asuflyer
Etihad to retire the 77L
Thu Nov 16, 2017 3:25 am
EY will phase out the 5 77L's currently in their fleet after the end of AUH-DFW in March.
The 77L has been removed from schedules beyond March.
AUH-LAX will be operated by exclusively by the 77W from January 15th.
77west
Re: Etihad to retire the 77L
Thu Nov 16, 2017 3:34 am
From memory, some of them originally came from Air India so may not be in the best condition
FoxtrotSierra
Thu Nov 16, 2017 3:48 am
This is yet another sign of one of two things:
1. EY is in deep shit
2. EY is finally making sensible decisions
AsiaTravel
Thu Nov 16, 2017 3:55 am
EY is in deep shit hence they finally make sensible decisions.
That would be my take.
sibibom
Thu Nov 16, 2017 4:00 am
Perhaps Air India can take it back, they surely can use with it now, since routes to the US are finally working. But then Oil is rising again, these birds are guzzlers.
77west
Thu Nov 16, 2017 4:59 am
If AI take them back, they will probably just part them out like they did last time. Could these be the first of the "NG" 777's scrapped? (200LR/300ER family)
Slash787
Thu Nov 16, 2017 5:25 am
Is Iran Air allowed to buy them?
ist2014
Thu Nov 16, 2017 7:18 am
Does it work for TK
They can use iy for SYD flights
ZK-NBT
Thu Nov 16, 2017 7:54 am
What did AI part out last time?
Narfish641
Thu Nov 16, 2017 10:03 am
JA actually retired 3 of their 773 a year ago I believe. Emirates has also retired a few of their 300s as well a while back. Those are the only two airlines I can think of.
VSMUT
Thu Nov 16, 2017 10:35 am
Those were the early non-ER versions though. Emirates has retired a single 777-300ER, but it was sold to another operator.
dubaiamman243
Thu Nov 16, 2017 10:38 am
EY B77Ls will be in active service for a limited time.
MileHFL400
Thu Nov 16, 2017 10:57 am
Any potential takers?
MoKa777
Thu Nov 16, 2017 11:04 am
I wonder where this leaves their order for 778.
EY made terrible decisions but I always feel that, among the ME3, they are the least likely to allow pride, face and ego stop them from admitting their plans did not work and attempting to correct things. Some of you might disagree but that is how I see it.
emiratesdriver
Thu Nov 16, 2017 11:15 am
Then regrettably, you dont know enough about how EY works, the strong "wasta" culture has followed on from the many at EY who were responsible for Gulf Air and its slide into insignificance.
frigatebird
Thu Nov 16, 2017 11:29 am
Wow, that's quick. They have been in service with EY for just 3,5 years.
Some have suggested AI could use them for US routes, where the 77W has too many restrictions and the 788 is too small.
Indeed. And not just that order, IMO EY has overordered massively, they have too many 787 (54), A350 (62) and 777X (35) on order as it is. Maybe they thought they could form their own alliance and ordered accordingly, I don't know. Deferrals/cancellations must be coming I believe.
Arion640
Thu Nov 16, 2017 11:44 am
EY will never be EK but as long as they control what they are doing I think they can chip away at it.
I think EY has too many fleet types so this should help solve this issue.
mjoelnir
Thu Nov 16, 2017 12:15 pm
That was sold to VIM. The bird is stored and with regards to VIM troubles not out of danger to be scrapped.
mjoelnir
Thu Nov 16, 2017 12:18 pm
I think that the EY 777-200LR will get retired and scrapped. AI did not have a real use for them. A 777-200ER is expensive to use and for everything but extreme range there are the 787 and A350 doing it better and less expensive.
FlyRow
Thu Nov 16, 2017 12:20 pm
My first thought was Delta.. seems like the second hand bargain they would lay their hands on.
na
Thu Nov 16, 2017 1:08 pm
AI offloaded their 77Ls quickly, calling them "gas guzzlers". Like the now vanished A345 they are niche aircraft and most airlines can do without them.
dtw2hyd
Thu Nov 16, 2017 1:51 pm
frigatebird wrote:
Some have suggested AI could use them for US routes, where the 77W has too many restrictions and the 788 is too small..
