Page 1 of 2
A321 NEO LR LBG - JFK Flight Tracker
Posted: Tue Feb 13, 2018 2:34 pm
by keesje
Re: A321 NEO LR CDG - JFK Flight Tracker
Posted: Tue Feb 13, 2018 2:40 pm
by Newbiepilot
I guess we know why they used CFM engines instead if PW engines for the first A321LR since PW equipped A321neos have suspeded all test flights.
I wonder who will come out to see the plane land
Posted: Tue Feb 13, 2018 2:45 pm
by thepinkmachine
I think WOW Air stole the show by operating non-stop KEF-LAX a couple of weeks ago - a longer flight...
Posted: Tue Feb 13, 2018 2:47 pm
by keesje
Another A321 at JFK but it ain't Jetblue or AA. Exiting stuff .. :yawn:
It reached the UK and is a cruise level / speed for this stage.
Posted: Tue Feb 13, 2018 2:52 pm
by estorilm
keesje wrote:
Ohhh what I'd do to trade my work desk for theirs right now :lol: Wonder what's for lunch? Someone in another thread said it was heading to JFK?
Posted: Tue Feb 13, 2018 3:03 pm
by KarelXWB
You can't change engine type on such short notice.
Considering the lead time of the pylon, this was planned a long time ago.
The first LR customers have selected the CFM powerplant, hence this variant will be certified first.
Posted: Tue Feb 13, 2018 3:34 pm
by CobaltScar
So I suppose with comfortable flights from Paris to JFK, JetBlue is almost assuredly going to be using this plane. This is going to be a real danger to the Euro based LCCs that are flying trans Atlantic (Norwegian)
Posted: Tue Feb 13, 2018 3:45 pm
by fcogafa
That FR24 track seems to show it out of LBG
Posted: Tue Feb 13, 2018 3:49 pm
by reidar76
But this is not really an A321LR, as it only has two additional center tanks onboard. This is the A321 ACF, the first aircraft with both the new engines and the modified fuselage. The third additional center tank will be installed later.
Posted: Tue Feb 13, 2018 3:55 pm
by Richard28
Although Norwegian also have plenty of A321LR's on order too.
Posted: Tue Feb 13, 2018 4:03 pm
by ikolkyo
The aircraft has the 97t MTOW so it is an A321LR, just missing the 3rd ACT.
Posted: Tue Feb 13, 2018 4:41 pm
by flee
keesje wrote:
You might want to change the thread title to LBG - JFK.
Posted: Tue Feb 13, 2018 4:47 pm
by arcticcruiser
And all this is pointless without knowing the payload capability on the sector. You can ferry or fly poor loads (as WOW did) long distances. But that does not bring profits.
Posted: Tue Feb 13, 2018 4:48 pm
by ikolkyo
reidar76 wrote:
The A321neo ACF is the base for the longer range variant known as the A321LR. As I understand it, there will only be one variant of the A321 going forward, with 0, 1, 2, or 3 additional center tanks onboard. All A321 from 2020 will have a MTOW of 97t (or be paper derated)
There is also a benefit of the increased MTOW to 97t going short haul with high payload. The A321 ACF is also necessary for the increase to a maximum of 240 passengers.
http://www.airbus.com/newsroom/press-re ... o-acf.html
I’m aware of all the changes with the ACF configuration l, you said this aircraft isn’t an A321LR because it’s missing the 3rd ACT and that is false.
by reidar76
Posted: Tue Feb 13, 2018 5:00 pm
by Dutchy
The airspeed is quite a bit slower, around 50-80kn. The 757 seems to have the same speed as the WB.
Posted: Tue Feb 13, 2018 5:31 pm
by AirbusOnly
And that was „only“ their A 321 neo- no LR - and they are still using it nonstop KEF - SFO too! Flightime more than 8 h - Check TF-SKY
Posted: Tue Feb 13, 2018 5:37 pm
by TranscendZac
I would rather fly a 321NEO/LR across the pond than a wide body. Less people on board, and the A32X family cabin is plenty spacious, and certainly on most airlines who will be operating longer 321LR flights.
Posted: Tue Feb 13, 2018 5:41 pm
by arcticcruiser
Yep, even slower than a Norwegian 737. Doing maximum range cruise speed? Winds are bad today going west.
Posted: Tue Feb 13, 2018 5:47 pm
by Acey
..a ~220 seat 767 with two aisles still wins in the "spaciousness" department as far as I'm concerned, though those are mostly on the way out.
Posted: Tue Feb 13, 2018 5:48 pm
by Dutchy
I guess, this will hurt it on long runs.
Posted: Tue Feb 13, 2018 6:29 pm
by keesje
Yes the AirLingus A330 EI137 will probably overtake it.
:checkeredflag:
https://www.flightradar24.com/EIN13T/106b2fed
Posted: Tue Feb 13, 2018 6:35 pm
by tomcat
It's currently 70 kts slower than the closest Norwegian 737 (352 vs 425 knots). It's like if she was flying on one engine! Are these live ground speeds or the last ones recorded at some point during the crossing? Could it be that it's flying this slow because of landing slot issue? The first flight of the day apparently went back to Paris after a few minutes in flight because of an ESTA issue, so they lost their initial landing slot at JFK.
The altitude is a bit odd as well: it has been shown at 34750 ft for a while (so not in transition between two flight levels), while all the other planes fly at "round" altitude levels (34000, 38000,...).
Posted: Tue Feb 13, 2018 6:41 pm
by N757ST
I’m sure it’s at long range cruise speeds. It’ll cruise between .78-.79 in normal operations.
