nitepilot79
Pax Jumps Off Plane Waiting To Taxi At CLT
Fri May 26, 2017 4:20 pm
Good thing it wasn't one of AA's A330s. I guess he must have had some kind of mental breakdown...
http://www.charlotteobserver.com/news/l ... 96914.html
Article quote:
"Nothing seemed out of order when the flight backed away from its gate and was waiting for the OK to begin heading toward the runway for takeoff to New Bern. All the passengers were seated, and the seatbelt signs were on. That’s when a man, identified as Sein, got out of his seat and tried to open the main door to the aircraft, federal documents say. A flight attendant interceded. So did two passengers. Sein, however, tried to bite the attendant’s hand, then made his way to the galley. There, he pried open the door, and jumped."
jnev3289
Re: Pax Jumps Off Plane Waiting To Taxi At CLT
Fri May 26, 2017 4:25 pm
How will the news spin this as the airline's fault?
jayfred
Fri May 26, 2017 4:33 pm
That seems a bit overly cynical. The news certainly hasn't been kind to the airlines lately, but in most cases it was certainly the airline at fault. This would be pretty difficult to even suggest at being the airline's fault.
jnev3289
Fri May 26, 2017 4:37 pm
Cynicism is required to post around here
SFOformerFA
Fri May 26, 2017 4:39 pm
I'm sure the media will find a way to shed a negative light on the airline. Clearly the media is swarming to any thing out of the ordinary that happens with the airlines like bees to honey.
wjcandee
Fri May 26, 2017 4:43 pm
This was a PSA CRJ-200.
I'm mystified why the article would be referring to sky marshals -- pretty sure there weren't sky marshals on this 50-seat jet.
jnev3289
I forgot Sky Marshals existed
CriticalPoint
Fri May 26, 2017 4:50 pm
Air marshalls are everywhere......that's the point you never know where they are.
SFOATLFlyer
IMO, AA won't get dissed for this. It is a crime for a passenger to attempt to open a door. The article is vague, but doesn't imply any wrongdoing by AA.
Mir
Fri May 26, 2017 4:53 pm
Let's be honest here: who among us hasn't been tempted to try and find a faster way off a CRJ-200? :silly:
readytotaxi
Fri May 26, 2017 4:54 pm
A fit person, lucky not to break his ankles/leg.
Polot
Fri May 26, 2017 5:01 pm
Doesn't the CRJ-200 door swing downwards with the airstairs built in? In which case it isn't too much of a jump. It sounds like the plane was stopped at the time and not taxing.
kjeld0d
Fri May 26, 2017 5:02 pm
The situation was made worse by the absence of a seinlanguage interpreter.
usflyer msp
The plane was so uncomfortable he could not wait to get off...
thewizbizman
Fri May 26, 2017 5:07 pm
Well, The passenger was out of his place, clearly should not have done that. He does deserve jail time and. air Marshall's are randomly assigned to flights. I wonder what the flight crew, cabin crew and passengers did after he jumped.
Also Bombardier CRJ's are good planes. CRJ700LR is the best though :P
Yflyer
Fri May 26, 2017 5:11 pm
It's not entirely clear which door he exited through, but the article says he tried to open the "main door" but the flight attendant stopped him, then he "made his way to the galley". So I'm assuming he exited through the door on the right hand side of the plane through the galley, which wouldn't have stairs.
And I'm not sure if all CRJ-200s have stairs or if they're optional. And if they're optional I have no idea whether PSA has them or not.
Polot
Fri May 26, 2017 5:18 pm
I'm pretty sure they are standard on the CRJ-200. That said you are right I forgot about the service door. Granted it is probably only an ~6-7' drop. I wouldn't expect a 22 year old that looks like he is in good/normal physical condition to break his leg/ankle from the drop unless he has a really bad landing, especially if he dropped down to the floor before exiting instead of leaping from standing.
nitepilot79
Fri May 26, 2017 5:58 pm
On second thought, I'd guess that the chutes on the hypothetical A330 from my op would already have been armed (I guess that's what happens?) because they were about to taxi. Though, I suppose he could have bounced off the slide and hit the tarmac due to the frenzied state.
