3rdGen
Re: Airbus A350 Production/Delivery Thread 2018
Mon Sep 03, 2018 11:10 pm
trex8 wrote:
Do higher cycle costs outweigh higher weight costs over the lifetime of the frame or vice versa? I guess it depends on lots of variables but overall can one say its usually less one way or other?
Do you mean do higher cycle costs out weigh the potential revenue earned by having an aircraft that can carry more payload or fuel or both?
Of course it all depends on the mission the aircraft is going to be sent out on. If the airline realises that it isn't ever going to reach max take off weight why but an aircraft certified for a higher weight.
As for what makes sense it's a case by case basis. Airlines do their math and figure out what they need. But I would say that if the aircraft can be filled up it's generally the case that the revenue earned out weighs the cost of the higher certified weight. I mean the manufacturers also do their math. If they're going to sell aircraft with higher weight they need to be sure there are airlines out there that would want the aircraft.
hkcanadaexpat
Tue Sep 04, 2018 8:38 am
MSN 110 (QR#30) departing on its first CAF
MSN 243 (PR#4) active on the flightline
qf789
Tue Sep 04, 2018 12:25 pm
First A350 for HU returning to TLS after another test flight
https://twitter.com/CAlloing/status/1036952115380449280
hkcanadaexpat
Tue Sep 04, 2018 8:22 pm
MSN 112 (JD/HU) active on the flightline
MSN 206 (CX#26) RTO - first flight scheduled for Wed
MSN 226 (HU#1) first test flight post-painting #AIB04FG
qf789
Wed Sep 05, 2018 11:59 am
Cathay Pacific MSN206 A350-1000 taxiing back after RTO
https://twitter.com/A350fans/status/1036995674510962689
hkcanadaexpat
Wed Sep 05, 2018 8:04 pm
MSN 52 (3U#2) new engine run
MSN 206 (CX#26) revised RTO - first flight now scheduled for Thu
MSN 223 (SQ#23) out on another test flight #AIB03HE
MSN 240 (CA#5) first flight #AIB01HK - unpainted
Sayan777
Thu Sep 06, 2018 6:12 am
Is there any probable dates when Singapore Airlines gets its first A350 ULR. Thanks.
LAX772LR
Thu Sep 06, 2018 7:12 am
Have to admit, I had a bit of trouble initially distinguishing this one as an A35K versus an A359.
Normally, I'd look straight to the gear for the dead giveaway, but this one was a bit of a challenge. :eek:
StTim
Thu Sep 06, 2018 7:24 am
It is the new low rider version.
Someone83
Thu Sep 06, 2018 10:57 am
SriLankan ended up paying Airbus $116 millions for cancelling their A350s order
https://www.ch-aviation.com/portal/news ... ling-a350s
audidudi
Thu Sep 06, 2018 12:43 pm
Normally, I'd look straight to the gear for the dead giveaway, but this one was a bit of a challenge. :eek:[/quote]
The dead giveaway is the number of windows between doors L1/L2 or R1/R2. There are 15 (minus any blanked off) on the A359 and 22 (minus any blanked off) on the A35K!
hkcanadaexpat
Thu Sep 06, 2018 8:05 pm
MSN 163 (QR#29) sporting its final regs (A7-AME) - delivery imminent
MSN 206 (CX#26) first flight #AIB01NI
MSN 217 (CA#3) first CAF #AIB06NU
LAX772LR
Fri Sep 07, 2018 3:13 am
Thanks. Never really paid enough attention to the frames to count that. Will remember.
hkcanadaexpat
Fri Sep 07, 2018 8:12 pm
MSN 226 (HU#1) out on another test flight #AIB05FG
MSN 240 (CA#5) flew to XFW for painting #AIB02HK
MSN 243 (PR#4) initial engine run
qf789
Sat Sep 08, 2018 9:36 am
MSN217 CA#3 returning from its flight
https://twitter.com/Frenchpainter/statu ... 6969443330
qf789
Sat Sep 08, 2018 9:38 am
MSN226 HU#1 returning to TLS from its test flight
https://twitter.com/Frenchpainter/statu ... 6264557569
qf789
Sat Sep 08, 2018 10:00 am
A couple more photos of MSN217 CA#3 on its test flight
https://twitter.com/duncan_morley/statu ... 1531411457
Eyad89
Sat Sep 08, 2018 1:09 pm
A350 might be the first wide-body that looks better with the smaller variant IMO. Other smaller variants of different wide-bodies look kinda overwinged.