Posted: Tue Feb 13, 2018 6:42 pm
by barney captain
75kts slower than the MAX8 just south of it? That is very odd.
Posted: Tue Feb 13, 2018 6:47 pm
by CCGPV
For those of us not using flighradar can we get a flight number or anything?
Posted: Tue Feb 13, 2018 6:48 pm
by ap305
The speed is not updated for a long time since its out of receiver range... It was at mach .78 at the last point which is the lrc of the a320 family.
Posted: Tue Feb 13, 2018 6:49 pm
by Abeam79
Paris-JFK....Putting it right in JetBlues backyard which is close to finalizing its fleet review..how convenient!
Posted: Tue Feb 13, 2018 6:51 pm
by barney captain
....except they are being overtaken by everyone around them.
Posted: Tue Feb 13, 2018 6:58 pm
by cledaybuck
What is the point of this flight? Publicity?
Posted: Tue Feb 13, 2018 7:02 pm
by MKIAZ
Yes, but Norwegian can only fly Europe to north-east.
Jetblue, by way of having it's main hubs at BOS/JFK can provide one stop service between the entire US and most of europe. And the seats are actually more spacious in economy than the US3 or the European LLC's. And in business they'd have lie-flat mint, potentially the whole journey.
For people paying for business it's much nicer than connecting in LHR or flying domestic first to a connecting point.
AC could also capitalize on this with their YUL hub.
Posted: Tue Feb 13, 2018 7:08 pm
by ap305
except those are projected by fr24 based on the last recorded ads-b data which was a long time back.
Posted: Tue Feb 13, 2018 7:10 pm
by ap305
The aircraft is also nowhere near its weight limitations given that they went up straight to fl360... This test probably has more to do with seeing how the cabin systems work on a real long haul operation.
Posted: Tue Feb 13, 2018 7:25 pm
by barney captain
That's a good point - it is a test flight. If you look at their GS graph, there is a steady reduction of speed over the course of an hour or so, it could easily be part of a test.
Posted: Tue Feb 13, 2018 7:48 pm
by SteinarN
Interestingly enough, when facing head winds the optimum true airspeed for max range/lowest fuel consumption per distance does in fact increase. And the reverse when facing tail wind. Say max range cruise speed is mach 0,78 in still air. When facing severe head wind the maximum range true airspeed goes up to say mach 0,8 and when facing strong tail wind the max range cruise speed goes down to say mach 0,75.
Posted: Tue Feb 13, 2018 8:00 pm
by airbazar
As if the speed of a test flight where we don't know what exactly is being tested, is relevant and comparable to commercial operations :banghead:
Posted: Tue Feb 13, 2018 8:01 pm
by PerVG
Just got back to live tracking and doing about the same speed as all other aircraft on a similar fly path.. ;)
Posted: Tue Feb 13, 2018 8:25 pm
by Theseus
Indeed, and EI137 did not overtake it.
I did not know FR24 was extrapolating (yes, I feel foolish), thanks for the brilliant demonstration. ;)
by Noise
Not sure if serving Europe is in JetBlue's medium-term plans.
Posted: Tue Feb 13, 2018 8:32 pm
by Newbiepilot
A320s along with 737s, 757s and 767s are pretty slow going between Mach .78 and .80 compared to 747s, 787s, A350s and A380s going at 0.85. When Delta and United went head to head on SFO-NRT, the Delta 767 was blocked at 55 minutes longer than the United 747. 737s and A320s are some of the slowest ETOPS birds.
Posted: Tue Feb 13, 2018 8:33 pm
by tjwgrr
AIB321 / D-AVZO
Not showing up on Flightaware for some reason.
Posted: Tue Feb 13, 2018 10:39 pm
by Bricktop
Looks like it'll go to 22L, and light's fading fast. Beauty shots look doomed.
Posted: Tue Feb 13, 2018 10:42 pm
by Abeam79
Not sure if serving Europe is in JetBlue's medium-term plans.[/quote]
Uhhmm..guess you haven’t heard much or been out of the loop but a cursory google search and you’ll see jetblue planning on converting to the LR for Europe a very serious next step which we should hear soon. Even so I’m sure they will also continue deeper into Latam from Mco/fll focus cities with it.
Posted: Tue Feb 13, 2018 10:49 pm
by Bricktop
Now looks like setting up for 13R. Coolest approach to JFK.
Changed to 13R, or I didn't hear initial instructions.
Posted: Tue Feb 13, 2018 10:54 pm
by gatibosgru
Is this the first true trans Atlantic NEO crossing?
Posted: Tue Feb 13, 2018 11:03 pm
by GE90man
It looked as if it was going to land on one of the 22s, but nope. This is extremely unfortunate for me as I happen to live under the path that aircraft take to the 22s, and I was planning on spotting it. :(
Posted: Tue Feb 13, 2018 11:10 pm
by Bricktop
Dark and cloudy. I saw it through the clouds for a few seconds, and I was too slow to get any kind of shot.
Posted: Tue Feb 13, 2018 11:12 pm
by Samrnpage
Its parked up near the end of 4L by the looks of it - well out of the way
Posted: Tue Feb 13, 2018 11:16 pm
by GE90man
When does it return to LBG, or continue the next leg of its journey?
Posted: Tue Feb 13, 2018 11:38 pm
by GSPFlyer
When QF was still using both the 744 and A380 between SYD and MEL, wasn't the 380 blocked for longer than the 744?
