018 4:59 am
http://www.departedflights.com/JFKI96p5.html
Shows that JFK-NRT is a 742 not 744.
Frostbite
Thu May 17, 2018 5:13 am
I agree the 742 regularly operated JFK-NRT in the late 90s. Anecdotally, I worked the ramp for DL in Fairbanks AK (FAI), around 1998-1999 a NW 747-200B dropped in on us for fuel, operating JFK-NRT. It was not an equipment sub, just heavy and running against headwinds.
UA857
Thu May 17, 2018 5:19 am
Was it operated by a 747-200 all year around?
compensateme
Thu May 17, 2018 6:20 am
Probably just the way the info was reported via OAG; the NW timetable shows it as a 744. Notice the UA flight is also listed as a 747 — kinda hard to digest given UA had a half-dozen 742 vs. nearly 30 744, and the 742 were primarily flown domestically by 1996. There’s some YouTube videos showing UA commercials from circa 1994 advertising its all-744 Pacific fleet...
mmo
Thu May 17, 2018 9:20 am
Yes, NW 17/18 was operated with a 200 all year long. Ideally, a 200B would be used but it was not uncommon, especially during the summer, to see a 200A with Q power on the rotation.
UA857
Thu May 17, 2018 11:13 pm
747 means 747-100 or 747-200