Perhaps that’s because A359 wasn’t initially supposed to be the baby of the family.
hkcanadaexpat
Sat Sep 08, 2018 6:19 pm
MSN 236 (PR#3) new engine run (engine change?)
Erebus
Sat Sep 08, 2018 9:37 pm
I actually like the A35K better. It has a bit of that slender elegance of the A346 which I most liked about it. Sort of like a supermodel. :hearts:
Tedd
Sat Sep 08, 2018 9:46 pm
Not sure about the "supermodel" analagy, but I`m with you on the A35K being better proportioned. I believe a stretch of this
aircraft would look pretty decent too, it might also give the B777-9 some added competition if AB were to consider it :)
george77300
Sat Sep 08, 2018 10:45 pm
That’s because it is the first? wide body where the varients have different wings. Look at the 787/777/330 etc all have the same wing on all length varients. The A350-900 has a smaller wing than the A350-1000 so I guess they look more in proportion.
Erebus
Sun Sep 09, 2018 1:27 am
Well, not quite. I think the A345/A346 have enlarged wings compared to its smaller sisters.
Stitch
Sun Sep 09, 2018 1:50 am
Yes, the A340-500 and A340-600 did have a three-frame insert in both the wingbox and the wings as well as a 1.6 extension to each wingtip.
And I believe the A350-900 and A350-1000 share the same wing, with the A350-1000 having an extended trailing edge that adds around 4% to the total wing surface area.
george77300
Sun Sep 09, 2018 9:36 am
Oh yes of course. I was sort of thinking of them as two separate families in my head. 342/343 shared and the 345/346 has the same hence why the 345 looks over winged because it’s the same as on the much larger 346.
hkcanadaexpat
Mon Sep 10, 2018 7:43 am
MSN 220 (SQ#22 - first ULR) at the delivery centre this morning
Theseus
Mon Sep 10, 2018 4:00 pm
Just forwarding information observed on the google list, but I think it is interesting nonetheless:
Two deliveries for QR today:
- MSN110 (A35K)
- MSN163 (A359)
Also, this is the 6th delivery of an A35K (3 for QR and 3 for CX so far).
audidudi
Mon Sep 10, 2018 5:39 pm
- MSN110 (A35K)
- MSN163 (A359)
Deliveries #1 and #2 in September.
Deliveries #52 and #53 in 2018.
hkcanadaexpat
Mon Sep 10, 2018 8:10 pm
MSN 125 (QR#32) second test flight #AIB02GK
MSN 207 (QR#33) active on the flightline
MSN 231 (CA#4) new engine run
MSN 236 (PR#3) moved to the delivery centre
MSN 243 (PR#4) RTO - first flight scheduled for Tuesday
EBJ68
Mon Sep 10, 2018 10:54 pm
Just a quick note. I'm a returning member to Airliners.net. Really enjoy the Production/Delivery threads. To those who make contributions, thank you very much.
qf789
Tue Sep 11, 2018 7:30 am
Air China MSN240 at Hamburg for painting
https://twitter.com/Tobias_Gudat/status ... 5229655042
hkcanadaexpat
Tue Sep 11, 2018 8:51 am
MSN 236 (PR#3) departing on its first CAF this morning #AIB03HH
hkcanadaexpat
Tue Sep 11, 2018 8:48 pm
MSN 239 (CI#14) has been moved to the delivery centre
MSN 243 (PR#4) first flight #AIB01FP
MSN 250 (JJ#9) active on the flightline this evening
hkcanadaexpat
Wed Sep 12, 2018 5:56 pm
MSN 98 (JD/HU) second test flight #AIB02FR
MSN 223 (SQ#23) out on another test flight #AIB04HE
MSN 226 (HU#1) out on another test flight #AIB06FG
MSN 230 (SQ#24) returns from XFW paint shop #AIB03HI
Aircellist
Thu Sep 13, 2018 1:54 am
I restate my earlier question: is there a rumor about which would be delivery #200? I suppose it could happen before the end of this month… Could it?