Blimpie
Fri May 26, 2017 7:17 pm
This guy is yet another forgotten example of the long passes Cola Wars. I never would forget the days spent locked in a room forced to drink Pepsi as a Coca Cola loyalist. They were dark times.
TWA772LR
Fri May 26, 2017 7:35 pm
He's lucky it was a CRJ period. Any other plane he would've broken his legs, became paralyzed, or died. Even the Emb-145s don't have slides, and even though it's a 5 foot drop, unless he was a paratrooper that knew how to fall he would've hurt himself. If it was a prop job, we all know what would happen there...
NeBaNi
Fri May 26, 2017 10:19 pm
I lol'd :lol:
F27500
Fri May 26, 2017 10:59 pm
... People ..it was a CRJ200 .. a Chihuahua could step easily out of the galley door and onto the ramp without any injury .. this was no big jump here! ;)
washingtonflyer
Fri May 26, 2017 11:32 pm
Land wrong and it could be. I took an E145 flight yesterday and sat in 1A. Looked at the signage on the door - it said distance to the ground was 5 feet and change (I think 5' 3"). I'd imagine the CR2 is at a similar height.
kabq737
Sat May 27, 2017 12:01 am
Does the ERJ-145 not have slides?
antoniemey
Sat May 27, 2017 12:39 am
Around 5. I stand 6'2" and the CRJ service door is at about my shoulder height.
Nope.
mhkansan
Sat May 27, 2017 12:42 am
The CR2 floor to ground height is actually higher than the ER4. The ERJ sits on the ground, typically, in a nose-down fashion where the CR2 door is a noticeable amount higher. We have to adjust the jetbridges from the ERJ up to the CR2.
That being said, I have jumped before from the ER4 with no issues :) If you're not fit, you'd have a hard time doing that though.
N62NA
Sat May 27, 2017 4:19 am
This from the article:
"The affidavit says Sein entered the country through Newark, N.J"
I wonder what country he is from.
einsteinboricua
Sat May 27, 2017 4:34 am
"In the world of airline travel, airlines just can't seem to catch a lucky break. American Airlines' regional carrier, American Eagle, is now part of the frenzy taking over.
*cut to reporter explaining the situation*
*cut to Sein talking about his experience*
Sein was simply jetlagged and was anxious for the jet to move. He claims that airlines now stuff coach passengers so tight, there's no room to be comfortable. And he's right. Since Airline Deregulation in 1980s, airlines have cut back on coach space, reducing leg space an average of 5", making seats thinner, and offering pitiful meals. After having traveled half the world in less than 24 hours, who could blame him for wanting to reach his final destination as intended?
American Airlines released a statement saying the behavior was unacceptable, but Sein's lawyers will be filing suit against the airline for damages and emotional stress.
For KADN, I'm einsteinboricua, Civil Aviation Forum"
:praise:
kabq737
Sat May 27, 2017 4:46 am
Nope.[/quote]
Wow I wasn't aware of that. Isn't that kind of dangerous during a fast evacuation?
Balerit
Sat May 27, 2017 10:58 am
An insein one. :)
AVLAirlineFreq
Sat May 27, 2017 3:33 pm
Well, between the fact that he was on a CRJ-200 and the taxi from Concourse E to the runway at CLT can be interminable, who can blame him?
Mainliner
Sat May 27, 2017 5:44 pm
http://www.cnn.com/2017/05/26/us/airlin ... to-tarmac/
He jumped from the galley service door.
It even says so in the original article posted:
"Finally, Tu Lon Sein forced open the galley door of American Airlines flight 5242 on Thursday, and took flight himself ..."
reltney
Sat May 27, 2017 7:24 pm
He pried the door open???? With a plastic knife? Why did he not use the lever lever which says open/close with the big red arrow..... Idiot reporters.......
Pried........ GMAB.
ahj2000
Sun May 28, 2017 3:10 am
Especially If he was going to the 485 runway... ugh
