jubguy3 wrote:impromark wrote:YYC-SLC operates Daily on an E175, is this a candidate for replacement? I may fly that route again someday, so the interest is purely selfish...
Possibly,
but Delta has said that the bases for the CS100 are going to be NYC and LAX. The competitive advantage gained by using fuel efficient CS100 is not needed in Salt Lake City because it is a fortress hub without a DC-9 derivative base, and there is little incentive to using the newest aircraft here.
first bases.
There will be other bases in the future.
TVNWZ wrote:Midwestindy wrote:.... with capacity definitely under 120 seats that met our mission profiles, including average route distances of under 1,000 nautical miles, not the 2900 nautical miles that have been defined today.
In fact, our agreement is structured with maximum takeoff weight provisions that reflect our intended deployment plan to fly the aircraft, on average, on routes that are less than 1000 miles. If we exceed those averages, i.e., the plane needs to carry more fuel because it's flying longer distances, we're going to be required to pay Bombardier additional payments
A fleet
average of 1,000 miles leaves a lot of wiggle room for longer routes to be used.
The actually range is going to be right around 2,000nm. The airplane will be able to do basically anything from the interior hubs and everything but transcons from the coastal hubs.
INFINITI329 wrote:Midwestindy wrote:In fact, our agreement is structured with maximum takeoff weight provisions that reflect our intended deployment plan to fly the aircraft, on average, on routes that are less than 1000 miles. If we exceed those averages, i.e., the plane needs to carry more fuel because it's flying longer distances, we're going to be required to pay Bombardier additional payments
It baffles me why DL would limit the capability of their investment. Use airplane as you see fit but don't limit its capabilities. As others have stated this makes the CS100 at DL a glorified regional jet. A jet capable of 3,000+ nm range and you are limiting it to a 1/3 of that to save a couple pennies just doesn't make sense to me.
because Delta is going to use the airplanes for mostly regional flying. Its fairly stupid for Delta to pay BBD and Pratt for higher weight/thrust plus pay for the higher maintenance and operational cost that comes with it.
LawAndOrder wrote:Midwestindy wrote:ilovelamp wrote:
My post was mostly rhetorical in that I know it hasn’t been announced officially. I just found it funny that’s being spoken about as if it's a given when Delta Networking won’t even know where they will be based until the last minute. Sure, some execs have stated those places publicly but that’s not the official word.
Ummm, it is all but confirmed guys, and has been for a while....They even confirmed it to investors, the media, pilots, flight attendants, and probably the neighbors dog too. I'm not sure how much more they need to do to make it known that they will base the Cseries in NYC and LAX...It isn't like network just found out about these planes either, they have known about them for years....they aren't just now deciding what to do with them, lol.
cessna2 wrote:Technically they may be smaller, but the CS will hold the least amount of pax at 109. 1 less than the 717. So it will in terms be the "smallest" A/C in our fleet.
I'm aware, we were discussing the current fleet, and the person I was quoting was saying the MD88 was smaller than the B717
StrandedAtMKG wrote:
Wait...what? How does that work? DL has to pay Bombardier more if they utilize the aircraft's full range? I'm not clear on the concept here.
Greg May.
Senior Vice President of Fleet and Supply Chain Management at Delta Airlines.
On buying C Series:
I can't stress enough that when we began looking at our single-aisle replacement growth strategy in 2015 our focus was on reducing our 50-seat regions jets by up gauging to small gauge mainline aircraft. One of the highest priorities at the time was to find a small gauge aircraft, one with capacity definitely under 120 seats that met our mission profiles, including average route distances of under 1,000 nautical miles, not the 2900 nautical miles that have been defined today.
The initial 2 route planned or that has been communicated to the media are over 1000 miles. But I suppose you combine them with some short haul "shuttle like" markets you can get to under a 1000 average stage.
and that is what will happen. I would bet on most of the short haul flying out of LA and Seattle to become CS100 routes. DEN, PHX, SFO etc.
There will be some mid cons on the fleet but the average flying will be mostly regional.
ilovelamp wrote:deltal1011man wrote:ilovelamp wrote:
Where is the official announcement they are going to NYC and LAX?
Delta has not ever (to my knowledge) provided an announcement of pilot bases.
Having said that its one of the worlds worst secrets that LAX and NYC will be the first pilot bases for the airplanes. It has been talked about internally, by employees in public and even executives on earnings calls several times.
not how that works at all.
The company has to be pretty clear with DALPA on the first bases. If the airplanes come in August like being talked about an AE will need to be done pretty quickly and get pilots in the training pipe line.
I get your point but we are getting to the time where the first bases will be set in stone. Now network could come out in August and say the first route is ATL-MCI, but the pilots will be coming from NYC/LAX.