That is just a blogger myth without even knowing the config. AI can block 100 seats off a 77W and carry the same number of passengers as their 77L.
AI 77L vs 77W vs 788
Y - 195-303-238
J - 35 angle flat - 35 flat - 18 flat
F - 8 flat - 4 flat - 0
I wouldn't say quickly. Contrary to what has been said on a.net, Air Canada offered way higher for those 77Ls, but AI's assessors estimated even higher value, forcing AI to ignore AC's offer. In hindsight, it was a very bad move considering AI burnt $60M/year ($12x5) on grounded aircraft for few more years and sold for $65M/each including the heavy check.
If this was a private airline, CEO could have just ignored assessors estimate and sold to AC.
fanoftristars
Thu Nov 16, 2017 1:59 pm
I would hope Delta could pick them up. I'm curious - considering the price that Delta might be able to get these for, what would economics look like if they were flying them across the pacific or atlantic? I know that after a given amount of miles, thought it was around 3000, the 777LR beats the 777ER in economics. And the 777LR can do any of Delta's missions with a full load pretty much without restrictions.
voxkel
Thu Nov 16, 2017 2:29 pm
It would be great if AI bought back five of the EY 77L (A6-LRA through A6-LRE) which were formerly AI aircraft. AI could then give the original names VT-ALA through VT-ALE.
AI sold the 77Ls in a time where there was not much need for 8 of then. Back then (2013), IIRC only the DEL-ORD flight was 77L, and that was soon changed to 77W as well.
AI should buy back the 77Ls and adopt a denser configuration (no F, good all-aisle J, and 3-4-3 Y). Then they would have all 8 of their 77Ls. 2 could be used for SFO, 2 for ORD and 1 for IAD. (From what I understand, ORD/IAD flights need to block several seats to make the trip nonstop on 77W.)
Then, they could start 3/wk LAX and 3/wk IAH, both on 77Ls, and have 1 spare remaining. Currently AI can only start 1 new route (LAX/SEA/IAH) due to the availability of only 1 free 77L.
The JFK/EWR flights can remain 77W.
Spiderguy252
Thu Nov 16, 2017 2:34 pm
AI have been static for a few months since the talk of the sell-off, so grandiose plans like the ^above^ may have to wait a wee bit longer.
amdiesen
Thu Nov 16, 2017 2:39 pm
Etihad might consider speaking with the other Atlanta based airline
United787
Thu Nov 16, 2017 2:45 pm
Who else is still flying the 777-200LR?
DfwRevolution
Thu Nov 16, 2017 2:55 pm
And since when has AI been an authority on fleet planning?
The 772LR burns less fuel than a 772ER on medium-range routes greater than about 4,000 nm. That covers a huge number of TATL city pairs to say nothing of ULH. It's vastly more flexible than the A345.
voxkel
Thu Nov 16, 2017 3:03 pm
AC is one I can think of, along with EK/QR.
Interestingly the only ULH route EK use 77L on is DXB-FLL. All other ULH are on 77W or A380.
VictorKilo
Thu Nov 16, 2017 3:12 pm
I seem to remember discussion back when AI were trying to place these aircraft the first time that there may have been some maintenance paperwork issues with these aircraft.
Were those issues resolved when they were placed in service with EY? Are there remaining paperwork issues with these aircraft that may limit where they are placed going forward?
jbs2886
Thu Nov 16, 2017 3:19 pm
Is it confirmed these will be retired or just speculation from the airlineroute post?
dtw2hyd
Thu Nov 16, 2017 3:28 pm
That is one guy with CTSB connections, claiming on a.net that AC never gave an offer. Recent audit reports actually prove that was a false theory. AC offer was sooner and higher. AI would have saved $180M in sunk cost and $100M more in the sale.
Also, Indian bloggers only fly planes with every component serial number matches the initial delivery bill-of-material. AI-EY sale included a heavy check.
JAAlbert
Thu Nov 16, 2017 3:34 pm
Operating an aircraft for only 3.5 years seems like a tremendous waste of money. How much did EY pay for the 77Ls? (I did a google search, but didn't get a figure)
dtw2hyd
Thu Nov 16, 2017 3:42 pm
$65 Million including heavy check and interior redone. EY probably paid extra for a paint job in Amsterdam.