hkcanadaexpat
Thu Sep 13, 2018 2:11 am
we're sitting on 195 and there are 4 frames at the delivery centre (CA/PR/SQ/CI). PR will go 196 or 197 depending on that CA frame. Other frames due to the delivery centre imminently include CA/SQ/QR/HU. So i think we can say with 100% certainty that the 200th will go to one of CA/SQ/CI/QR/HU. Pick your horse & wait and see!
for those in this forum obsessed with delivery flights rather than deliveries, we're currently sitting on 193 with those two 3U frames delivered in Dec 2016 still sitting @TLS.
Aircellist
Thu Sep 13, 2018 4:57 am
Thanks hkcanadaexpat!
My bet: the first ULR…
hkcanadaexpat
Thu Sep 13, 2018 8:49 am
MSN 217 (CA#3) out on another CAF this morning #AIB07NU
MSN 239 (CI#14) active at the delivery centre
hkcanadaexpat
Thu Sep 13, 2018 7:51 pm
MSN 141 (QR#34) active on the flightline - oneworld paint scheme
MSN 172 (QR#31) new engine run
hkcanadaexpat
Fri Sep 14, 2018 12:13 am
Delta's next 359 (MSN 267) has rolled out of FAL. Q1/2019 delivery.
Aircellist
Fri Sep 14, 2018 3:46 am
By the way, have the tests with the ULR been concluded?
hkcanadaexpat
Fri Sep 14, 2018 4:01 am
yes. delivery should happen soon. the first frame sits at the delivery centre.
Slug71
Fri Sep 14, 2018 4:54 am
Nice to see Qatar deliveries finally caught up. With the exception of 2 or 3 -1000s.
After looking at the production list, looks like -1000 activity is increasing too. Should be roughly 7 frames sitting around?
4 ULRs around (1 at the delivery center and the rest in flight testing?), with 3 more in the FAL?
hkcanadaexpat
Fri Sep 14, 2018 7:02 am
QR has caught up a lot but is still behind. To put it in perspective, Airbus is delivering MSNs in the 230 range right now. There are still 8 QR frames undelivered of MSN 215 or lower. The QR 359 backlog should clear by year end. The QR 35J backlog should clear by Q1-2019.
On the A35J front, CX has (1) in flight testing, (3) in cabin fitting, (1) in re-work and (1) in FAL. QR has (1) in flight testing, (1) in pre-flight testing, (2) in cabin fitting, (2) in re-work and (1) in FAL. VS has (1) in re-work at Bordeaux (ex-prototype) and (1) in FAL. BF has (1) in re-work at Hamburg (ex-prototype). Total = 16
On the ULR front, SQ has (1) at the delivery centre, (2) in flight testing, (2) in cabin fitting and (1) in re-work (post flight testing). Total = 6
3rdGen
Fri Sep 14, 2018 12:05 pm
Just to clarify with everyone on the forum. The short form is 35K not 35J.
george77300
Fri Sep 14, 2018 2:02 pm
If you want to be pedantic then technically no you are wrong. The ICAO is A35K and the IATA is 351.
So technically A35J/A351 and 35K/35J are all incorrect.
juliuswong
Fri Sep 14, 2018 3:06 pm
Thanks hkcanadaexpat for the updates. Wow, it seems like SQ will receive their 7 ULR successively pretty quickly.
Also VS taking ex-prototype for A350-1000? I haven't heard of this. Sorry, been away for some time from this thread.
Kikko19
Fri Sep 14, 2018 4:16 pm
Good move for A. If the ULR will prove performing well might receive more orders. And maybe we can see a A350 1100.
Polot
Fri Sep 14, 2018 4:23 pm
The ULR is a very niche plane, I would not expect many more orders for it (which is ok since it was cheap, SQ’s planes probably paid for all ULR unique development on it).
