iyerhari wrote:VS4ever wrote:B757rocket wrote:Delta BOS-LIS Non-Stop on 757-200 has been loaded and is bookable. Seasonally from May 23rd:
DL124 BOS 21:45—09:15 LIS
DL125 LIS 10:45—13:15 BOS (return starts the 24th).
Well Terminal E is going to look quite the quasi DL terminal when CDG, LHR, AMS and now LIS will all be on the ground at the same time as arrivals.
Maybe even DUB although can’t remember the return time of that one.
Two questions, 1)daily? 2) any idea of when this runs to?
Your wish on a new route announcement coming true every two weeks is indeed happening! I believe this is just the start - DL may start announcing new flights anytime soon in anticipation of addnl. A gates.
yeah, really, they just keep on coming... I was thinking (tongue in cheek) about more PF, but I'll take a DL LIS flight, now we have 3 carriers on that route. I guess that means TP will hold at daily now, 21.45 departure time is interesting as that's around the timing of the DUB flight leaving too. I am seeing another bank potentially appearing after the 7pm departures, now we have a 10pm LIS and DUB, sure it's early days, but it might work out. Also, this is timed to land within 5 minutes of the daily TP flight.
One thing that amazes me, is that DL has all these early arrivals into BOS, all of them with the exception of the 2nd AMS flight land within an hour of each other, the advantage of being US based, because they can have the late departure from BOS and the earlier departures from Europe without having the aircraft on the ground for too long. something the European based airlines can't really do because of the space issues in E. TP get away with it, because they get to use C, so can use the stand and FI get away with it due to the shorter distance and stupidly early time of arrival in KEF.
Right now if the schedules stay the same, this is what we could see on stand.
AMS - DL259 - 13.15 arrival A333
CDG - DL119 - 12.15 arrival B763
DUB - DL155 - 12.32 arrival B752
LHR - DL 59 - 12.16 arrival B763
LIS - DL125 - 13.15 arrival B752
you can almost guarantee some of the early ones will be delayed, so you could have 5 DL flights on stand at the same time. and maybe more to come.
In that 13.15 timeslot there appears to be 2 stands open, so they have more room if they want to announce more. It goes to 4 available if they push to 13.45 or 5-6 if they use 12.15