N415XJ
Thu Nov 16, 2017 3:49 pm
DL operates 8, PIA operates 2, Turkmenistan operates 3, and Iraqi Airways operates 1.
yashk
Thu Nov 16, 2017 3:53 pm
I think it has a lot to do with AI's config of only 235 seats. Compare that to Emirates which is re configuring these planes to seat 300+
jbs2886
Thu Nov 16, 2017 4:07 pm
Ethiopian has 6; Etihad has 6; AI has 3.
IrishAyes
Thu Nov 16, 2017 4:23 pm
gotta admit, DL taking the 77Ls....the most vocal opponent of the ME3....that would be a very interesting twist of irony!
IranianMan123
Thu Nov 16, 2017 4:35 pm
Yes, but it does not need them. If everything goes to plan we will see IR receive their first 77W in April. No need to receive the 77L
thgsr08
Thu Nov 16, 2017 4:40 pm
The main question is: What's the reason to buy/lease this aircraft? Opportunity? - It must've been very cheap. For me, an airline to purchase any aircraft, it must do a lot of study and see the real demand otherwise it'll loose money an I'm seeing this happening - waste of $$$. A "brand new" aircraft with lots of circles still available, far from C check, going to be scrapped? It seems to be the same situation when AI bought them and then realized they didn't need, altought they're plenty good on their route to SFO.
Anyway, it'll be good if these 77L find another operator.
airzona11
DL might be in market. They do have a lot of capacity coming online around that same size tho. They will probably spend some time parked.
catiii
Thu Nov 16, 2017 5:02 pm
Are any governments in the market for VIP transports? There may be a few sales there...
OA940
Thu Nov 16, 2017 5:07 pm
Well I would hope for a new operator, but I doubt it with such a small number of planes. I really doubt that they will be scrapped/not sold to another airline
whywhyzee
Thu Nov 16, 2017 5:10 pm
I think AC will likely take a good hard look. As it stands next summer, they don’t have any spare widebodies whatsoever, I’m not even sure they have enough for the schedule as it is. It’s also well known that they are looking for used widebodies to bridge the gap between now and the eventual next 787 order.
Do we know for sure EY is going to sell them though?
res77W
Thu Nov 16, 2017 5:24 pm
DL operates 10.
When was this announced?
-Rowen
Btblue
Thu Nov 16, 2017 5:29 pm
Maybe a likely candidate for cargo conversion, perhaps?
https://www.flightglobal.com/news/artic ... io-428408/
Polot
Thu Nov 16, 2017 5:31 pm
Just this week. They are removing F from the planes and making them 2 class.
dubaiamman243
Thu Nov 16, 2017 6:29 pm
Etihad B77L adjusted schedule:
Abu Dhabi – Dallas/Ft. Worth 1 daily until 24MAR18
Abu Dhabi – Los Angeles 1 daily until 14JAN18
Abu Dhabi – Munich 1 flight on 19JAN18
Abu Dhabi – Singapore 1 flight on 05DEC17
Source: https://www.routesonline.com/news/38/ai ... arch-2018/
aemoreira1981
Thu Nov 16, 2017 6:43 pm
These are still twin-jets, and nothing else has the range to reach the USA other than JFK or IAD nonstop without major restrictions. Air India should be trying to buy back these frames...and go 3-4-3 in Y using the Dreamliner specs (33" pitch/17" width) and a true W cabin as well. AI's expansion to North America is limited by its stock.
Another airline that could use them is United, as it wouldn't force UA to perhaps change routes from EWR to DEL, BOM, or HKG to a B77W or a B789 (as when the long-haul B772ERs go 3-4-3, they could be range-restricted for those destinations. They could go 3-4-3 on a B77L and still make those destinations with ease, with a subfleet restricted to EWR for these routes only...unless 7-8 Dreamliners were moved to EWR.
worldranger
Thu Nov 16, 2017 6:47 pm
[threeid][/threeid]
https://www.flightglobal.com/news/artic ... ea-443285/
